Home » Eclipse Projects » Mylyn » Create Mylyn task from a source file I'm looking at
Create Mylyn task from a source file I'm looking at [message #381084] Wed, 29 July 2009 17:30 Go to next message
is it possible to create a Mylyn task which includes directly the (Java)
source file I'm currently working on?
My workflow is usually the following:
1.) I start searching for an issue / example
2.) If I find it and if it is easy, I fix it immediately
3.) If during my analysis I discover that the fix will be complex I
create a task for Mylyn this
Unfortunately if I create a new task I have not found an option to
directly include a file. If I activate the task the Java package
explorer is closed, I have to remove the Mylyn filter, re-search the
file and open it to add it to my task.
As this is unnecessary and time consuming I would like to create a task
directly from a source file (and the source file should be added to the
context)?
Is this possible?
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
Re: Create Mylyn task from a source file I'm looking at [message #412141 is a reply to message #381084] Thu, 30 July 2009 04:45 Go to previous messageGo to next message
Hi Lars,
if I remember correctly, a new Mylyn task without any context will start with the currently open
files. I.e.
- Create new task
- Open some files or vice versa
- Activate task
Now the context should contain the already open files.
I did not re-test this with the latest Mylyn 3.3, but if this feature is gone, it is worth a bug report.
Cheers, Jörg
P.S. Did you know that from the Markers view (errors/warnings, TODO/FIXME annotations etc.) you can
create a task by right clicking and selecting "New task from marker" etc?
> context)?
> Is this possible?
> Best regards, Lars
Re: Create Mylyn task from a source file I'm looking at [message #412144 is a reply to message #412141] Thu, 30 July 2009 04:51 Go to previous message
Hi Jörg,
that for the answer.
Unfortunately the this doesn't work the, e..g the file is not added if
you activate the task.
Even if you create a task from the marker it doesn't include the file,
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=260627
Best regards, Lars
Jörg Thönnes wrote:
> Hi Lars,
> files. I.e.
> - Create new task
> - Activate task
> Cheers, Jörg
>> context)?
>> Is this possible?
>> Best regards, Lars
Re: Create Mylyn task from a source file I'm looking at [message #598471 is a reply to message #381084] Thu, 30 July 2009 04:45 Go to previous message
Hi Lars,
files. I.e.
- Create new task
- Activate task
Cheers, Jörg
> context)?
> Is this possible?
> Best regards, Lars
Re: Create Mylyn task from a source file I'm looking at [message #598478 is a reply to message #412141] Thu, 30 July 2009 04:51 Go to previous message
Hi Jörg,
Best regards, Lars
Jörg Thönnes wrote:
> Hi Lars,
> files. I.e.
> - Create new task
> - Activate task
> Cheers, Jörg
>> context)?
>> Is this possible?
>> Best regards, Lars
Previous Topic:Mylyn - Private attachments and messages
Next Topic:viewing an attached screenshot
Current Time: Sun Jul 20 15:11:41 EDT 2025
Powered by FUDForum. Page generated in 0.04647 seconds
