Home » Eclipse Projects » Subversive » Compare with latest from repository --> EmptyStackException
Compare with latest from repository --> EmptyStackException [message #38364] |
Thu, 27 November 2008 06:54  |
Hello.
When trying the "Compare with latest from repository" feature from J2EE
Perspective for a file in a webapp project, I get the following error
message:
SVN: '0x0000000c: Locate URL in History' operation finished with error:
null
java.util.EmptyStackException
However, synchronizing with repository and using the compare editor in
Team Synchronzing Perspective works without problems.
I'm using JDK 1.5.0_16, Eclipse Ganymede, Subverisve Team Provider
0.7.5.I20081029-1900 and SVNKit 1.2.0 Implementation (version
2.0.5-I20081024-1200).
Thanks for any help and sorry if this is not the right forum.
Re: Compare with latest from repository --> EmptyStackException [message #40110 is a reply to message #39921] |
Tue, 06 January 2009 11:34   |
I too have this problem. The report states:
null
null
I am installing the Mylyn integration for SVN and will submit the bug
along that route. That failed (authentication error) so I will paste it
here. I will try to get it submitted automatically as well.
Version: 0.7.3.I20080814-1500
SVN Client: org.eclipse.team.svn.connector.svnkit15 2.0.6.I20081205-1900
SVN/1.5.4 SVNKit/1.2.1 (http://svnkit.com/) r5306
JVM Properties:
{java.vendor=Sun Microsystems Inc., osgi.bundles.defaultStartLevel=4,
sun.java.launcher=SUN_STANDARD,
org.osgi.supports.framework.extension=true,
sun.management.compiler=HotSpot Client Compiler,
osgi.framework.beginningstartlevel=1, eclipse.p2.profile=PlatformProfile,
os.name=Linux, osgi.ws=gtk, sun.desktop=gnome,
java.vm.specification.vendor=Sun Microsystems Inc.,
java.runtime.version=1.6.0_10-b33,
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off,
osgi.instance.area=file:/home/gary/workspace-2/, user.name=gary,
eclipse.launcher=/home/gary/eclipse-3-4/eclipse,
org.osgi.framework.language=en, user.language=en,
org.osgi.framework.processor=x86,
osgi.syspath=/home/gary/eclipse-3-4/plugins,
sun.boot.library.path=/usr/java/jdk1.6.0_10/jre/lib/i386,
osgi.manifest.cache=/home/gary/eclipse-3-4/configuration/org .eclipse.osgi/manifests,
osgi.compatibility.bootdelegation=true, java.version=1.6.0_10,
org.osgi.framework.os.name=Linux, user.timezone=GMT-05:00,
sun.arch.data.model=32,
java.endorsed.dirs=/usr/java/jdk1.6.0_10/jre/lib/endorsed,
sun.cpu.isalist=, sun.jnu.encoding=UTF-8, file.encoding.pkg=sun.io,
org.osgi.framework.vendor=Eclipse, file.separator=/,
java.specification.name=Java Platform API Specification,
java.class.version=50.0, user.country=US,
org.eclipse.equinox.launcher.splash.location=/home/gary/ecli pse-3-4/plugins/org.eclipse.platform_3.3.101.v200809111700/s plash.bmp,
java.home=/usr/java/jdk1.6.0_10/jre, osgi.os=linux, eclipse.commands=-os
linux -ws gtk -arch x86 -showsplash -launcher
/home/gary/eclipse-3-4/eclipse -name Eclipse --launcher.library
/home/gary/eclipse-3-4/plugins/org.eclipse.equinox.launcher. gtk.linux.x86_1.0.101.R34x_v20080805/eclipse_1115.so
-startup
/home/gary/eclipse-3-4/plugins/org.eclipse.equinox.launcher_ 1.0.101.R34x_v20080819.jar
-exitdata 2d8000d -framework
plugins/org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar -clean -data
/home/gary/workspace-2 -vmargs-Xmx1500m -Xms1500m -XX:MaxPermSize=128M -vm
/usr/java/jdk1.6.0_10/bin/java , java.vm.info=mixed mode, sharing,
osgi.splashLocation=/home/gary/eclipse-3-4/plugins/org.eclip se.platform_3.3.101.v200809111700/splash.bmp,
os.version=2.6.23.1-42.fc8, osgi.arch=x86, path.separator=:,
java.vm.version=11.0-b15, org.osgi.supports.framework.fragment=true,
osgi.framework.shape=jar,
osgi.instance.area.default=file:/home/gary/workspace/,
java.awt.printerjob=sun.print.PSPrinterJob,
sun.io.unicode.encoding=UnicodeLittle, org.osgi.framework.version=1.4.0,
osgi.install.area=file:/home/gary/eclipse-3-4/,
osgi.framework=file:/home/gary/eclipse-3-4/plugins/org.eclip se.osgi_3.4.2.R34x_v20080826-1230.jar,
user.home=/home/gary,
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info,
osgi.bundlestore=/home/gary/eclipse-3-4/configuration/org.ec lipse.osgi/bundles,
osgi.splashPath=platform:/base/plugins/org.eclipse.platform,
osgi.nl=en_US, java.specification.vendor=Sun Microsystems Inc.,
java.library.path=/usr/java/jdk1.6.0_10/jre/lib/i386/client: /usr/java/jdk1.6.0_10/jre/lib/i386:/usr/java/jdk1.6.0_10/jre /../lib/i386:/usr/lib/firefox-2.0.0.17:/usr/java/packages/li b/i386:/lib:/usr/lib,
java.vendor.url=http://java.sun.com/,
org.osgi.framework.os.version=2.6.23.1-42,
eclipse.startTime=1231258861630, eclipse.p2.data.area=@config.dir/../p2,
java.vm.vendor=Sun Microsystems Inc., java.runtime.name=Java(TM) SE
Runtime Environment,
java.class.path=/home/gary/eclipse-3-4/plugins/org.eclipse.e quinox.launcher_1.0.101.R34x_v20080819.jar,
osgi.requiredJavaVersion=1.5,
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off,
org.eclipse.update.reconcile=false,
eclipse.vm=/usr/java/jdk1.6.0_10/bin/java, java.vm.specification.name=Java
Virtual Machine Specification, java.vm.specification.version=1.0,
sun.cpu.endian=little, sun.os.patch.level=unknown,
org.apache.commons.logging.simplelog.defaultlog=off, java.io.tmpdir=/tmp,
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi,
eclipse.product=org.eclipse.platform.ide,
jna.platform.library.path=/usr/lib:/lib,
eclipse.home.location=file:/home/gary/eclipse-3-4/, os.arch=i386,
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment,
java.ext.dirs=/usr/java/jdk1.6.0_10/jre/lib/ext:/usr/java/pa ckages/lib/ext,
user.dir=/home/gary, org.osgi.supports.framework.requirebundle=true,
osgi.clean=true, line.separator= , java.vm.name=Java HotSpot(TM) Client
VM,
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog,
eclipse.ee.install.verify=false, file.encoding=UTF-8,
osgi.framework.version=3.4.2.R34x_v20080826-1230,
eclipse.buildId=M20080911-1700,
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx256m
-XX:MaxPermSize=256m -jar
, java.specification.version=1.6,
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6,
osgi.logfile=/home/gary/workspace-2/.metadata/.log,
osgi.configuration.area=file:/home/gary/eclipse-3-4/configur ation/}
at java.util.Stack.peek(Stack.java:85)
at java.util.Stack.pop(Stack.java:67)
at
org.eclipse.team.svn.core.utility.SVNUtility$8.next(SVNUtili ty.java:380)
at
org.tigris.subversion.javahl.ConversionUtility$2.singleMessa ge(ConversionUtility.java:94)
at
org.tigris.subversion.javahl.JavaHLObjectFactory.handleLogMe ssage(JavaHLObjectFactory.java:527)
at
org.tmatesoft.svn.core.javahl.SVNClientImpl$6.handleLogEntry (SVNClientImpl.java:487)
at
org.tmatesoft.svn.core.wc.SVNLogClient$2.handleLogEntry(SVNL ogClient.java:783)
at
org.tmatesoft.svn.core.internal.io.dav.DAVRepository$1.handl eLogEntry(DAVRepository.java:596)
at
org.tmatesoft.svn.core.internal.io.dav.DAVRepository.logImpl (DAVRepository.java:645)
at org.tmatesoft.svn.core.io.SVNRepository.log(SVNRepository.ja va:1034)
at org.tmatesoft.svn.core.wc.SVNLogClient.doLog(SVNLogClient.ja va:799)
at
org.tmatesoft.svn.core.javahl.SVNClientImpl.logMessages(SVNC lientImpl.java:506)
at
org.tmatesoft.svn.core.javahl.SVNClientImpl.logMessages(SVNC lientImpl.java:484)
at
org.polarion.team.svn.connector.svnkit.SVNKitConnector.logEn tries(SVNKitConnector.java:1179)
at
org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.logEntries(ThreadNameModifier.java:296)
at
org.eclipse.team.svn.core.utility.SVNUtility.logEntries(SVNU tility.java:375)
at
org.eclipse.team.svn.core.operation.remote.LocateResourceURL InHistoryOperation.processEntry(LocateResourceURLInHistoryOp eration.java:80)
at
org.eclipse.team.svn.core.operation.remote.LocateResourceURL InHistoryOperation$1.run(LocateResourceURLInHistoryOperation .java:61)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doS ubTask(ProgressMonitorUtility.java:117)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. protectStep(AbstractActionOperation.java:145)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. protectStep(AbstractActionOperation.java:140)
at
org.eclipse.team.svn.core.operation.remote.LocateResourceURL InHistoryOperation.runImpl(LocateResourceURLInHistoryOperati on.java:59)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:76)
at
org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:37)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:80)
at
org.eclipse.team.svn.ui.operation.CompareResourcesOperation$ 2.run(CompareResourcesOperation.java:116)
at
at
at
org.eclipse.team.svn.ui.operation.CompareResourcesOperation. runImpl(CompareResourcesOperation.java:113)
at
at
at
org.eclipse.team.svn.core.operation.CompositeOperation.runIm pl(CompositeOperation.java:94)
at
at
at
at
at
org.eclipse.team.svn.ui.utility.DefaultCancellableOperationW rapper.run(DefaultCancellableOperationWrapper.java:55)
at
org.eclipse.team.svn.ui.utility.SVNTeamOperationWrapper.run( SVNTeamOperationWrapper.java:35)
at
org.eclipse.team.internal.ui.actions.JobRunnableContext.run( JobRunnableContext.java:144)
at
org.eclipse.team.internal.ui.actions.JobRunnableContext$Reso urceJob.runInWorkspace(JobRunnableContext.java:72)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Compare with latest from repository --> EmptyStackException [message #40351 is a reply to message #40110] |
Wed, 14 January 2009 12:12  |
Hello Gary,
The problem was resolved, please, update to latest version. For more details
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=249285
> null
> null
> JVM Properties:
> -startup
> VM,
> eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx256m -XX:MaxPermSize=256m
> -jar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Sun Jul 20 09:50:03 EDT 2025
Powered by FUDForum. Page generated in 0.05160 seconds
