Home » Archived » Service Oriented Architecture Tools Platform (STP) » Problems integrating the bpmn modelerinto my RCP Plugin Project
Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374796] Thu, 21 August 2008 04:08 Go to next message
Originally posted by: dali.xxxx.com
Hello Everybody,
i'm trying to integrate the bpmn modeler into my RCP plugin project.
my problem is that when i call the bpmn editor from my main class :
page.openEditor(new myeditinput("name"),BpmnEditor.ID,true);
it through a core exception :
org.eclipse.core.runtime.CoreException: ERROR
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:25)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2327)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at ekipbpmodeler.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
i read a recent topic that tells that it's possible to integrate it into
RCP.
Please Help,
Best Regards,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374797 is a reply to message #374796] Thu, 21 August 2008 05:34 Go to previous messageGo to next message
Hi Dali,
It is possible to integrate it into a RCP application. I'm doing it
right now right here ;)
Would be nice to know what kind of Input you pass to the openEditor
method. I had a bug with the editor not opening when I try to open a
diagram which wasn't in a project in the workspace.
Greets
Dali schrieb:
> Hello Everybody,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> RCP.
> Please Help,
> Best Regards,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374798 is a reply to message #374797] Thu, 21 August 2008 05:58 Go to previous messageGo to next message
Hi Till ,
what a nice coincidence.
i'm passing an IEditorInput to the openEditor Method.
Thanks for feedback.
Best Regards,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374799 is a reply to message #374798] Thu, 21 August 2008 06:13 Go to previous messageGo to next message
Hi Till ,
i forget to tell you that my current need is to open a blank bpmn editor
with a palette so i can design my process.
so what kind of inputs should i pass to the openEditor Method.
Best Regards ,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374800 is a reply to message #374799] Thu, 21 August 2008 10:53 Go to previous messageGo to next message
Hi everybody ,
i'm still trying to integrate the bpmn modeler into my RCP Plugin project.
my question is it necessary that the editor input be based on an IFile.
please help me fixing this bug when i'm calling the editor :
IWorkspaceRoot myWorkspaceRoot = ResourcesPlugin.getWorkspace().getRoot();
IProject myWebProject =
myWorkspaceRoot.getProject("EkipBPModeler");
IFolder bpmnFolder = myWebProject.getFolder("BpmnFiles");
IFile file = bpmnFolder.getFile("test.bpmn_diagram");
FileEditorInput fileEditorInput = new FileEditorInput(file);
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
page.openEditor(fileEditorInput,BpmnEditor.ID,true);
I obtain this exception :
!STACK 1
org.eclipse.core.runtime.CoreException: Resource
'/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:219)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:145)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContentFromStora ge(FileDiagramDocumentProvider.java:154)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.setDocumentContent(StorageDocum entProvider.java:152)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContent(FileDiag ramDocumentProvider.java:273)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.createDocument(StorageDocumentP rovider.java:76)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:476)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.connect(AbstractDocumentProvider.j ava:387)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:42 6)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:638)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:44)
at
at
at
at
at
at
at
org.eclipse.core.runtime.CoreException[1]:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:199)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(URIConverterImpl.java:540)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:449)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:897)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil$FileLoader.load(DiagramIOUtil.java:83)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource
at
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
at
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:285)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:276)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:195)
... 68 more
!SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1
2008-08-21 16:52:49.642
!MESSAGE Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!ENTRY org.eclipse.ui 4 0 2008-08-21 16:52:49.658
!MESSAGE org.eclipse.gef.DefaultEditDomain
!STACK 0
java.lang.ClassCastException: org.eclipse.gef.DefaultEditDomain
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getDi agramEditDomain(DiagramEditor.java:576)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getAc tionManager(DiagramEditor.java:1027)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getOp erationHistory(DiagramEditor.java:1050)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.stopL istening(DiagramEditor.java:997)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.stopListening(DiagramEditorWithFlyOutPalette.jav a:585)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.setIn put(DiagramEditor.java:914)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.dispose(DiagramDocumentEditor.java:179)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.dispose( BpmnDiagramEditor.java:149)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:689)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE Unable to create editor ID ekipbpmodeler.BpmnEditor: An exception
was thrown during initialization
!STACK 0
at
org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(TransactionUtil.java:50)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .DiagramModificationListener. <init>(DiagramModificationListener.java:55)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramModificationListener. <init>(FileDiagramModificationListener.java:54)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider$Custo mModificationListener. <init>(BpmnDocumentProvider.java:164)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider.creat eFileInfo(BpmnDocumentProvider.java:114)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:486)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanx for help,
Best regards ,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374801 is a reply to message #374800] Thu, 21 August 2008 11:22 Go to previous messageGo to next message
Hi Dali,
Test if your project exists and is open
if(myWebProject.exists() && myWebProject.isOpen())
The only reason I see is, that ... yeah, the file doesn't exist.
The methods like getProject, getFolder etc. doesn't test if the
requested resources are present, they only give you a link. The first
"test" of the resource is made when the editor is opened.
Greets
Till
Dali schrieb:
> Hi everybody ,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception was thrown during initialization
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374804 is a reply to message #374801] Fri, 22 August 2008 05:04 Go to previous messageGo to next message
Hi till,
yeah the myWebProject.exists() return false .
why the workbench is can not localise it.
how can i debug this.
Best Regards ,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374805 is a reply to message #374804] Fri, 22 August 2008 05:09 Go to previous messageGo to next message
Hi Dali,
I don't know how you created your project inside the workbench, but try
to create a new from sourcecode:
myWebProject.create(null);
myWebProject.open(null);
Greets,
Till
Dali schrieb:
> Hi till,
> Best Regards ,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374806 is a reply to message #374805] Fri, 22 August 2008 05:24 Go to previous messageGo to next message
Hi till ,
i create the project from
file->newProject->PluginDevelopment->Pluginproject.
i tryed to create it from code but it still through me this exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:56)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
2008-08-22 11:17:38.074
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:38.105
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2008-08-22 11:17:58.185
!MESSAGE The proxied handler for
'org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplica teActionDelegate'
could not be loaded
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:58.185
could not be loaded
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.gmf.runtime.diagram.ui was unable to load class
org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplicat eActionDelegate.
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(Ha ndlerProxy.java:293)
at
org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(Hand lerProxy.java:262)
at org.eclipse.core.commands.Command.isEnabled(Command.java:831 )
at org.eclipse.core.commands.Command.setHandler(Command.java:93 8)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.updateComm and(HandlerAuthority.java:535)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.deactivate Handler(HandlerAuthority.java:256)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndler(HandlerService.java:144)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndlers(HandlerService.java:153)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.clearAct ivations(HandlerPersistence.java:101)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.dispose( HandlerPersistence.java:107)
at
org.eclipse.ui.internal.handlers.HandlerService.dispose(Hand lerService.java:159)
at
org.eclipse.ui.internal.services.ServiceLocator.dispose(Serv iceLocator.java:95)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:27 30)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 17)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 34)
at org.eclipse.ui.internal.Workbench$22.run(Workbench.java:1078 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1076)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1048)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:696)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:675)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:790)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:788)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:736)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 2)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:91)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:301)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1621)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3674 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:291)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1554)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1753)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2260 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:456)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at
at
at
at
at
at
at
java.lang.ClassNotFoundException:
at java.lang.ClassLoader.findClass(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-08-22 11:17:58.185
!MESSAGE Plug-in org.eclipse.gmf.runtime.diagram.ui was unable to load
class
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374809 is a reply to message #374806] Fri, 22 August 2008 06:35 Go to previous messageGo to next message
Hi till ,
nothing to do ! it's still the same exception :(
can u please give me a fever bysending me your RCP project into my email:
friaa.dali@gmail.com so i can debug my app .
Best Reagards,
dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374810 is a reply to message #374806] Fri, 22 August 2008 10:59 Go to previous messageGo to next message
1. Step: Look into your run dialog where your workspace is.
2. Step: Check if your project/folder/file is located in there.
2.1 : If not, create a project from source code (to be sure it IS there)
2.2 : Move the diagram file into the project and try opening it.
What you discover is not a problem with the modeler itself, but your
runtime ;)
Greets
Till
Dali schrieb:
> Hi till ,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> could not be loaded
> could not be loaded
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374811 is a reply to message #374809] Fri, 22 August 2008 11:01 Go to previous message
Due to the copyright... I'm sorry, I can't.
Dali schrieb:
> Hi till ,
> email: friaa.dali@gmail.com so i can debug my app .
> Best Reagards,
> dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618482 is a reply to message #374796] Thu, 21 August 2008 05:34 Go to previous message
Hi Dali,
Greets
Dali schrieb:
> Hello Everybody,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> RCP.
> Please Help,
> Best Regards,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618485 is a reply to message #374797] Thu, 21 August 2008 05:58 Go to previous message
Hi Till ,
Best Regards,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618490 is a reply to message #374798] Thu, 21 August 2008 06:13 Go to previous message
Hi Till ,
Best Regards ,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618493 is a reply to message #374799] Thu, 21 August 2008 10:53 Go to previous message
Hi everybody ,
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanx for help,
Best regards ,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618496 is a reply to message #374800] Thu, 21 August 2008 11:22 Go to previous message
Hi Dali,
Greets
Till
Dali schrieb:
> Hi everybody ,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618505 is a reply to message #374801] Fri, 22 August 2008 05:04 Go to previous message
Hi till,
Best Regards ,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618507 is a reply to message #374804] Fri, 22 August 2008 05:09 Go to previous message
Hi Dali,
Greets,
Till
Dali schrieb:
> Hi till,
> Best Regards ,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618511 is a reply to message #374805] Fri, 22 August 2008 05:24 Go to previous message
Hi till ,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
could not be loaded
could not be loaded
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
class
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618514 is a reply to message #374806] Fri, 22 August 2008 06:35 Go to previous message
Hi till ,
Best Reagards,
dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618517 is a reply to message #374806] Fri, 22 August 2008 10:59 Go to previous message
runtime ;)
Greets
Till
Dali schrieb:
> Hi till ,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> could not be loaded
> could not be loaded
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618519 is a reply to message #374809] Fri, 22 August 2008 11:01 Go to previous message
Dali schrieb:
> Hi till ,
> Best Reagards,
> dali
Previous Topic:Problem under Ganymede
Next Topic:About the property tab of BPMN
Current Time: Sat Jul 19 22:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.32514 seconds
