[MOFScript]Re: Mofscript doesn't show action button [message #384783] |
Thu, 14 August 2008 04:50  |
Hello Ye,
First, MOFScript is not part of the M2T project but GMT and you should post
to eclipse.modeling.gmt and prefix your posting with [MOFScript].This reply
is cross-posted, any follow-ups should only be posted to the gmt list.
I am not sure why you have this problem. You should try the following:
Help -> about eclipse platform -> plug-ins, then sort by plug-in id,
check that you have all the org.eclipse.mofscript.xxx installed.
7 of them, and especially check for the org.eclipse.mofscript.editor.
If this is not the case, try to remove the plugins manually removing all
folders / files in both eclipse\plugins and eclipse\features starting with
org.eclipse.mofscript . Restart eclipse and try to get the latest version
from http://www.modelbased.net/mofscript/update (but it should the same as
the gmt update site)..
G
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619482 is a reply to message #384783] |
Thu, 14 August 2008 08:40  |
I have tried to uninstall all the related mofscript plugin and reinstall
them.1.3.0 version from exactly the website you gave me .But the problem
is still the same:no mofscript wizard, no action buttons,no mofscript
preference.
Can you check if it's the following plugins that are required?
org.eclipse.mofscript.help;
org.eclipse.mofscript.model;
org.eclipse.mofscript.traceabilitymodel;
org.eclipse.mofscript.fileresourcemodel.
These are all the update website provide.
And according to the Mofscript guide,plugins related to ANTLR are also
installed:
org.antlr.runtime;
org.antlr.eclipse.ui;
org.antlr.eclipse.core;
org.antlr.doc
org.antlr
What else could be the reason?
Many thanks!
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619686 is a reply to message #384786] |
Fri, 15 August 2008 03:05  |
Originally posted by: rivas_jorge55.hotmail.com
Hi, i have the same problem, all last week, i was follow the install
instruction but itŽs just dont work, some body have a link to a
bundle_mofscript or a preinstall mofscript UI in eclipse, thats will be
great, any help its usefull thanks.
FUDForum. Page generated in 0.03930 seconds
