Home » Archived » Buckminster » Binary projects result in nested jars with PDE build
Binary projects result in nested jars with PDE build [message #378527] Tue, 15 July 2008 05:14 Go to next message
we use BM to materialize bundles into the workspace where they're added
as binary projects. This works fine up to the moment where we feed this
workspace to PDE build to create our product. All binary projects end up
being "normally" packaged by PDE which results in the original jars
nested in newly created jars. Obviously this causes problems at runtime
(RCP doesn't even start).
ATM I see two solutions:
- Do not materialize into the workspace but e.g. site mirror instead.
The site mirror is feed to PDE build via baseLocation and/or pluginPath.
Unfortunately this doesn't work well since not all our bundles originate
from an update site and BM currently doesn't support rules like site
mirror binary projects but materialize source projects to workspace.
- Tell PDE build to not repackage binary projects but simply consume the
original binary bundle. But can a binary project be distinguished from a
source project? To me it seems the only indicator is a nested jar with
the same name as the project.
Any hints are greatly appreciated.
Cheers
Markus
P.S. The reason we don't use BM's product export is because is doesn't
support building for several platforms simultaneously (yet?).
Re: Binary projects result in nested jars with PDE build [message #378531 is a reply to message #378527] Tue, 15 July 2008 06:40 Go to previous messageGo to next message
Hi Markus,
Markus Alexander Kuppe wrote:
Not sure what you mean here. You can always create mspec-nodes for the
binary projects that will redirect them into your target platform if you
like. That should work with both the site.mirror and eclipse.import
reader types.
Buckminster had a bug similar to this a while back but we fixed it so
that the original jars are used in the build. So using the Buckminster
product export would solve this.
> Cheers
> Markus
Not the way you want it I guess. We support platform agnostic builds but
if you want several builds, one for each platform, then you need to
spawn a new buckminster build (with a new output folder) for each platform.
Suggestions on how to improve this are of course very welcome.
Thomas Hallgren
Re: Binary projects result in nested jars with PDE build [message #378533 is a reply to message #378531] Tue, 15 July 2008 07:01 Go to previous messageGo to next message
>> originate from an update site and BM currently doesn't support rules
>> like site mirror binary projects but materialize source projects to
>> workspace.
> reader types.
But doesn't this mean that I have to maintain the mspecs when I add a
new binary bundle?
>> the original binary bundle. But can a binary project be distinguished
>> from a source project? To me it seems the only indicator is a nested
>> jar with the same name as the project.
Yep, Buckminster handles this scenario perfectly. :) Do you happen to
remember the bug. Might be worth to file a similar bug against PDE build.
I'd rather not compile all bundles for each platform over and over
again, just to avoid inconsistencies between the platform builds.
Cheers
Markus
Re: Binary projects result in nested jars with PDE build [message #378535 is a reply to message #378533] Tue, 15 July 2008 08:06 Go to previous messageGo to next message
Never mind, https://bugs.eclipse.org/bugs/show_bug.cgi?id=212411
Re: Binary projects result in nested jars with PDE build [message #378540 is a reply to message #378533] Tue, 15 July 2008 08:58 Go to previous message
> Do you happen to
https://bugs.eclipse.org/240821
Previous Topic:'No component match was found' error - Resolve to Wizard
Next Topic:Product export doesn't run custom build hooks
Current Time: Sat Jul 19 15:25:26 EDT 2025
Powered by FUDForum. Page generated in 0.03256 seconds
