Home » Modeling » MDT (Model Development Tools) » [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
[UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #378094] |
Mon, 03 March 2008 13:16  |
another problem, I want to access the UML_Primitive_Lib, so that I can use
the primitive types as type specification.
I tried like this:
URI primitiveTpyeLibURI =
URI.createURI(XMI2UMLResource.UML_PRIMITIVE_TYPES_LIBRARY_UR I);
Model uml2PrimitiveTypesLibrary =
(Model)UML2Util.load(
RESOURCE_SET,
primitiveTpyeLibURI,
UMLPackage.Literals.MODEL);
actually I've tried with many URIs in different classes, but none of work
seemed to be working(i.e. load() always return null).
--XMI2UMLResource
* UML_PRIMITIVE_TYPES_LIBRARY_2_1_URI
* UML_PRIMITIVE_TYPES_LIBRARY_URI
--UMLResource
--UML22UMLResource
* UML2_PRIMITIVE_TYPES_LIBRARY_URI
Any one has any idea?
best Regards.
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #378121 is a reply to message #378117] |
Tue, 04 March 2008 05:36   |
Hi Kenn,
Thanks for the advice.
Well, it seemed that the URI
"pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml" has to be resolved
manually, otherwise it could not be resolved by EMF. (I always got the
"MalformedURLException")
So I solved the problem like this:
* I extract the "UMLPrimitiveTypes.library.uml" from the JAR file, and
save it in my current project dir.
* and then register the the pathmap-URI with with the physical one(the one
in my project dir), and now I was able to load the primitive type lib and
get the primitive types.
Jinhui
The code looks like this:
ResourceSet RESOURCE_SET = new
RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
RESOURCE_SET.getResourceFactoryRegistry().getExtensionToFact oryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
Map uriMap = RESOURCE_SET.getURIConverter().getURIMap();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml",
new UMLResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",
new XMIResourceFactoryImpl());
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml"),
URI.createFileURI(System.getProperty("user.dir") +
"/Model_Libs/UMLPrimitiveTypes.library.uml"));
Resource resource =
RESOURCE_SET.getResource(URI.createURI(UMLResource.UML_PRIMI TIVE_TYPES_LIBRARY_URI),
true);
Kenn Hussey wrote:
> Jinhui,
> Its sounds like a resource factory has not been registered to hande the URI
> you are trying load. The FAQ entry that I pointed you to shows how to do
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #378126 is a reply to message #378121] |
Tue, 04 March 2008 10:53   |
Jinhui,
What string did you try using for the base JAR URL? I've done this many
times in the past (as per the FAQ) and never had a problem...
Kenn
"Jinhui" <zhuj@in.tum.de> wrote in message
news:0026a798a8951e2cfe35598bcf00db2e$1@www.eclipse.org...
> Hi Kenn,
> So I solved the problem like this: * I extract the
> "UMLPrimitiveTypes.library.uml" from the JAR file, and save it in my
> Jinhui
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*", new
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> URI you are trying load. The FAQ entry that I pointed you to shows how to
>> do this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #489100 is a reply to message #489016] |
Thu, 01 October 2009 09:49  |
Federico,
That was indeed a typo and has now been fixed. Sorry about that.
Kenn
Federico Tomassetti wrote:
> I did as the FAQ indicated but which URI I have to import? import
> org.eclipse.emf.common.util.URI? Because this class have the method
> "createUri" but not the method "create" indicated in the line:
> URI uri = URI.create("
> jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_
> 2.0.0.v200606221411.jar!/ ");
> Is this just a typo and have I to change create in createUri?
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584830 is a reply to message #378094] |
Mon, 03 March 2008 14:12  |
Jinhui,
This is another question for the UML2 newgroup.
Have you read the introductory articles on the UML2 documentation page
(http://wiki.eclipse.org/MDT-UML2#Articles)? They described how to work with
models and profiles both programatically and using the sample editor. I
suspect the problem you are having relates to not registering the pathmaps
for the UML library resources - see the FAQ at
http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
Kenn
"Jinhui " <zhuj@in.tum.de> wrote in message
news:140c994f2ffa8aae6c53eb09bb4b9dc5$1@www.eclipse.org...
> Hello,
> I tried like this:
> RESOURCE_SET,
> --XMI2UMLResource
> --UMLResource
> --UML22UMLResource
> best Regards.
> Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584843 is a reply to message #378108] |
Mon, 03 March 2008 15:54  |
Hi Kenn,
first, sorry for misplacing the message in the MDT group. Newbie!
I tried both the two approaches mentioned in the article, neither worked.
the one as in the Profile-tutorial looks like this:
PrimitiveType primitiveType = importPrimitiveType( "Boolean");
protected static PrimitiveType importPrimitiveType(String name) {
Model umlLibrary =
(Model)load(URI.createURI(UMLResource.UML_PRIMITIVE_TYPES_LI BRARY_URI));
PrimitiveType primitiveType = (PrimitiveType)
umlLibrary.getOwnedType(name);
return primitiveType;
protected static org.eclipse.uml2.uml.Package load(URI uri) {
org.eclipse.uml2.uml.Package package_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true); (****)
package_ =(org.eclipse.uml2.uml.Package)EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
return package_;
I got Exception at (****):
"Cannot create a resource for
'pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml'; a registered
resource factory is needed"
>> I suspect the problem you are having relates to not registering the
pathmaps for the UML library resources
Can you give me more hints on this?
best Regards!
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584858 is a reply to message #378113] |
Mon, 03 March 2008 20:25  |
Jinhui,
this:
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);Kenn
news:902de8df46b383e348d19ed88a7e0b73$1@www.eclipse.org...
> Hi Kenn,
> Model umlLibrary =
> try {
> resource.getContents(), UMLPackage.Literals.PACKAGE); } catch
> return package_;
> best Regards! Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584875 is a reply to message #378117] |
Hi Kenn,
Jinhui
Resource resource =
true);
Kenn Hussey wrote:
> Jinhui,
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584899 is a reply to message #378121] |
Jinhui,
Kenn
> Hi Kenn,
> Jinhui
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> do this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #584914 is a reply to message #378126] |
Tue, 04 March 2008 13:58  |
Hi Kenn,
yes, you're right, after setting the correct base JAR URL, the "FAQ-way"
worked well.
Previously I was wondering, if I could avoid setting it to a specific
directory of mine, because this could be different on others' machine, and
my app is supposed to run on many machines.
regards.
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #593695 is a reply to message #378121] |
Fri, 08 August 2008 11:16  |
Hello there!
I have a problem with the same code, also trying to load resources from
a standalone application.
The code above gives me a
java.lang.ClassCastException:
org.eclipse.uml2.uml.internal.resource.UMLResourceFactoryImp l cannot be
cast to org.eclipse.emf.ecore.resource.Resource$Factory
which seems strange, since UMLResourceFactoryImpl implements
Resource.Factory ...
I use the plugin versions EMF SDK 2.4 (2008/06/09) and UML2 2.1.0
(2008/05/13). Are these incompatible? They are the latest available
versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #593706 is a reply to message #378633] |
Fri, 08 August 2008 14:41  |
UML2 2.2.0 is dependent on EMF 2.4. It looks like you have incompatible
versions.
The download page indicates all the proper depencies ...
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2
- James
"Werner Schindling" <w.schindling@netconomy.et> wrote in message
news:g7ho0p$i4j$1@build.eclipse.org...
> Hello there!
> I have a problem with the same code, also trying to load resources from a
> versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #593737 is a reply to message #378634] |
Mon, 11 August 2008 03:39  |
You were right, my Tomcat used the wrong libs.
Werner
> versions.
> - James
>> Hello there!
>> versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #597787 is a reply to message #378108] |
Thu, 01 October 2009 04:54  |
I did as the FAQ indicated but which URI I have to import? import org.eclipse.emf.common.util.URI? Because this class have the method "createUri" but not the method "create" indicated in the line:
URI uri = URI.create(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 2.0.0.v200606221411.jar!/ ");
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #597792 is a reply to message #597787] |
Federico,
Kenn
Current Time: Sat Jul 19 23:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.06491 seconds
