Home » Language IDEs » AspectJ » Aspect Visualizer Failure
Aspect Visualizer Failure [message #38426] |
Thu, 15 July 2004 12:36  |
I have successfully compiled and run a simple simulation model developed
with AspectJ but the Aspect Visualizer is failing. When I invoke it, all
I see are gray bars and the Error Log says:
"Exception creating editor: the file does not exist." ...
"org.eclipse.ui"
I am wondering whether I have missing or incompatible features or program
components. Can anyone tell what the problem is from the following
information? If not, I would appreciate advice on what the most reliable
AspectJ version configuration is.
Bob
ps. Sorry about previous incomplete post. I accidently hit a key that
automatically sent the post - don't know what key it is yet though.
I am using Eclipse Version: 3.0.0 Build id: 200406251208
The "About Eclipse Platform Features" panel says
Eclipse AspectJ Development Tools Version: 1.1.7 Build id: 1.2.0
The AspectJ Development Tools feature line for AspectJ Development Tools
says version 1.1.10 and Feature Id: org.eclipse.aspectj
The Plug-in details for the AspectJ Development Tools feature say:
Provider (for all 4 features): Eclipse.org
Plug-in Name, Version, Plug-in Id
- AspectDemos, 0.6.10, org.eclipse.ajdt.examples
- AspectJ Development Tools, 1.1.10, org.eclipse.aspectj
- AspectJ Development Tools (AJDT) UI, 0.6.10, org.eclipse.ajdt.ui
- org.aspectj.ajde, 1.1.10, org.aspectj.ajde
Re: Aspect Visualizer Failure [message #38459 is a reply to message #38426] |
Thu, 15 July 2004 13:17   |
Originally posted by: mchapman.uk.ibm.com
Hi Bob,
Firstly, the message in the error log doesn't sound relevant to the
visualiser.
You're using AJDT version 1.1.10. (the 1.1.7 string in the about
page is incorrect). It looks like your configuration is okay, although
1.1.10 was released before your version of Eclipse (3.0 final) so we
couldn't test that combination. AJDT 1.1.11 for Eclipse 3.0 final is due
for release very soon, and I'd definitely recommend upgrading to that
version then.
In the meantime, you could check that your project is being built
correctly by looking for advice markers on the left of the editor.
Also, you could try these steps using one of the bundled
examples:
File > New > Other
Expand "AspectJ", then "AspectJ Examples" Select "TJP Example" and hit
Next, then Finish Expand the newly created project, and open Demo.java in
the editor Check for advice markers down the left hand edge of the editor
Switch to the Aspect Visualization perspective Select "TJP Example" in
the "Projects" view
The visualiser should now show Demo.java with three stripes, and
GetInfo.java will be gray (as it is an aspect).
Hope that helps,
Matt.
> "org.eclipse.ui"
> Bob
> Provider (for all 4 features): Eclipse.org Plug-in Name, Version, Plug-in
> Id
> - AspectDemos, 0.6.10, org.eclipse.ajdt.examples - AspectJ Development
> Tools, 1.1.10, org.eclipse.aspectj - AspectJ Development Tools (AJDT)
> UI, 0.6.10, org.eclipse.ajdt.ui - org.aspectj.ajde, 1.1.10,
> org.aspectj.ajde
Re: Aspect Visualizer Failure [message #38492 is a reply to message #38459] |
Thu, 15 July 2004 15:50  |
Hi Matt,
Thank you.
I cleaned and rebuilt it and seemed to have to click on a couple of
things, but it works.
Bob
Matt Chapman wrote:
> Hi Bob,
> visualiser.
> version then.
> examples:
> File > New > Other
> the "Projects" view
> Hope that helps,
> Matt.
> > "org.eclipse.ui"
> > Thanks,
> > Bob
> > Id
> > org.aspectj.ajde
Re: Aspect Visualizer Failure [message #581459 is a reply to message #38426] |
Hi Bob,
visualiser.
version then.
examples:
File > New > Other
the "Projects" view
Hope that helps,
Matt.
> "org.eclipse.ui"
> Bob
> Id
> org.aspectj.ajde
Re: Aspect Visualizer Failure [message #581480 is a reply to message #38459] |
Hi Matt,
Thank you.
Bob
Matt Chapman wrote:
> Hi Bob,
> visualiser.
> version then.
> examples:
> File > New > Other
> the "Projects" view
> Hope that helps,
> Matt.
> > "org.eclipse.ui"
> > Thanks,
> > Bob
> > Id
> > org.aspectj.ajde
Current Time: Sat Jul 19 15:15:53 EDT 2025
Powered by FUDForum. Page generated in 0.26103 seconds
