Pulling components from CVS branch [message #379839] |
Wed, 27 August 2008 08:26  |
How do I set up an RMap to fetch certain version of the component from a
cvs branch?
I suppose this is something to be specified in url element, but how?
Roland Tepp
Re: Pulling components from CVS branch [message #379846 is a reply to message #379841] |
Thu, 28 August 2008 05:59   |
Like this?
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="path.to.rmap">
<cq:rootRequest name="commons" componentType="buckminster"
versionDesignator="[1.3.2,1.3.2]"
versionType="Triplet"/>
<cq:advisorNode namePattern=".*" branchTagPath="v1_3_2"/>
</cq:componentQuery>
Thomas Hallgren kirjutas mulle midagi seesugust:
> Hi Roland,
> No, you don't specify this in the URL. You specify it using a
> "Branch/Tag path" in the CQUERY advisor node or, if you use branches to
> denote explicit versions, using a version designator in the provider
> element of the RMAP.
> The most common case is to use a CQUERY with one advisor node that
> matches the pattern ".*" (i.e. all components) and in that node, you
> would specify the designated branch under "Selection Criteria" ->
> "Branch/Tag path". In this path tags are preceded with a '/' while
> branches are entered verbatim.
> Regards,
> Thomas Hallgren
> Roland Tepp wrote:
>> Hello,
>> a cvs branch?
Roland Tepp
Re: Pulling components from CVS branch [message #379848 is a reply to message #379846] |
Thu, 28 August 2008 06:37  |
Yes, that looks correct. This will pull things from the v1_3_2 branch.
Thomas Hallgren
Roland Tepp wrote:
> Like this?
> <cq:componentQuery
FUDForum. Page generated in 0.15371 seconds
