Home » Archived » GMT (Generative Modeling Technologies) » [TCS] NPE with TCSSamples
[TCS] NPE with TCSSamples [message #379572] Thu, 13 September 2007 03:28 Go to next message
I've trying to run the TCSSamples from the TCS wiki and
am getting a NPE when the ANTLR.tcs model is being
loaded; details below. I'm using the eclipse 3.3 release
and ATL 2.0RC2 from the ATL update site. From reading
this news group I can see that others are successfully
using TCS to parse their own DSLs. So, does anyone
know why I can't run the sample, or what setup are
those running TCS using?
thanks
Andy.
Buildfile: C:\andy\eclipse\tcs\SampleDSL_InjectorCreation.xml
default:
transfo:
init:
[am3.loadModel] INFO: Loading of model AddressBook.tcs
[am3.loadModel] INFO: Loading of model KM3
[am3.loadModel] INFO: Loading of model AddressBook.km3
[am3.loadModel] INFO: Loading of model ANTLR
[am3.loadModel] INFO: Loading of model ANTLR.tcs
[am3.loadModel] java.lang.NullPointerException
[am3.loadModel] at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:231)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.ASMModelHandler.actualSet(ASMM odelHandler.java:47)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.ASMModelHandler.set(ASMModelHa ndler.java:117)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.set(EBNFInjector 2.java:371)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCS_ANTLR3Parser.classTemplate (TCS_ANTLR3Parser.java:2808)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCS_ANTLR3Parser.template(TCS_ ANTLR3Parser.java:1978)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCS_ANTLR3Parser.concreteSynta x(TCS_ANTLR3Parser.java:1422)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.TCS_ANTLR3Parser.main(TCS_ANTL R3Parser.java:121)
[am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at java.lang.reflect.Method.invoke(Method.java:585)
[am3.loadModel] at
org.eclipse.gmt.tcs.wrappers.antlr3.ParserWrapper.parse(Pars erWrapper.java:69)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:253)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:213)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:162)
[am3.loadModel] at
org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:92)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:256)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:273)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.inject(A M3AntToolKit.java:281)
[am3.loadModel] at
org.eclipse.gmt.am3.tools.ant.tasks.LoadModelTask.execute(Lo adModelTask.java:62)
[am3.loadModel] at
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
Method)
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[am3.loadModel] at org.apache.tools.ant.Task.perform(Task.java:348)
[am3.loadModel] at org.apache.tools.ant.Target.execute(Target.java:357)
[am3.loadModel] at
org.apache.tools.ant.Target.performTasks(Target.java:385)
[am3.loadModel] at
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
[am3.loadModel] at
org.apache.tools.ant.helper.SingleCheckExecutor.executeTarge ts(SingleCheckExecutor.java:38)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.EclipseSingleCheckExecutor .executeTargets(EclipseSingleCheckExecutor.java:30)
[am3.loadModel] at
org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
[am3.loadModel] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
[am3.loadModel] at
org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:105)
[am3.loadModel] at
Method)
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
Method)
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at
org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[am3.loadModel] at
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[am3.loadModel] at
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
[am3.loadModel] at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
Method)
[am3.loadModel] at
[am3.loadModel] at
[am3.loadModel] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:377)
[am3.loadModel] at
org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:230)
[am3.loadModel] at java.lang.Thread.run(Thread.java:595)
[am3.loadModel] INFO: Loading of model Problem
[am3.loadModel] INFO: Loading of model Problem.tcs
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
Re: [TCS] NPE with TCSSamples [message #379576 is a reply to message #379572] Mon, 17 September 2007 12:37 Go to previous message
TCSSamples does not work with ATL 2.0RC2 but with older versions.
A newer version of TCS that works with ATL 2.0RC2 is going to be
published soon.
In the mean time, you can still use an older version of ATL (e.g., from
the CVS).
Frédéric Jouault
> thanks
> Andy.
> default:
> transfo:
> init:
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
Re: [TCS] NPE with TCSSamples [message #607567 is a reply to message #379572] Mon, 17 September 2007 12:37 Go to previous message
published soon.
the CVS).
Frédéric Jouault
> thanks
> Andy.
> default:
> transfo:
> init:
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
> Method)
> [am3.loadModel] at
> [am3.loadModel] at
> [am3.loadModel] at
Previous Topic:[OAW] Running java code from workflow
Next Topic:[MOFScript] parsing EMF UML2 v1.0.0 XMI
Current Time: Sun Jul 20 04:27:07 EDT 2025
Powered by FUDForum. Page generated in 0.03952 seconds
