Centrally controlling component versions [message #379851] |
Thu, 28 August 2008 11:27  |
I am trying to manage component dependencies and materialization using
Buckminster and while I was declaring dependencies on a component, I
notices that I was continuously copying the same version information to
CSPEC version and and dependency (versionDesignator) nodes.
That prompted me to wonder how the version information is meant to be
used/handled by Buckminster.
If I have to specify version information of all dependencies in all
CSPECs, wouldn't it become rather troublesome to manage later on, when
the whole project moves to new new branch/version.
I would have to remember to (manually) change the version number of the
component and all of the dependency declarations of the dependent
components?
In my use case there is actually 1:1 mapping between version and branch
in source control tree - so that one can be inferred from the other.
So is there a way to infer component version number from the source
control branch defined in CQUERY?
Roland Tepp
Re: Centrally controlling component versions [message #379902 is a reply to message #379857] |
Fri, 29 August 2008 09:59  |
Roland Tepp wrote:
> Aah, so that is what the versionConverter in RMAP was for...
> So in my CQUERY I specify a branch and in RMAP I translate this branch
> to a version number?
No, not really. You either use branches as a non-versioning scheme and rely on that the
components that you find in a branch (or in head/trunk) will provide the version from
meta-data files in some way or another OR you let the branches/tags be the ones that
defines the versions. If you do the latter, Buckminster will scan the branches that are
available and select the best one according to a version designator. In this case, you do
NOT want to specify a branch or tag in the CQUERY.
The branch/tag path in the CQUERY can be used if you want Buckminster to use a specific
branch or tag when resolving. You can enter several comma separated values (hence the term
path) which will cause Buckminster to search them one at a time. The keyword "main" can be
used to denote head/trunk. This approach is particularly useful when you have a number of
components but only a few of them needs to be branched. We use this ourselves since only a
small selection of our plug-ins needs special handling for the differences between Europa
and Ganymede. When working with Europa, we use a CQUERY that first looks in our 3.3.x
branch and then in head, i.e. "3.3.x,head"
> In my component dependencies I do not have to specify an exact version
> number of the component (that will be inferred from the branch)?
> Still, there is the matter of version numbers of the components
> themselves declared in CSPEC - can I omit version information there and
> have it inferred from branch or should I still manage these manually?
Yes, that's possible. You can control all version explicitly using branches. In some cases
that's the simplest thing to do. It all depends on how you want to work :-)
Thomas Hallgren
FUDForum. Page generated in 0.10880 seconds
