Home » Archived » Buckminster » versionConverter for svn component reader
versionConverter for svn component reader [message #379920] Mon, 01 September 2008 16:03 Go to next message
I would like to use the versionConverter to select the requested version of
a buckminster component. We've got the standard svn layout:
* branches
* tags
* trunk
And this the same layout under branches, tags and trunk.
I'm able to retrieve the correct component version stored under the tags
folder using the versionConverter with the type "tag" and the flag
"moduleBeforeTag". But when I use the version converter with the type
"branch" and the same flag "moduleBeforeTag", the component reader tries to
locate the component at the root of the branches folder. Do I have make a
mistake?
Thanks!
Re: versionConverter for svn component reader [message #379927 is a reply to message #379920] Tue, 02 September 2008 03:03 Go to previous messageGo to next message
Hi Fabrice,
The version converter should behave exactly the same for branches and tags when using SVN.
Can you provide some more info? A snippet from you RMAP that shows how the provider is
configured and a DEBUG level log from a resolution attempt would be helpful.
Thomas Hallgren
fabrice macagno wrote:
> Hello,
> * branches
> * tags
> * trunk
> mistake?
> Thanks!
Re: versionConverter for svn component reader [message #380021 is a reply to message #379927] Wed, 03 September 2008 11:07 Go to previous messageGo to next message
Hi, here is a RMAP snippet:
<searchPath name="marny">
<provider readerType="svn" componentTypes="buckminster"
mutable="true" source="true">
<uri format="https://{0}:{1}
@our.svn.fr/repos/trunk/plugins/maya/arnold/{2}?moduleBefore Tag ">
<bc:propertyRef key="svn.login"/>
<bc:propertyRef key="svn.passwd"/>
<bc:propertyRef key="buckminster.component"/>
</uri>
<versionConverter type="branch" versionType="OSGi"/>
</provider>
</searchPath>
And here is the debug level log:
marny:buckminster/[2.27.4,2.27.4]#OSGi: Using resolver rmap
Downloading file:/T:/Temp/our.rmap
marny:buckminster/[2.27.4,2.27.4]#OSGi: Using resource map
marny:buckminster/[2.27.4,2.27.4]#OSGi: Using search path marny
marny:buckminster/[2.27.4,2.27.4]#OSGi: Trying provider svn(https://{0}:
{1}@our.svn.fr/repos/trunk/plugins/maya/arnold/{2}?moduleBef oreTag)
marny:buckminster/[2.27.4,2.27.4]#OSGi: Using version converter branch.
trunk/head will not be considered
marny:buckminster/[2.27.4,2.27.4]#OSGi: branches will be searched
Listing remote folder https://our.svn.fr/repos/branches#HEAD
marny:buckminster/[2.27.4,2.27.4]#OSGi: Rejecting provider svn(https://
{0}:{1}@our.svn.fr/repos/trunk/plugins/maya/arnold/{2}?modul eBeforeTag):
No component match was found
marny:buckminster/[2.27.4,2.27.4]#OSGi: No provider was found that could
resolve the request
ERROR [0001] : No suitable provider for component marny:buckminster/
[2.27.4,2.27.4]#OSGi was found in searchPath marny
ERROR [0001] : Rejecting provider svn(https://{0}:{1}
@our.svn.fr/repos/trunk/plugins/maya/arnold/{2}?moduleBefore Tag): No
I've got a window error message which says:
'Resolving query" has encountered a problem.
Syntax error in version string java-1.4 at position 0:
Not a valid OSGi version
"java-1.4" is a folder at the root of the branches directory (it has
nothing to do with my current project) and I guess it shoudn't be parsed
by the reader.
I have the exact same layout for my project under trunk and branches.
I hope it helps.
Thomas Hallgren <thomas@tada.se>
Re: versionConverter for svn component reader [message #380031 is a reply to message #380021] Thu, 11 September 2008 12:16 Go to previous messageGo to next message
any ideas about my problem?
Thanks!
> </uri>
> </provider>
> </searchPath>
> resolve the request
> by the reader.
> I hope it helps.
Re: versionConverter for svn component reader [message #380033 is a reply to message #380031] Thu, 11 September 2008 12:29 Go to previous messageGo to next message
Hi Fabrice,
This looks like a bug. Apparently the branches folder is searched for versions even when
the moduleBeforeTag is specified. Can you please enter a bugzilla for this? The expected
behavior should be to search for branches/<module>/<version>/<component> and the
versionConverter should only see <version>
Thomas Hallgren
> Thanks!
>> </uri>
>> </provider>
>> </searchPath>
>> resolve the request
>> by the reader.
>> I hope it helps.
>> Thomas Hallgren <thomas@tada.se> ?crivait news:48BCE544.6030804@tada.se:
>>> Hi Fabrice,
>>> tags when using SVN. Can you provide some more info? A snippet from
>>> you RMAP that shows how the provider is configured and a DEBUG level
>>> Regards,
>>> Thomas Hallgren
>>>> Hello,
>>>> version of a buckminster component. We've got the standard svn
>>>> layout: * branches
>>>> * tags
>>>> * trunk
>>>> tags folder using the versionConverter with the type "tag" and the
>>>> flag "moduleBeforeTag". But when I use the version converter with the
>>>> type "branch" and the same flag "moduleBeforeTag", the component
>>>> reader tries to locate the component at the root of the branches
>>>> folder. Do I have make a mistake?
>>>> Thanks!
Re: versionConverter for svn component reader [message #380036 is a reply to message #380033] Thu, 11 September 2008 14:03 Go to previous message
Done:
Bug 247062
Cheers.
Thomas Hallgren wrote:
> Hi Fabrice,
> versions even when the moduleBeforeTag is specified. Can you please enter
> a bugzilla for this? The expected behavior should be to search for
> branches/<module>/<version>/<component> and the versionConverter should
> only see <version>
> Thomas Hallgren
>> Hi,
>> Thanks!
>>> </uri>
>>> </provider>
>>> </searchPath>
>>> resolve the request
>>> by the reader.
>>> I hope it helps.
>>>> Hi Fabrice,
>>>> Regards,
>>>> Thomas Hallgren
>>>>> Hello,
>>>>> layout: * branches
>>>>> * tags
>>>>> * trunk
>>>>> Thanks!
Previous Topic:component type for eclipse projects
Next Topic:CVS component reader changed?
Current Time: Sat Jul 19 17:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.04644 seconds
