Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [Ann] SWTSwing Release 0.0011 is out!
| [Ann] SWTSwing Release 0.0011 is out! [message #375460] |
Wed, 15 October 2003 14:15  |
Hi all,
Some news of SWTSwing, the port of SWT to Swing!
-- Release 0.0011 is out --
There is more work on SWTSwing. Many threading (freezing) issues are
corrected, as well as some scroll pane problems.
The developpers of iRATE (http://irate.sourceforge.net) are thinking about
using SWTSwing! They currently maintain a Swing implementation in addition
to the SWT one. I worked with them to solve most of the SWTSwing issues and
now iRATE runs pretty well with it!
* What is SWTSwing:
This port replaces the native libraries by Swing, which will allow to use
Swing components in SWT implementations and vice-versa, and also allows SWT
applications to run on non-supported configurations (as long as they have
JRE 1.4 installed).
It consists in "swt.jar" that you place instead of the environment specific
one.
It works for some basic applications, but still needs some work. Do not
expect it to work on too complex applications for now.
Website: http://chrriis.brainlex.com/projects/swtswing
* Download:
SWTSwing is here: http://sourceforge.net/projects/swtswing
The site proposes to dowload:
- swt.zip: contains the library "swt.jar"
- swtsrc.zip: contains the sources of the library "swt.jar"
- swttest.zip: contains the "swt.jar" test suite, based on the Eclipse code
snippets. Useful for any SWT port developper.
- swttestsrc.zip: contains the sources of the "swt.jar" test suite.
* Changes in Release 0.0011:
- Tool items fire events.
- Tool items RADIO and CHECK style are working correctly.
- Disposing a component removes it from the parent.
- Table in scroll pane is modified to work correctly.
- Adding a column to a table shifts data correctly.
- Setting the selection of a text field is added.
- Attempt to speed up the event queue.
- Caret positioning for text fields implemented.
- Text field support the echo character, which makes it a password field.
- Disposing a window was not done in proper thread.
- Hiding a window no longer tries to set some Windows specific flags.
- Deffered events are not executed in the event thread anymore.
- Events are sent outside the GUI thread, except if it is the Close event.
- Running deferred events is done also before dispatching GUI stuff.
- Adding a column does not lose previously defined widths.
- Table background is now the same as the cells background.
- Toolbars support flat style for some components.
- Arm event is sent for menu items when mouse is over.
- Drop down style for tool items is working better.
- Some code added to try to avoid some thread concurrency problem.
* Some important issues:
- Some exceptions occur but they do not generate any problem. Still, I will
correct it in the future.
- Image handling is basic, just for me to continue overall development. This
is not a final implementation and will probably need complete replacement.
- Code quality is not yet the best, as I type directly in the windows port.
Anyway, it is improving as the development progresses.
* Contributions:
I welcome any good developers willing to help. Just send me an e-mail!
Have fun!
-Christopher
chrriis@brainlex.com
| Re: [Ann] SWTSwing Release 0.0011 is out! [message #375520 is a reply to message #375460] |
Fri, 17 October 2003 05:57   |
Hey,
Congrats for the release and keep up the good work!
FYI, another project that does just the opposite of yours; GPL (as of yet),
unfortunately:
http://sourceforge.net/projects/swingwt/
"Christopher Deckers" <chrriis@brainlex.com> wrote in message
news:bmk2og$q01$1@eclipse.org...
> Hi all,
and
> * What is SWTSwing:
SWT
> JRE 1.4 installed).
specific
> one.
> * Download:
code
will
This
port.
> * Contributions:
> Have fun!
> -Christopher
| Re: [Ann] SWTSwing Release 0.0011 is out! [message #375725 is a reply to message #375695] |
Fri, 17 October 2003 16:05   |
You think ant is really that great?
If so, i'll probabely try it.
Actually I'm still using Makefiles (handwritten ;-)) and shellscripts
(together with a gcc/gcj compiler cache of course) for building
Never got convinced enough of ant to try it.
Peschmä
Am Fri, 17 Oct 2003 19:33:32 +0300 schrieb Ivan Markov:
> As a matter of fact, I would. :-)
> If only I had a bit of free time, I would delegate it to Ant cpptasks.
> Using Ant + the <cc> task to compile C/C++ projects is soo much easier
> than the regular GNU autoconf mess (SWT/Fox's native part initialy used
> autoconf), that I would be very excited to see the <cc> task stabilized
> and part of Ant's standard distribution.
> But I think I'm way off-topic already.
> /Ivan
> news:bmp37v$70t$1@eclipse.org...
>> Yes, I know what you mean. Skilled people are hard to find, especially
>> to work on a project they did not start :)
>> Would you join someone else's project? Would I? I am so busy with all my
>> past/present/future projects that I guess I could not. Most of the
>> skilled programmers have their heads full of projects already!
>> -Christopher
>> "Ivan Markov" <ivanm@wizcom.bg> a écrit dans le message news:
>> bmp2uc$6lg$1@eclipse.org...
>> > For several months (since the beginning of the summer) I do not have
> much
>> > time either, which is pretty unfortunate, as I am confident SWT/Fox
>> > does have its place..
>> > The really bad thing is that there are no people among the potential
> users
>> > that have the required skills and that would like to delve into the
>> > code
>> and
>> > fix stuff..
>> > /Ivan
>> > news:bmp23p$5o1$1@eclipse.org...
>> > > Hi Ivan,
>> > > I heard about the SwingWT project some time ago, but it is nice to
>> remind
>> > me
>> > > of its existence.
>> > > I personaly like the idea of Swing over SWT, but I feel that all the
>> bugs
>> > of
>> > > Swing should not be transposed.
>> > > It would be a good oportunity to re-create a good Swing like layer
>> > > but
> a
>> > > cleaner one. Swing has a certain history, and some of its API is or
>> should
>> > > be deprecated.
>> > > For my SWTSwing port, I do not have much time so it does not move
>> forward
>> > so
>> > > fast. Hopefully one day I will reach the Fox port maturity :)
>> > > -Christopher
>> > > bmoe9l$hei$1@eclipse.org...
>> > > > Hey,
> of
>> > > yet),
>> > > > unfortunately:
>> > > > > Hi all,
> are
>> > > > > corrected, as well as some scroll pane problems. The developpers
> thinking
>> > > about
>> > > > > in
>> > > addition
>> > issues
>> > > > and
>> > > > > * What is SWTSwing:
>> > > > > allow
>> to
>> > > use
>> > allows
>> > > > SWT
> they
>> > > have
>> > > > > JRE 1.4 installed).
>> > > > > environment
>> > > > specific
>> > > > > one.
> Do
>> > not
>> > > > > expect it to work on too complex applications for now. Website:
>> > > > > * Download:
>> > > > > SWTSwing is here: http://sourceforge.net/projects/swtswing The
>> > > > > - swt.zip: contains the library "swt.jar" - swtsrc.zip: contains
>> > > > > the sources of the library "swt.jar" - swttest.zip: contains the
>> Eclipse
>> > > > code
>> > > > > snippets. Useful for any SWT port developper. - swttestsrc.zip:
> suite.
>> > > > > - Tool items RADIO and CHECK style are working correctly. -
>> > > > > Disposing a component removes it from the parent. - Table in
>> > > > > scroll pane is modified to work correctly. - Adding a column to
>> > > > > a table shifts data correctly. - Setting the selection of a text
>> > > > > field is added. - Attempt to speed up the event queue. - Caret
>> > > > > positioning for text fields implemented. - Text field support
>> > > field.
>> > > > > - Disposing a window was not done in proper thread. - Hiding a
>> flags.
> Close
>> > > event.
> stuff.
>> > > > > - Adding a column does not lose previously defined widths. -
>> > > > > Table background is now the same as the cells background. -
>> > > > > Toolbars support flat style for some components. - Arm event is
>> > > > > sent for menu items when mouse is over. - Drop down style for
>> > > > > tool items is working better. - Some code added to try to avoid
> Still,
>> I
>> > > > will
>> > development.
>> > > > This
>> > > replacement.
>> windows
>> > > > port.
>> > > > > * Contributions:
>> e-mail!
>> > > > > Have fun!
>> > > > > -Christopher
| Re: [Ann] SWTSwing Release 0.0011 is out! [message #375783 is a reply to message #375736] |
Sat, 18 October 2003 10:02   |
Yes,
but (if i don't mix things up) Swingwt actually uses SWT Button to create
a JButton. So it is not just replacing AWT with SWT but rather replacing
AWT+Swing with SWT. (Which would be really desirable)
Or am I wrong there?
Peschmä
Am Sat, 18 Oct 2003 16:42:04 +0300 schrieb Christopher Deckers:
> Actually, it can work. If you think about Swing, it is a layer on top of
> AWT, which cannot provide HTML.
> The basic idea is that the top containers are AWT containers, and
> everything is painted inside by Swing. Whether it is SWT or AWT that
> provides the top containers does not make much difference since everything
> will be painted.
> To me, SWT provides everything hat AWT provides, but adds emulated
> widgets as well as operating system specific capabilities. So everything
> using AWT could use SWT, including Swing.
> -Christopher
> "Simon Rutishauser" <simon.rutishauser@gmx.ch> a écrit dans le message
> news: pan.2003.10.17.20.03.44.334675@gmx.ch...
>> Am Fri, 17 Oct 2003 12:57:03 +0300 schrieb Ivan Markov:
>> > yet), unfortunately:
>> Unfortunately a complete Swing on SWT is imho quite impossible. Too many
>> programs rely on functionality that cannot be provided by SWT.
>> My favourite sample: Lots of programs rely on the HTML-formatting
>> capabilities Swing provides for _every_ widget. You can display a
>> complete HTML file in a label. (Of course it has to be html 3.2 with...)
>> So it will be: Programs written _for_ Swingwt will also work on "normal"
>> Swing, not the desirable opposite...
>> Peschmä
Current Time: Sun Nov 02 03:16:17 EST 2025
Powered by FUDForum. Page generated in 0.05555 seconds
