Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] Configuring HUTN file
[Epsilon] Configuring HUTN file [message #383907] |
Mon, 30 June 2008 12:28  |
I'm interested in the configuration capabilities of HUTN to define
identifiers and default values.
I've explored the hutnConfig metamodel but it is not clear how to use it
in a HUTN definition file.
If I write the following:
@Configuration{
IdentifierRule "rule"{
attribute: "id"
classifier: "test.Test"
I got an error: [Line: 8, Column: 1, Reason: Unrecognised classifier:
IdentifierRule]
Is there any example of using this configuration mechanism??
Thanks.
Re: [Epsilon] Configuring HUTN file [message #383923 is a reply to message #383907] |
Wed, 02 July 2008 05:42   |
Hi Pau,
Many thanks for your message. Apologies for the late reply; I had a
deadline yesterday.
To use the HUTN configuration metamodel, you should:
1) Create a new instance of the metamodel. In the Epsilon perspective,
Click File | New | EMF Model. Select:
"http://www.eclipse.org/gmt/epsilon/hutnConfig" as the Metamodel URI,
and "Configuration" as the root instance type.
2) Open the new model, and define your rules with tree-structure editor.
3) In your HUTN source file, specify the config file in the same block
as the metamodel nsURI. For example:
@Spec {
MetaModel "FamiliesMetaModel" {
nsUri = "http://www.example.org/families"
configFile = "FamiliesConfig.model"
The value of "configFile" is relative to the HUTN source.
4) Save the HUTN source, and your configuration file should be loaded.
Does this fix your problem?
(On a related note, we do not yet support embedded configuration, as you
describe. This seems to be a sensible alternative to the method outlined
above, and is mentioned in the HUTN specification. I will add it to the
list of features to be implemented in the next iteration (later this month).
Many thanks,
Louis.
Pau Giner wrote:
> Hello,
> @Configuration{
> attribute: "id"
> IdentifierRule]
> Thanks.
Re: [Epsilon] Configuring HUTN file [message #383926 is a reply to message #383923] |
Wed, 02 July 2008 11:36   |
Many thanks for the info.
I tried it, and it works now.
Only a pair of comments:
1. About the embedded configuration: I prefer better the configuration
in a separate file since many of the configuration adjustments are
metamodel-related. So replication could be avoided using a common file
for several instances of your models. But, anyway it is possible for
some people to find the embedded configuration also useful.
2. Just to note that the described configuration process can be also
made using HUTN. Its quite obvious, but just for illustration I copy the
example definition for the configuration model I used:
@Spec{
MetaModel "hutnConfig" {
nsUri: "http://www.eclipse.org/gmt/epsilon/hutnConfig"
hutnConfig{
Configuration "Config"{
rules: IdentifierRule "Rule" {
attribute: "id"
classifier: "TestClass"
Louis Rose escribió:
> Hi Pau,
> deadline yesterday.
> @Spec {
> month).
> Many thanks,
> Louis.
> Pau Giner wrote:
>> Hello,
>> it in a HUTN definition file.
>> @Configuration{
>> attribute: "id"
>> IdentifierRule]
>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #383930 is a reply to message #383926] |
Wed, 02 July 2008 12:00   |
Reply hidden below!
You're welcome, I'm glad we managed to fix the problem.
I agree; being able to specify configuration for each metamodel (rather
than for each HUTN source) is my preferred style too.
> @Spec{
> hutnConfig{
> attribute: "id"
Excellent, I hadn't tried this yet. Great idea!
Louis.
>> Hi Pau,
>> deadline yesterday.
>> @Spec {
>> you describe. This seems to be a sensible alternative to the method
>> outlined above, and is mentioned in the HUTN specification. I will add
>> it to the list of features to be implemented in the next iteration
>> (later this month).
>> Many thanks,
>> Louis.
>> Pau Giner wrote:
>>> Hello,
>>> @Configuration{
>>> attribute: "id"
>>> IdentifierRule]
>>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #384435 is a reply to message #383930] |
Mon, 04 August 2008 08:20   |
--------------060006000006090704070800
Hello!
I'm trying to define a configuration file for UML models using HUTN, but
I have some troubles.
I have followed the instructions you gave to Pau and I have no problems
with some simply metamodels I use for proofs, but when I try to
configure the HUTN files related to the UML metamodel I get this error:
Line: 4, Column: 8, Reason: The attribute "name" for the classifier
"Model" does not accept String values.,
"Package" does not accept String values.
"Package" and "Model" inherit the attribute "name" from "NamedElement",
and it contains a String.
I send you a little example of the files I'm using.
One more doubt. I need to define an attribute whose type is an
enumeration. Reading the HUTN specification I noticed that I have to
config it, but the given examples seem different (like @config instead
of @spec) and I don't know much about how to do it.
Many thanks,
H
Re: [Epsilon] Configuring HUTN file [message #384447 is a reply to message #384435] |
Wed, 06 August 2008 12:20   |
Hello Héctor,
Thanks very much for your message. You can safely ignore the errors that
you mention.
The errors are caused by a bad comparison by the validation of the
configuration model. I've updated the EVL that performs the validation,
and the errors are no longer generated. A patched EVL file is attached,
please overlay your installation. The patch will appear in the next
release of HUTN.
Regarding enumeration types, we did have some support for these, but I
recently removed it as it was quite buggy. I will reintroduce support in
the next release. For now, I'm afraid you will have to specify the value
of your enumeration types by hand after generating the model with HUTN.
Apologies for the inconvenience.
If the value of the enumeration type can be calculated based on the
value of other attributes, you could automate it using EOL. For example:
for (p in Person.allInstances()) {
if (p.name = 'Louis') {
p.gender := MyModel!Gender#male;
} else if (p.name = 'Louise') {
p.gender := MyModel!Gender#female;
Louis.
Héctor Iturria wrote:
> Hello!
> Many thanks,
> Héctor
>> Reply hidden below!
>>> configuration in a separate file since many of the configuration
>>> adjustments are metamodel-related. So replication could be avoided
>>> using a common file for several instances of your models. But, anyway
>>> it is possible for some people to find the embedded configuration
>>> also useful.
>> (rather than for each HUTN source) is my preferred style too.
>>> the example definition for the configuration model I used:
>>> @Spec{
>>> hutnConfig{
>>> attribute: "id"
>> Cheers,
>> Louis.
>>>> Hi Pau,
>>>> deadline yesterday.
>>>> perspective, Click File | New | EMF Model. Select:
>>>> URI, and "Configuration" as the root instance type.
>>>> editor.
>>>> block as the metamodel nsURI. For example:
>>>> @Spec {
>>>> add it to the list of features to be implemented in the next
>>>> Many thanks,
>>>> Louis.
>>>> Pau Giner wrote:
>>>>> Hello,
>>>>> use it in a HUTN definition file.
>>>>> @Configuration{
>>>>> attribute: "id"
>>>>> classifier: IdentifierRule]
>>>>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #384453 is a reply to message #384449] |
Thu, 07 August 2008 02:49  |
Hi Louis, many thanks for the reply :)
I will add the info by hand for now and I will wait until it can be done
in hutn.
Thanks!
Héctor
> Whoops, I forgot to attach the file!
> Many thanks,
> Louis.
> Louis Rose wrote:
>> Hello Héctor,
>> that you mention.
>> validation, and the errors are no longer generated. A patched EVL file
>> is attached, please overlay your installation. The patch will appear
>> in the next release of HUTN.
>> in the next release. For now, I'm afraid you will have to specify the
>> value of your enumeration types by hand after generating the model
>> with HUTN. Apologies for the inconvenience.
>> Cheers,
>> Louis.
>>> Hello!
>>> but I have some troubles.
>>> problems with some simply metamodels I use for proofs, but when I try
>>> to configure the HUTN files related to the UML metamodel I get this
>>> error:
>>> "NamedElement", and it contains a String.
>>> instead of @spec) and I don't know much about how to do it.
>>> Many thanks,
>>> Héctor
>>>> Reply hidden below!
>>>>> anyway it is possible for some people to find the embedded
>>>>> also made using HUTN. Its quite obvious, but just for illustration
>>>>> I copy the example definition for the configuration model I used:
>>>>> @Spec{
>>>>> hutnConfig{
>>>>> attribute: "id"
>>>> Cheers,
>>>> Louis.
>>>>>> Hi Pau,
>>>>>> a deadline yesterday.
>>>>>> editor.
>>>>>> @Spec {
>>>>>> loaded.
>>>>>> as you describe. This seems to be a sensible alternative to the
>>>>>> method outlined above, and is mentioned in the HUTN specification.
>>>>>> I will add it to the list of features to be implemented in the
>>>>>> Many thanks,
>>>>>> Louis.
>>>>>> Pau Giner wrote:
>>>>>>> Hello,
>>>>>>> define identifiers and default values.
>>>>>>> @Configuration{
>>>>>>> attribute: "id"
>>>>>>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618106 is a reply to message #383907] |
Mon, 30 June 2008 17:54  |
Hi Pau,
I've forwarded your message to Louis and he should get back to you shortly.
Dimitrios
P.S. Could you please also start a new thread in the newsgroup for the
comment you wrote on the Epsilon blog about HUTN/UML?
Pau Giner wrote:
> Hello,
> @Configuration{
> attribute: "id"
> IdentifierRule]
> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618112 is a reply to message #383907] |
Hi Pau,
deadline yesterday.
@Spec {
Many thanks,
Louis.
Pau Giner wrote:
> Hello,
> @Configuration{
> attribute: "id"
> IdentifierRule]
> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618116 is a reply to message #383923] |
@Spec{
hutnConfig{
attribute: "id"
> Hi Pau,
> deadline yesterday.
> @Spec {
> month).
> Many thanks,
> Louis.
> Pau Giner wrote:
>> Hello,
>> @Configuration{
>> attribute: "id"
>> IdentifierRule]
>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618118 is a reply to message #383926] |
Reply hidden below!
> @Spec{
> hutnConfig{
> attribute: "id"
Louis.
>> Hi Pau,
>> deadline yesterday.
>> @Spec {
>> (later this month).
>> Many thanks,
>> Louis.
>> Pau Giner wrote:
>>> Hello,
>>> @Configuration{
>>> attribute: "id"
>>> IdentifierRule]
>>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618632 is a reply to message #383930] |
Hello!
Many thanks,
H
Re: [Epsilon] Configuring HUTN file [message #618882 is a reply to message #384435] |
Hello Héctor,
you mention.
release of HUTN.
Louis.
> Hello!
> Many thanks,
> Héctor
>> Reply hidden below!
>>> also useful.
>>> @Spec{
>>> hutnConfig{
>>> attribute: "id"
>> Cheers,
>> Louis.
>>>> Hi Pau,
>>>> deadline yesterday.
>>>> editor.
>>>> @Spec {
>>>> Many thanks,
>>>> Louis.
>>>> Pau Giner wrote:
>>>>> Hello,
>>>>> @Configuration{
>>>>> attribute: "id"
>>>>> Thanks.
Re: [Epsilon] Configuring HUTN file [message #618883 is a reply to message #384447] |
Wed, 06 August 2008 12:23  |
--------------040103010802080702010106
Many thanks,
Louis.
Louis Rose wrote:
> Hello H
Re: [Epsilon] Configuring HUTN file [message #618887 is a reply to message #384449] |
in hutn.
Thanks!
Héctor
> Many thanks,
> Louis.
> Louis Rose wrote:
>> Hello Héctor,
>> that you mention.
>> Cheers,
>> Louis.
>>> Hello!
>>> error:
>>> Many thanks,
>>> Héctor
>>>> Reply hidden below!
>>>>> @Spec{
>>>>> hutnConfig{
>>>>> attribute: "id"
>>>> Cheers,
>>>> Louis.
>>>>>> Hi Pau,
>>>>>> editor.
>>>>>> @Spec {
>>>>>> loaded.
>>>>>> Many thanks,
>>>>>> Louis.
>>>>>> Pau Giner wrote:
>>>>>>> Hello,
>>>>>>> @Configuration{
>>>>>>> attribute: "id"
>>>>>>> Thanks.
Current Time: Sat Jul 19 19:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.05745 seconds
