[MOFScript] eAnnotations-question [message #378057] |
Sun, 27 May 2007 17:07  |
Originally posted by: chhirsch.rumms.uni-mannheim.de
Hi everybody,
i am trying to access the following eAnnotations - entry of a UML2 Model
using MOFScript.
<transition xmi:id="_HBYoxP5OEdut2qo8JgL_7Q" name="OVERVIEW"
target="_HBO3i_5OEdut2qo8JgL_7Q" source="_HBO3gv5OEdut2qo8JgL_7Q">
<eAnnotations xmi:id="_HBYoxf5OEdut2qo8JgL_7Q" source="abstract">
<details xmi:id="_HBYoxv5OEdut2qo8JgL_7Q" key="type"
value="Transition"/>
<details xmi:id="_HBYox_5OEdut2qo8JgL_7Q" key="stereotype"
value="State Transition"/>
<details xmi:id="_HBYoyP5OEdut2qo8JgL_7Q" key="bendpoints"
value="1"/>
</eAnnotations>
</transition>
I tried the following transformation:
texttransformation ExampleTransformation (in
uml:"http://www.eclipse.org/uml2/2.0.0/UML") {
uml.Transition::main () {
self.eAnnotations->forEach(annot:uml.EAnnotation){
//do something
This results in the following error message:
Error: MTTParseError: Type not found: 'EAnnotation' in metamodel 'uml',
line: 0, column: 0
Is there any way in MOFScript to access the eAnnotations content?
Any help is appreciated.
Greetings,
Christian
Re: [MOFScript] eAnnotations-question [message #378131 is a reply to message #378057] |
Wed, 13 June 2007 15:27  |
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
Christian,
We found similar obstacle.
We believe this happens, because the .ecore metamodel
is not taken into consideration by MOFscript,
when just indicating as input a .uml model..
Therfore, MOFscript does not consider that the UML elements,
are also ecore elements, and therefore have eAnnotations.
By explicitely including the ecore metamodel as an input parameter,
MOFscript will "find" the eAnnotations.
The hassle is that when you run the transformation,
MOFscript launcher will ask you for an input model
(to serve as the ec: parameter),
but you can simply provide the every same .uml input model,
it doesn
Re: [MOFScript] eAnnotations-question [message #601839 is a reply to message #378057] |
Christian,
it doesn
FUDForum. Page generated in 0.04317 seconds
