Home » Modeling » OCL » Problem: Cannot find operation
Problem: Cannot find operation [message #38029] Mon, 24 September 2007 12:20 Go to next message
In my ecore file I defined an EClass named ClassA, which has some
EAttributes such as ClassA#weight. I need to call generated getWeight()
method in an OCL expression using a instance of ClassA as the context, for
example "self.getWeight()", but I got an exception saying "Cannot find
operation (getWeight()) for the type (LoaderModel)", however "self.weight"
is no problem.
Can anyone give me some instructions on evaluating methods defined on
context object? thanks in advance.
Hao
Re: Problem: Cannot find operation [message #38060 is a reply to message #38029] Mon, 24 September 2007 12:35 Go to previous messageGo to next message
Hi, Hao,
The "getWeight()" operation is not modeled as an operation in Ecore; it is
purely a figment of the Ecore-to-Java transformation performed by EMF.
You can define an EOperation named "getWeight" in your Ecore model, and the
OCL constraint will be able to call it. EMF is smart enough to realize
that this EOperation corresponds, in the generated code, to the Java
accessor method of your "weight" attribute. This shouldn't be necessary,
though, since OCL can access the property simply by "self.weight" as you
indicated.
Christian
Hao Zhang wrote:
> is no problem.
> Regards,
> Hao
Re: Problem: Cannot find operation [message #38093 is a reply to message #38060] Mon, 24 September 2007 12:59 Go to previous messageGo to next message
Thanks it helps. Actually here is another question about calling user
defined EOperations.
In my ecore file I also defined an EOperation named "validate" which takes a
list as argument:
<eOperations name="validate">
<eParameters name="commodities" upperBound="-1" eType="#//Commodity"/>
</eOperations>
I have problem calling this EOperation in OCL expression:
self.validate(Commodity.allInstances()->asSequence())
I found that "Commodity.allInstances()->asSequence()" returns an ArrayList
instance, so I also suppressed EMF types so that in java interface
corresponding method is defined as following:
public void remove(List<Commodity> commodities);
Yet I always get "(Cannot find operation (validate(Sequence(Commodity))) for
the type (ClassA))" exception. I don't know why OCL can't find the
operation.
BTW, is there any way to get all operations for a specified context object?
"Christian W. Damus" <cdamus@ca.ibm.com>
??????:fd8p0v$8j8$2@build.eclipse.org...
> Hi, Hao,
> the
> indicated.
> Cheers,
> Christian
> Hao Zhang wrote:
>> Hi,
>> for
>> "self.weight"
>> is no problem.
>> Regards,
>> Hao
Re: Problem: Cannot find operation [message #38126 is a reply to message #38093] Mon, 24 September 2007 13:48 Go to previous messageGo to next message
Hi, Hao,
You don't need to worry about the declaration of multiplicity-many
EParameters with the EList<Commodity> type (you don't need to suppress the
EList API).
The original problem that you had is that, because the parameter has
isUnique = true
isOrdered = true
by default (these attributes do not appear in your Ecore snippet), the OCL
type of the parameter is OrderedSet(Commodity), not Sequence(Commodity).
So, do this instead:
self.validate(Commodity.allInstances()->asOrderedSet())
HTH,
Christian
> a list as argument:
> </eOperations>
> for the type (ClassA))" exception. I don't know why OCL can't find the
> operation.
> object?
------8<------
Re: Problem: Cannot find operation [message #38191 is a reply to message #38126] Mon, 24 September 2007 22:39 Go to previous messageGo to next message
It works, thanks a lot!
??????:fd8t8v$jsb$1@build.eclipse.org...
> Hi, Hao,
> EList API).
> isUnique = true
> isOrdered = true
> HTH,
> Christian
>> takes
>> a list as argument:
>> </eOperations>
>> ArrayList
>> operation.
>> object?
> ------8<------
Re: Problem: Cannot find operation [message #38221 is a reply to message #38126] Mon, 24 September 2007 22:44 Go to previous messageGo to next message
Just to satisfy my curiosity, how should I define my ecore file to accept
"asSequence()" parameters in ocl?
e.g., self.validate(Commodity.allInstances()->asSequence())
> Hi, Hao,
> EList API).
> isUnique = true
> isOrdered = true
> HTH,
> Christian
>> takes
>> a list as argument:
>> </eOperations>
>> ArrayList
>> operation.
>> object?
> ------8<------
Re: Problem: Cannot find operation [message #38417 is a reply to message #38221] Tue, 25 September 2007 09:37 Go to previous message
Hi, hao,
EMF's generated Java code uses EList for all collection types. In the Ecore
model, you want to specify an ETypedElement (such as an EParameter) with
multiplicity many (upper bound -1 (unlimited) or greater than 1) and the
isUnique and isOrdered properties set as follows:
Collection Type isUnique isOrdered
Bag N N
Sequence N Y
Set Y N
OrderedSet Y Y
Christian
------8<------
Previous Topic:org.eclipse.ocl.uml.impl.BagTypeImpl not contained in the resource
Next Topic:About OCLFactory Interface
Current Time: Sat Jul 19 20:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.05068 seconds
