Home » Archived » Buckminster » Headless buckminster through a proxy server
Headless buckminster through a proxy server [message #379297] Tue, 19 August 2008 20:33 Go to next message
I am running buckminster headless behind a proxy server. However, I cannot
get it to work through the proxy. Specifically, I'd like to run something
like:
C:\> buckminster install
http://download.eclipse.org/tools/buckminster/updates-3.4/he adless-site.xml
org.eclipse.buckminster.pde.headless.feature
Is there a way to make this command work through a proxy?
-- Scott
Re: Headless buckminster through a proxy server [message #379298 is a reply to message #379297] Wed, 20 August 2008 02:18 Go to previous messageGo to next message
Hi Scott,
Buckminster is using the standard Eclipse update manager (the old one,
not p2 yet) to install things from an update site. If I remember
correctly, it in turn uses the network connection settings available in
the IDE ("Windows -> Preferences -> General -> Network Connections).
In order to make Buckminster headless aware of this setting you'll need
to use a workspace template. I.e. start an Eclipse IDE on a new empty
workspace, define this settings (and others that you may wish to have),
exit the Eclipse instance and create a zip from the workspace.
Whenever you run the install command, unzip this workspace to some
location and point to that location with the -data <location> option.
Thomas Hallgren
> cannot get it to work through the proxy. Specifically, I'd like to run
> something like:
> -- Scott
Re: Headless buckminster through a proxy server [message #379299 is a reply to message #379297] Wed, 20 August 2008 02:38 Go to previous messageGo to next message
> something like:
> -- Scott
for 3.4 we use following Ant tasks to set UM proxy settings:
<mkdir dir="${osgi.configuration.area}/.settings" />
<propertyfile
file=" ${osgi.configuration.area}/.settings/org.eclipse.core.net.pr efs ">
<entry key="proxyData/HTTPS/host" value="${http.proxyHost}" />
<entry key="proxyData/HTTPS/port" value="${http.proxyPort}" />
<entry key="proxyData/HTTPS/hasAuth" value="false" />
<entry key="proxyData/HTTP/host" value="${http.proxyHost}" />
<entry key="proxyData/HTTP/port" value="${http.proxyPort}" />
<entry key="proxyData/HTTP/hasAuth" value="false" />
<entry key="nonProxiedHosts" value="${http.nonProxyHosts}" />
<entry key="proxiesEnabled" value="${http.proxySet}" />
<entry key="eclipse.preferences.version" value="1" />
</propertyfile>
Cheers
Markus
Re: Headless buckminster through a proxy server [message #381056 is a reply to message #379299] Wed, 12 November 2008 19:02 Go to previous messageGo to next message
Thanks Markus, I did find this useful!
-- Scott
>> something like:
>> C:> buckminster install
>> Thanks,
>> -- Scott
> <propertyfile
> </propertyfile>
> Cheers
> Markus
Re: Headless buckminster through a proxy server [message #381057 is a reply to message #379298] Wed, 12 November 2008 19:18 Go to previous messageGo to next message
Hi Thomas,
My proxy server requires authentication. I can configure the server and
port using the -D parameters described here:
http://dev.eclipse.org/newslists/news.eclipse.technology.buc kminster/msg00364.html
It's clear that buckminster *is* recognizing the "http.proxyHost" and
"http.proxyPort" properties. However, it is not using the username and
password properties. I've tried them with and without quotes.
I'm using buckminster.product-1.1.0.r09505.zip with the the specific
command:
java -Dhttp.proxyHost=<proxy> -Dhttp.proxyPort=<proxyport>
-Dhttp.proxyUserName=<username> -Dhttp.proxyPassword=<password> -jar
buckminster\startup.jar listsite
I get a response: [Server returned HTTP response code: "407 Proxy
Authentication Required" for URL:
http://download.eclipse.org/tools/buckminster/updates.]
Also, on a surprising aside, when I downloaded the
buckminster.archivedsite-1.1.0.r09616.zip , unzipped it, and then pointed
to it in order to install the updates locally. Buckminster still tries to
access the mirror URL -- so, I cannot even install those features (without
tampering with the site.xml file).
Any help would be greatly appreciated!
Thank you,
-- Scott
Thomas Hallgren wrote:
> Hi Scott,
> Regards,
> Thomas Hallgren
>> something like:
>> Thanks,
>> -- Scott
Re: Headless buckminster through a proxy server [message #381059 is a reply to message #381057] Wed, 12 November 2008 19:47 Go to previous messageGo to next message
Hi Scott,
Can you try something similar to this:
java -Dhttp.proxyHost=http://username:password@your.host/ -Dhttp.proxyPort=<proxyport>
Thomas Hallgren
Scott Hendrickson wrote:
> Hi Thomas,
> command:
> pointed to it in order to install the updates locally. Buckminster still
> tries to access the mirror URL -- so, I cannot even install those
> features (without tampering with the site.xml file).
> Thank you,
> -- Scott
>> Hi Scott,
>> in the IDE ("Windows -> Preferences -> General -> Network Connections).
>> need to use a workspace template. I.e. start an Eclipse IDE on a new
>> empty workspace, define this settings (and others that you may wish to
>> have), exit the Eclipse instance and create a zip from the workspace.
>> Regards,
>> Thomas Hallgren
>>> run something like:
>>> Thanks,
>>> -- Scott
Re: Headless buckminster through a proxy server [message #381060 is a reply to message #381057] Wed, 12 November 2008 19:52 Go to previous messageGo to next message
(Oh, I forgot to mention that I did try using a workspace that works
within eclipse as well. I can get through the proxy within Eclipse. It's
just from headless buckminster that I'm having problems -- Scott)
> Hi Thomas,
> command:
> buckminsterstartup.jar listsite
> Thank you,
> -- Scott
>> Hi Scott,
>> Regards,
>> Thomas Hallgren
>>> something like:
>>> Thanks,
>>> -- Scott
Re: Headless buckminster through a proxy server [message #381061 is a reply to message #381059] Wed, 12 November 2008 20:00 Go to previous messageGo to next message
Sure. I get a [Premature end of file.] exception (this is the same
exception I get if I do not specify the proxy setting at all -- so, I
assume that it means that the proxy is not being used).
I actually haven't been able to get an authentication error if I use
"http://" as part of the proxyHost property. It seems that adding the
"http://" property causes the property to be ignored altogether. (Or maybe
at least assumes the port is 80, but for me it's 8080)
I've also tried -Dhttp.proxyHost=http://username:password@your.host:port/
The only time I get the authentication error is when I use the proxy host
in a bare format (i.e., without "http://").
-- Scott
> Hi Scott,
> Regards,
> Thomas Hallgren
>> Hi Thomas,
>> command:
>> Thank you,
>> -- Scott
>>> Hi Scott,
>>> Regards,
>>> Thomas Hallgren
>>>> run something like:
>>>> Thanks,
>>>> -- Scott
Re: Headless buckminster through a proxy server [message #381088 is a reply to message #381061] Fri, 14 November 2008 18:46 Go to previous messageGo to next message
It seems that buckminster headless is ignoring any proxy and any
username/password settings normally stored in eclipse.
For example, I see that proxy and username/password information is stored
in the following files within the eclipse installation folder:
* ${eclipse.home}/configuration/.settings/org.eclipse.core.net .prefs
* ${eclipse.home}/configuration/org.eclipse.core.runtime/.keyr ing
To verify this, if I create a new installation of eclipse and copy these
files over, the proxy information is correct, the username/password for
the proxy is correct. Furthermore, the username/password for the svn
repositories seems to be stored in the keyring file as well. For example,
when I add a repository to a server requiring authentication, I am not
prompted for a username/password, and I am able to access the files, if I
copied the .keyring file in to the eclipse installation. From that
installation, I can resolve the queries, access an rmap (cx:
http://206.191.52.50/newsportal/article.php?id=575&group =eclipse.tools.buckminster#575
) etc.
If I copy these files in to the buckminster headless installation, or try
to specify them on the command line (or even specify them directly in the
rmap file -- in the case of the svn repository) buckminster continually
fails to authenticate. This is true if I use the same workspace as well.
So, it seems that buckminster is not using authentication information for
the proxy, or for subversion repositories, or for general url access (in
the case of the RMAP -- which is in the svn repository).
Hopefully this info will help in diagnosing the problem?
I'm using
* eclipse-SDK-3.4.1-win32.zip
* buckminster.product-1.1.0.r09505.zip
* buckminster.archivedsite-1.1.0.r09636.zip
* org.eclipse.buckminster.subclipse.headless.feature
-- Scott
> -- Scott
>> Hi Scott,
>> Regards,
>> Thomas Hallgren
>>> Hi Thomas,
>>> command:
>>> Thank you,
>>> -- Scott
>>>> Hi Scott,
>>>> Regards,
>>>> Thomas Hallgren
>>>>> run something like:
>>>>> Thanks,
>>>>> -- Scott
Re: Headless buckminster through a proxy server [message #381326 is a reply to message #381088] Tue, 25 November 2008 19:11 Go to previous message
I've figured out workarounds for every issue (as noted in other threads)
except for how to get through a proxy that requires authentication. Is
there any chance this could get fixed? Everything works within eclipse,
but not headlessly.
So, what I'm doing now:
- Initializing buckminster and installing features on a separate computer
that doesn't have to use the proxy, then moving it to the proxied computer
- Using subversive (authentication works for that, but not for subclipse)
- Downloading the rmap manually and modifying the link in the cquery so
that it points to the manually downloaded rmap file (the rmap is the an
svn repository that requires authentication)
But, I cannot get through the proxy when resolving my source code. Until
proxy authentication works, I'm stuck. * sob, sob, :) *
-- Scott
> ) etc.
> I'm using
> -- Scott
>> -- Scott
>>> Hi Scott,
>>> Regards,
>>> Thomas Hallgren
>>>> Hi Thomas,
>>>> command:
>>>> Thank you,
>>>> -- Scott
>>>>> Hi Scott,
>>>>> Regards,
>>>>> Thomas Hallgren
>>>>>> run something like:
>>>>>> Thanks,
>>>>>> -- Scott
Previous Topic:RCP build
Next Topic:How to point BM to a materialized target platform
Current Time: Sun Jul 20 09:38:03 EDT 2025
Powered by FUDForum. Page generated in 0.05036 seconds
