Home » Archived » Service Oriented Architecture Tools Platform (STP) » Problems Installing STP/SCA and GMF
Problems Installing STP/SCA and GMF [message #374595] Mon, 10 March 2008 10:53 Go to next message
for the EILF project we would like to evaluate the usage of STP/SCA.
I was trying to follow the tutorial "First Steps with the SCA Composite
Designer", but failed during Installation of STP/SCA.
I downloaded and installed "Consolidated requirements zip" (without
eclipse) from
http://download.eclipse.org/modeling/gmf/downloads/drops/R-2 .0.1-200709280000/index.php
Then I downloaded and installed SCACompositeDesigner_0.8.0.200803041719.zip
After restarting eclipse, I did not find the new creation wizards as
described in the tutorial.
There is only File -> New -> Other -> Other -> Composite Model available.
Then I checked the eclipse Product Configuration:
- STP/SCA is not listed as installed plugin
- GMF Base 1.0.0 reports errors in GEF SDK 3.3.1:
No plug-in: "org.eclipse.gef" included at runtime.
Does anybody have any idea what is wrong with my installation ? I'm using
eclipse version 3.3.0.
After that, I downloaded GMF-baseplatform-2.0.1-win32.win32.x86.zip
(including eclipse 3.3.1) and installed STP/SCA.
- no more errors regarding GMF or GEF
Again, there is only a wizard for File -> New -> Other -> Other ->
Help is most welcome.
Bye,
Daniel
Re: Problems Installing STP/SCA and GMF [message #374596 is a reply to message #374595] Mon, 10 March 2008 17:03 Go to previous messageGo to next message
Have you installed GMF 2.0.1? As you said, you need to install all GMF
requirements (Requirements section in [1]) but also GMF 2.0.1 (GMF SDK
section in [1]).
If GMF 2.0.1 is already installed, do you have errors concerning GMF or
STP/SCA in the error log?
Stéphane Drapeau
Obeo
[1] :http://download.eclipse.org/modeling/gmf/downloads/drops/R- 2.0.1-200709280000/index.php
Daniel Stucky a écrit :
> eclipse) from
> - GMF Base 1.0.0 reports errors in GEF SDK 3.3.1: No plug-in:
> using eclipse version 3.3.0.
> Bye,
> Daniel
Re: Problems Installing STP/SCA and GMF [message #374597 is a reply to message #374596] Tue, 11 March 2008 05:40 Go to previous messageGo to next message
> section in [1]).
you were right, I forgot to install GMF SDK. However, installing it did
not change anything.
There are no errors in any log file!
The only error I see is in Help -> Software Updates -> Manage
Configuration at GMF Base 1.0.0 -> GEF SDK 3.3.1:
Bye,
Daniel
Re: Problems Installing STP/SCA and GMF [message #374598 is a reply to message #374595] Tue, 11 March 2008 05:55 Go to previous message
Hi all,
today I downloaded GMF (Europa Edition) 2.0.2 from the Europa Discovery
Site.
STP/SCA works now, I see the creation wizards for Composite Diagram and
Model.
They are located beneath "Other" instead of "SOA Tools/SCA Tools" but this
might be because I don't have any SOA tools installed.
Anyway, I'm now able to work with the SCA Composite Designer.
Bye,
Daniel
Re: Problems Installing STP/SCA and GMF [message #613273 is a reply to message #374595] Mon, 10 March 2008 17:03 Go to previous message
section in [1]).
Stéphane Drapeau
Obeo
> eclipse) from
> Bye,
> Daniel
Re: Problems Installing STP/SCA and GMF [message #613274 is a reply to message #374596] Tue, 11 March 2008 05:40 Go to previous message
> section in [1]).
Bye,
Daniel
Re: Problems Installing STP/SCA and GMF [message #613275 is a reply to message #374595] Tue, 11 March 2008 05:55 Go to previous message
Hi all,
Site.
Model.
Bye,
Daniel
Previous Topic:Problems Installing STP/SCA and GMF
Next Topic:BPMN Modeler Annotations
Current Time: Sun Jul 20 13:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.04781 seconds
