Home » Archived » GMT (Generative Modeling Technologies) » [oaw] outsourcing of java-extensions in xtend
[oaw] outsourcing of java-extensions in xtend [message #378064] Thu, 31 May 2007 05:59 Go to next message
can anyone tell me if it is possible to outsource the java extensions
within xtend in one xtend-Template and include this by extension e.g.
extension my::javaextensions;
I made this but it does not seem to work. With the extend rules it works
although the editor marks these calls with errors.
I use eclipse 3.3RC1, oaw 4.1.2
Thank you much.
Svenja
Re: [oaw] outsourcing of java-extensions in xtend [message #378071 is a reply to message #378064] Tue, 05 June 2007 04:16 Go to previous messageGo to next message
Hi Svenja,
should be no problem. Just to make sure I understood what you want.
You have one xtend file
----------- "my/javaextensions.ext"
String doStuff(String s) : JAVA org.Stuff.doStuff(java.lang.String);
and another
--------- "my/extensions.ext"
myExtension() : doStuff("foobar");
This works.
sven
Svenja Wendler wrote:
> Thank you much.
> Svenja
Re: [oaw] outsourcing of java-extensions in xtend [message #378103 is a reply to message #378071] Tue, 12 June 2007 05:42 Go to previous messageGo to next message
Yes this was what I wanted but it did not work that way. I have now a
workaround:
I call the java ext in that javautils.ext like
myjavautils.ext
String function (String s) :
JAVA de.mypackage.JavaUtils.function (java.lang.String);
String func (String s) :
function(s);
These extensions are available in my other extends. Maybe it depends on my
eclipse configuration.
Svenja
Re: [oaw] outsourcing of java-extensions in xtend [message #378105 is a reply to message #378103] Tue, 12 June 2007 09:36 Go to previous message
I found my problem. I declarated the java-extensions private ;(. Now it
works fine ;)
Re: [oaw] outsourcing of java-extensions in xtend [message #601640 is a reply to message #378064] Tue, 05 June 2007 04:16 Go to previous message
Hi Svenja,
and another
This works.
sven
> Thank you much.
> Svenja
Re: [oaw] outsourcing of java-extensions in xtend [message #601752 is a reply to message #378071] Tue, 12 June 2007 05:42 Go to previous message
workaround:
myjavautils.ext
function(s);
Svenja
Re: [oaw] outsourcing of java-extensions in xtend [message #601760 is a reply to message #378103] Tue, 12 June 2007 09:36 Go to previous message
works fine ;)
Previous Topic:oA Workflow versus ant
Next Topic:[TCS] Case sensitive keywords
Current Time: Sun Jul 20 03:25:01 EDT 2025
Powered by FUDForum. Page generated in 0.06774 seconds
