Home » Archived » XML Schema Definition (XSD) » Moving components from one XSD schema to another Ctd
Moving components from one XSD schema to another Ctd [message #37753] Thu, 04 March 2004 08:08 Go to next message
I need to merge one XSD schema into another XSD Schema. I wrote code to do
this that works in the case that 1 schema includes the other schema -
works fantastically using the help that you gave me on July 31 2003:
You suggested: You can only merge included schemas into a single schema
since imports imply a
different namespace and each different target namespace will require a
different schema document to be defined. If you want something to be
contained by a particular schema you would add it to the list returned by
xsdSchema.getContents(); adding it to a new container will remove it from
its
old container automatically.
However, I now have a problem when the first schema imports the second
schema. The problem is how Eclipse manages the namespace when an object is
moved from one schema to another. In my example, I have an element in
schema A, which is of type CT which is imported from schema B. When I add
the objects from the imported schema (B) to the main schema, the namespace
is lost - which is great since I want one big schema. However, the element
in A that references that complex type that was in B but is now in A
refers to it with the namespace prefix. I would have expected that the
dependency mechanism of Eclipse model would have updated the referring
element's reference before moving the complex type- this does not seem to
be happening.
In order to see what I mean try using the 2 xsds samples that come with
XML Spy - OrgChart.xsd and Address.xsd. OrgChart.xsd imports address.xsd
and when I do orgChart.getContents().add(addressComplexType). When I try
to parse this new merged schema after saving the merged to disk, I get the
following error:
XSD: Type reference 'http://www.altova.com/IPO#US-Address' is unresolved.
Here is a snippet of my merged schema:
<xsd:complexType name="OfficeType">
<xsd:sequence>
<xsd:element ref="Name"/>
<xsd:element ref="Desc"/>
<xsd:element name="Address" type="ipo:US-Address"/>
<xsd:element name="Phone" type="xsd:string"/>
<xsd:element name="Fax" type="xsd:string"/>
Note that the complex type US-Address is no longer in namespace ipo but
the element reference thinks that it is.
Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #37786 is a reply to message #37753] Thu, 04 March 2004 08:47 Go to previous messageGo to next message
Hayen,
Have you tried calling updateElement on the schema at the end?
Hayden Marchant wrote:
> its
> be happening.
> following error:
> <xsd:sequence>
> Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #37849 is a reply to message #37786] Thu, 04 March 2004 10:20 Go to previous messageGo to next message
This didn't seem to change anything. I take it that updateElement is a
recursive method and that it would go down the whole tree and call
updateElement on each member? Is there anyway I can make sure that this is
happening.
Ed Merks wrote:
> Hayen,
> > Hi,
> > its
> > be happening.
> > following error:
> > <xsd:sequence>
> > Thanks,
> > Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #37882 is a reply to message #37849] Thu, 04 March 2004 11:45 Go to previous messageGo to next message
Hayden,
Maybe/probably if you do xsdSchema.setIncrementalUpdate(false), make your changes
to it, and then call updateElement, it will work; you can set it back to true
after. (I suspect that the incremental updates are re-resolving the names as
specific in the DOM.)
> happening.
> Thanks
> Ed Merks wrote:
> > Hayen,
> > > Hi,
> > > its
> > > be happening.
> > > following error:
> > > <xsd:sequence>
> > > Thanks,
> > > Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #38024 is a reply to message #37882] Mon, 08 March 2004 02:57 Go to previous message
Thanks - it worked!!!
Ed Merks wrote:
> Hayden,
changes
> > happening.
> > Thanks
> > Ed Merks wrote:
> > > Hayen,
> > > > Hi,
to do
by
from
> > > > its
object is
add
namespace
element
seem to
> > > > be happening.
address.xsd
try
the
> > > > following error:
unresolved.
> > > > <xsd:sequence>
> > > > Thanks,
> > > > Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #583687 is a reply to message #37753] Thu, 04 March 2004 08:47 Go to previous message
Hayen,
> its
> be happening.
> following error:
> <xsd:sequence>
> Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #583710 is a reply to message #37786] Thu, 04 March 2004 10:20 Go to previous message
happening.
Ed Merks wrote:
> Hayen,
> > Hi,
> > its
> > be happening.
> > following error:
> > <xsd:sequence>
> > Thanks,
> > Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #583726 is a reply to message #37849] Thu, 04 March 2004 11:45 Go to previous message
Hayden,
> happening.
> Thanks
> Ed Merks wrote:
> > Hayen,
> > > Hi,
> > > its
> > > be happening.
> > > following error:
> > > <xsd:sequence>
> > > Thanks,
> > > Hayden Marchant
Re: Moving components from one XSD schema to another Ctd [message #583814 is a reply to message #37882] Mon, 08 March 2004 02:57 Go to previous message
Ed Merks wrote:
> Hayden,
changes
> > happening.
> > Thanks
> > Ed Merks wrote:
> > > Hayen,
> > > > Hi,
to do
by
from
> > > > its
object is
add
namespace
element
seem to
> > > > be happening.
address.xsd
try
the
> > > > following error:
unresolved.
> > > > <xsd:sequence>
> > > > Thanks,
> > > > Hayden Marchant
Previous Topic:Any tools for reducing a schema?
Next Topic:Problem Including schemas
Current Time: Sat Jul 19 14:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.05371 seconds
