Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript]Re: Mofscript doesn't show action button
[MOFScript]Re: Mofscript doesn't show action button [message #384783] Thu, 14 August 2008 04:50 Go to next message
Hello Ye,
First, MOFScript is not part of the M2T project but GMT and you should post
to eclipse.modeling.gmt and prefix your posting with [MOFScript].This reply
is cross-posted, any follow-ups should only be posted to the gmt list.
I am not sure why you have this problem. You should try the following:
Help -> about eclipse platform -> plug-ins, then sort by plug-in id,
check that you have all the org.eclipse.mofscript.xxx installed.
7 of them, and especially check for the org.eclipse.mofscript.editor.
If this is not the case, try to remove the plugins manually removing all
folders / files in both eclipse\plugins and eclipse\features starting with
org.eclipse.mofscript . Restart eclipse and try to get the latest version
from http://www.modelbased.net/mofscript/update (but it should the same as
the gmt update site)..
G
Re: [MOFScript]Re: Mofscript doesn't show action button [message #384786 is a reply to message #384783] Thu, 14 August 2008 08:40 Go to previous messageGo to next message
I have tried to uninstall all the related mofscript plugin and reinstall
them.1.3.0 version from exactly the website you gave me .But the problem
is still the same:no mofscript wizard, no action buttons,no mofscript
preference.
Can you check if it's the following plugins that are required?
org.eclipse.mofscript.help;
org.eclipse.mofscript.model;
org.eclipse.mofscript.traceabilitymodel;
org.eclipse.mofscript.fileresourcemodel.
These are all the update website provide.
And according to the Mofscript guide,plugins related to ANTLR are also
installed:
org.antlr.runtime;
org.antlr.eclipse.ui;
org.antlr.eclipse.core;
org.antlr.doc
org.antlr
What else could be the reason?
Many thanks!
Re: [MOFScript]Re: Mofscript doesn't show action button [message #384788 is a reply to message #384786] Fri, 15 August 2008 03:05 Go to previous messageGo to next message
Originally posted by: rivas_jorge55.hotmail.com
Hi, i have the same problem, all last week, i was follow the install
instruction but itŽs just dont work, some body have a link to a
bundle_mofscript or a preinstall mofscript UI in eclipse, thats will be
great, any help its usefull thanks.
Re: [MOFScript]Re: Mofscript doesn't show action button [message #384791 is a reply to message #384786] Fri, 15 August 2008 05:33 Go to previous messageGo to next message
Hello Ye (and Jorge)
My suggestion is to download and install the latest Eclipse Ganymede 3.4
Modeling bundle:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/R/eclipse-modeling-ganymed e-incubation-win32.zip
Then use the updatesite for MOFScript (http://www.modelbased.net ) it will
be available on eclipse/gmt soon.
This is the configuration I am currently using, and it works.
It should be no problem to follow the same approach using Eclipse 3.3
The latest version of MOFScript does not require the antlr plugins, antlr
3.0 jars are included.
The User manual is unfortunately a bit outdated when it comes to the
installation..
Best Regards
G
Re: [MOFScript]Re: Mofscript doesn't show action button [message #384792 is a reply to message #384786] Fri, 15 August 2008 05:35 Go to previous message
Seems like we have been cross-posting to mt2.
Remove that form your reply
/G
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619482 is a reply to message #384783] Thu, 14 August 2008 08:40 Go to previous message
preference.
installed:
org.antlr.runtime;
org.antlr.doc
org.antlr
Many thanks!
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619686 is a reply to message #384786] Fri, 15 August 2008 03:05 Go to previous message
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619690 is a reply to message #384786] Fri, 15 August 2008 05:33 Go to previous message
Modeling bundle:
installation..
Best Regards
G
Re: [MOFScript]Re: Mofscript doesn't show action button [message #619692 is a reply to message #384786] Fri, 15 August 2008 05:35 Go to previous message
/G
Previous Topic:[MOFScript] input metamodel and preference page
Next Topic:[MOFscript]: where can i find the mofscriptrepository?
Current Time: Sat Jul 19 13:32:57 EDT 2025
Powered by FUDForum. Page generated in 0.04525 seconds
