Home » Language IDEs » ServerTools (WTP) » WS Bottom-up tutorial problem
WS Bottom-up tutorial problem [message #35549] Fri, 30 July 2004 16:11 Go to next message
Originally posted by: jeff.broberg.us
Has anyone gotten the WS Bottom-up tutorial to run successfully. I first
tried by using Tomcat5, and that seemed to cause problems, so I moved to
Tomcat4.1. Now when I run the wizard, I get a dialog that shows up over
and over stating that it "IWAB0506E Error when copying Axis jar files to
web project". Eventually I can get to a details dialog which shows :
org/apache/axis/tools/ant/wsdl/Java2WsdlAntTask
java.lang.NoClassDefFoundError:
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.defineClass(DefaultClassLoader.java:298)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:223)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClassImpl(DefaultClassLoader.java:281)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultCl assLoader.findClass(DefaultClassLoader.java:172)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:220)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:135)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:59)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at
com.ibm.etools.webservice.axis.consumption.command.Java2WSDL Command.executeAntTask(Java2WSDLCommand.java:100)
at
com.ibm.etools.webservice.axis.consumption.command.Java2WSDL Command.execute(Java2WSDLCommand.java:85)
at
com.ibm.env.command.fragment.CommandFragmentEngine.runComman d(CommandFragmentEngine.java:312)
at
com.ibm.env.command.fragment.CommandFragmentEngine.visitTop( CommandFragmentEngine.java:278)
at
com.ibm.env.command.fragment.CommandFragmentEngine.moveForwa rdToNextStop(CommandFragmentEngine.java:198)
at
com.ibm.env.widgets.SimpleCommandEngineManager$4.run(SimpleC ommandEngineManager.java:196)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
at
com.ibm.env.widgets.SimpleCommandEngineManager.runForwardToN extStop(SimpleCommandEngineManager.java:165)
at
com.ibm.env.internal.widgets.WizardPageManager.runForwardToN extStop(WizardPageManager.java:59)
at
com.ibm.env.internal.widgets.WizardPageManager.getNextPage(W izardPageManager.java:81)
at
com.ibm.env.internal.widgets.SimpleWizardPage.getNextPage(Si mpleWizardPage.java:113)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:674)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:300)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at
com.ibm.env.widgets.popup.DynamicPopupWizard.run(DynamicPopu pWizard.java:112)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Has anyone seen this before, any suggestions would be greatly appreciated.
Jeff
Re: WS Bottom-up tutorial problem [message #36977 is a reply to message #35549] Wed, 04 August 2004 12:59 Go to previous messageGo to next message
Sounds like some classloader problem... first thing to check is, make sure
<eclipse install directory>/plugins/org.apache.axis_1.0.1/lib/axis-ant.jar
exists, and make sure it contains the
org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask class.
Jeff
"Jeff Broberg" <jeff@broberg.us> wrote in message
news:ceea1e$bkf$1@eclipse.org...
> at
> at
Loader.java:223)
> at
> at
> at
> at
> at
assLoader.java:59)
> at
oader.java:371)
> at
..java:402)
> at
> at
> at
> at
tEngine.java:312)
> at
ngine.java:278)
> at
> at
ger.java:196)
> at
a:303)
> at
> at
geManager.java:59)
> at
..java:81)
> at
ava:113)
> at
> at
> at
> at
> at
> at
> at
> at
tem.java:866)
> at
tionItem.java:785)
> at
> at
> at
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> Jeff
Re: WS Bottom-up tutorial problem [message #37668 is a reply to message #36977] Mon, 09 August 2004 11:45 Go to previous messageGo to next message
Yes- that dir, and class exists, BUT, an org.apache.axis_1.1.0 also
exists. and its dir structure is different ( no lib dir ), and the only
jars in the pluggins dir are ( axis, jaxrpc, saaj, wsdl4j ).
Jeff
> Jeff
> > at
> > at
> Loader.java:223)
> > at
> > at
> > at
> > at
> > at
> assLoader.java:59)
> > at
> oader.java:371)
> > at
> ..java:402)
> > at
> > at
> > at
> > at
> tEngine.java:312)
> > at
> ngine.java:278)
> > at
> > at
> ger.java:196)
> > at
> a:303)
> > at
> > at
> geManager.java:59)
> > at
> ..java:81)
> > at
> ava:113)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> tem.java:866)
> > at
> tionItem.java:785)
> > at
> > at
> > at
> > at
> > at
> java:335)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
> > Jeff
Re: WS Bottom-up tutorial problem [message #38185 is a reply to message #37668] Wed, 11 August 2004 12:42 Go to previous messageGo to next message
That's strange... I just double checked the initial IBM contribution, it
doesn't have org.apache.axis_1.1.0 in it. If that plugin's id is
"org.apache.axis" (probably is), that would explain why you are getting a
NoClassDefFound exception. If you check the
com.ibm.etools.webservice.axis.consumption.ui (or other Web service plugins
that depend on org.apache.axis), the
<import plugin="org.apache.axis"/>
statement does not specify exactly which version of org.apache.axis it
depends on. I think that will pick up the most recent one, which is 1.1.0
and not 1.0.1. Since the org.apache.axis_1.1.0 plugin does not contain
axis-ant.jar, that's probably why you ran into that NoClassDefFound
exception. Try removing that org.apache.axis_1.1.0 plugin (remember to back
it up), see if that fixes the problem.
Jeff
news:cf8660$kbd$1@eclipse.org...
> Jeff
sure
> > <eclipse install
> > Jeff
first
to
over
to
> > > at
> > > at
> > Loader.java:223)
> > > at
> > > at
> > > at
> > > at
> > > at
> > assLoader.java:59)
> > > at
> > oader.java:371)
> > > at
> > ..java:402)
> > > at
> > > at
> > > at
> > > at
> > tEngine.java:312)
> > > at
> > ngine.java:278)
> > > at
> > > at
> > ger.java:196)
> > > at
> > a:303)
> > > at
> > > at
> > > at
> > > at
> > geManager.java:59)
> > > at
> > ..java:81)
> > > at
> > ava:113)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > tem.java:866)
> > > at
> > tionItem.java:785)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > java:335)
> > > at
> > > at
> > > at
> > > at
> > ..java:25)
appreciated.
> > > Jeff
Re: WS Bottom-up tutorial problem [message #39186 is a reply to message #38185] Mon, 16 August 2004 23:51 Go to previous message
Yes, removing it fixed the problem. I think the plugin came from Lomboz
when I installed it. So there seems to be a conflict having both the IBM
Contribution and Lomboz installed at the same time.
Jeff
> Jeff
> > Jeff
> sure
> > > <eclipse install
> > > Jeff
> first
> to
> over
> to
> > > > at
> > > > at
> > > Loader.java:223)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > assLoader.java:59)
> > > > at
> > > oader.java:371)
> > > > at
> > > ..java:402)
> > > > at
> > > > at
> > > > at
> > > > at
> > > tEngine.java:312)
> > > > at
> > > ngine.java:278)
> > > > at
> > > > at
> > > ger.java:196)
> > > > at
> > > a:303)
> > > > at
> > > > at
> > > > at
> > > > at
> > > geManager.java:59)
> > > > at
> > > ..java:81)
> > > > at
> > > ava:113)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > tem.java:866)
> > > > at
> > > tionItem.java:785)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > java:335)
> > > > at
> > > > at
> > > > at
> > > > at
> > > ..java:25)
> appreciated.
> > > > Jeff
Previous Topic:Weekly PMC Conference Call minutes for August 16 are on the website
Next Topic:[ANN] MyEclipse 3.8.0 GA is now available for download
Current Time: Sat Jul 19 09:35:37 EDT 2025
Powered by FUDForum. Page generated in 0.03594 seconds
