Home » Eclipse Projects » EclipseLink » NPE running JPA with Spring 2.5 & Tomcat 5
NPE running JPA with Spring 2.5 & Tomcat 5 [message #381080] Thu, 04 September 2008 04:22 Go to next message
Hi All,
I"m running into the following issue. The same code works fine in the
test but when I deployed to Tomcat. I'm getting the following NPE.
Any hint or clues? All it's doing is trying to execute the simple
findAll.
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. addStructConverters(EntityManagerSetupImpl.java:317)
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:247)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:69)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:118)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:112)
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:100)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:597)
org.springframework.orm.jpa.AbstractEntityManagerFactoryBean $ManagedEntityManagerFactoryInvocationHandler.invoke(Abstrac tEntityManagerFactoryBean.java:434)
$Proxy10.createEntityManager(Unknown Source)
org.springframework.orm.jpa.SharedEntityManagerCreator$Share dEntityManagerInvocationHandler.invoke(SharedEntityManagerCr eator.java:189)
$Proxy22.createQuery(Unknown Source)
com.gomper.persistence.ProfileDAO.findAll(ProfileDAO.java:39 )
com.gomper.service.RegistrationManager.getAllRegistration(Re gistrationManager.java:32)
com.gomper.web.RegistrationController.getAllRegistration(Reg istrationController.java:37)
org.springframework.web.bind.annotation.support.HandlerMetho dInvoker.doInvokeMethod(HandlerMethodInvoker.java:409)
org.springframework.web.bind.annotation.support.HandlerMetho dInvoker.invokeHandlerMethod(HandlerMethodInvoker.java:132)
org.springframework.web.servlet.mvc.annotation.AnnotationMet hodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandle rAdapter.java:310)
org.springframework.web.servlet.mvc.annotation.AnnotationMet hodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java :297)
org.springframework.web.servlet.DispatcherServlet.doDispatch (DispatcherServlet.java:875)
org.springframework.web.servlet.DispatcherServlet.doService( DispatcherServlet.java:809)
org.springframework.web.servlet.FrameworkServlet.processRequ est(FrameworkServlet.java:571)
org.springframework.web.servlet.FrameworkServlet.doGet(Frame workServlet.java:501)
javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
Thanks.
Re: NPE running JPA with Spring 2.5 & Tomcat 5 [message #381081 is a reply to message #381080] Thu, 04 September 2008 14:22 Go to previous messageGo to next message
I upgraded to Eclipselink 1.0.1 M3. Any shed of light?
Now I'm getting the following exception.
java.lang.IllegalStateException: Attempting to execute an operation on a
closed EntityManager.
org.eclipse.persistence.internal.jpa.EntityManagerImpl.verif yOpen(EntityManagerImpl.java:849)
org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultL ist(EJBQueryImpl.java:502)
Re: NPE running JPA with Spring 2.5 & Tomcat 5 [message #381267 is a reply to message #381081] Fri, 05 September 2008 20:30 Go to previous messageGo to next message
Hi All,
This is getting down frustrating that the behavior is so flaky.
I have Spring 2.5, Tomcat6 and EclipseLink 1.0M11.
The following is what my method have:
@Transactional (propagation= Propagation.REQUIRED)
public void save(BaseModel anObject) {
anObject.setUpdatedTime(new Date(System.currentTimeMillis()));
this.getEntityManager().merge(anObject);
this.getEntityManager().flush();
One time it would work fine and most time it will give the following
exception.
And this is not used concurrently yet. Any help is appreciated. I've
been stuck with this for a week.
org.springframework.web.util.NestedServletException: Request processing
failed; nested exception is
javax.persistence.TransactionRequiredException:
Exception Description: No transaction is currently active
org.springframework.web.servlet.FrameworkServlet.processRequ est(FrameworkServlet.java:583)
javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
root cause
org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionWrapper.throwCheckTransactionFailedException(EntityTra nsactionWrapper.java:109)
org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionWrapper.checkForTransaction(EntityTransactionWrapper.j ava:50)
org.eclipse.persistence.internal.jpa.EntityManagerImpl.check ForTransaction(EntityManagerImpl.java:898)
org.eclipse.persistence.internal.jpa.EntityManagerImpl.flush (EntityManagerImpl.java:384)
org.springframework.orm.jpa.ExtendedEntityManagerCreator$Ext endedEntityManagerInvocationHandler.invoke(ExtendedEntityMan agerCreator.java:358)
$Proxy22.flush(Unknown Source)
org.springframework.orm.jpa.SharedEntityManagerCreator$Share dEntityManagerInvocationHandler.invoke(SharedEntityManagerCr eator.java:197)
com.gomper.persistence.BaseDAO.save(BaseDAO.java:41)
com.gomper.service.RegistrationManager.register(Registration Manager.java:27)
com.gomper.web.RegistrationController.delete(RegistrationCon troller.java:56)
Re: NPE running JPA with Spring 2.5 & Tomcat 5 [message #381268 is a reply to message #381267] Fri, 05 September 2008 20:31 Go to previous messageGo to next message
BTW, if I attached JPDA it seems to work fine. So it looks like there is
racing condition that's happening internally.
Re: NPE running JPA with Spring 2.5 & Tomcat 5 [message #381269 is a reply to message #381267] Fri, 05 September 2008 20:57 Go to previous message
Problem solved, issue is with AOP.
I need to put the following in my aop.xml:
<?xml version="1.0"?>
<aspectj>
<weaver options="-showWeaveInfo
-XmessageHandlerClass:org.springframework.aop.aspectj.Aspect JWeaverMessageHandler ">
<include within="com.gomper..*"/>
</weaver>
</aspectj>
This is to ensure that it uses the right weaver.
Previous Topic:Join-Fetch with 1--> 0..N Cardinality
Next Topic:Exception [EclipseLink-30005] - Persistence FAILED
Current Time: Sat Jul 19 19:15:20 EDT 2025
Powered by FUDForum. Page generated in 0.17863 seconds
