Home » Eclipse Projects » Remote Application Platform (RAP) » Problems with listeners in M5
Problems with listeners in M5 [message #37758] Mon, 16 July 2007 05:47 Go to next message
Originally posted by: gschmoe.salomon.at
Hi!
I have updated my project with RAP M5 today and now I have some problems
with event handling. For instance, focus lost events and table selection
events are not delivered anymore... Last week (with CVS version from
Monday), however, it was working nicely!
Is there any change in the usage of these events or could that be a
side-effect of other enhancements in M5?
Gernot
Re: Problems with listeners in M5 [message #38365 is a reply to message #37758] Tue, 17 July 2007 02:53 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Gernot,
please see my comments below.
Rüdiger
Gernot Sch. wrote:
> Hi!
I encountered the same problem with focus events, but I couldn't
reproduce it. It occurred that there was a Display with client-side id "w2".
Can you reproduce the reported behavior and - if this is the case -
provide a standalone code snippet?
The "outside" usage of events hasn't changed, this must be a side-effect
of changes towards M5.
> Gernot
Re: Problems with listeners in M5 [message #39023 is a reply to message #37758] Tue, 17 July 2007 10:08 Go to previous messageGo to next message
Hi Gernot,
I can now reliably reproduce the behavior, so this shouldn't be too far
from a solution...
Rüdiger
Gernot Sch. wrote:
> Hi!
> Gernot
Re: Problems with listeners in M5 [message #39051 is a reply to message #39023] Tue, 17 July 2007 10:25 Go to previous messageGo to next message
Hi Rüdiger!
Oh, that sounds good! I noticed that if I start my application and I
connect with the first client (first session), this problem occurs. If I
reload and connect again (second session), then everything works nicely as
before...
Could it be some initialization problem..?!?
Ciao,
Gernot
Rüdiger Herrmann wrote:
> Hi Gernot,
> from a solution...
> Cheers,
> Rüdiger
> Gernot Sch. wrote:
>> Hi!
>> Thanks,
>> Gernot
Re: Problems with listeners in M5 [message #39296 is a reply to message #39051] Tue, 17 July 2007 15:45 Go to previous messageGo to next message
Hi Gernot,
some parts of RAP rely on the fact that the Display has a client-side Id
of 'w1'. Under some circumstances this wasn't the case anymore. This is
why some events weren't delivered.
I just committed a fix to CVS HEAD that solves the problem. It would be
nice if you could verify that your problem is actually solved and give
feedback if not.
Rüdiger
Gernot Sch. wrote:
> Hi Rüdiger!
> as before...
> Ciao,
> Gernot
>> Hi Gernot,
>> far from a solution...
>> Cheers,
>> Rüdiger
>> Gernot Sch. wrote:
>>> Hi!
>>> problems with event handling. For instance, focus lost events and
>>> table selection events are not delivered anymore... Last week (with
>>> CVS version from Monday), however, it was working nicely!
>>> Thanks,
>>> Gernot
Re: Problems with listeners in M5 [message #39387 is a reply to message #39296] Wed, 18 July 2007 03:05 Go to previous message
Hi Rüdiger!
Thanks for the fix! I can confirm that the events for my text fields
(focus lost, etc.) are now working again.
I still have a problem receiving selection events from my table, but I
need to debug it in detail. This might be also my mistake...
Ciao,
Gernot
> Hi Gernot,
> feedback if not.
> Cheers,
> Rüdiger
> Gernot Sch. wrote:
>> Hi Rüdiger!
>> as before...
>> Ciao,
>> Gernot
Previous Topic:Image and Text on the same index in a table item not working since M5
Next Topic:LCA for your custom widget
Current Time: Sun Jul 20 15:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.30798 seconds
