Error installing AM3 in Ganymede [message #374293] |
Fri, 21 November 2008 17:50  |
I tried to checkout AM3 from SVN as described here:
http://wiki.eclipse.org/AM3/How_Install_New_AM3_From_SVN, in latest
Eclipse Ganymede 3.4. And everything went O.K. But when I tried to export
those packages as "Deployable plug-ins and fragments", it works to 70% and
write this error:
Problems during export
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\org.eclipse.pde.container.feature\build.xml:84:
The following error occurred while executing this line:
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\org.eclipse.pde.container.feature\build.xml:55:
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\build.xml:194:
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\build.xml:166:
Failed to copy
C:\eclipse\workspace\org.eclipse.gmt.am3.platform.extension. globalmodelmanagement\temp.folder\@dot.bin\org\eclipse\gmt\a m3\platform\extension\globalmodelmanagement\transformationex ecutionengine\TransformationExecutionHelper.class
to
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.pde.core \temp\destination\plugins\org.eclipse.gmt.am3.platform.exten sion.globalmodelmanagement_0.4.0\@dot\org\eclipse\gmt\am3\pl atform\extension\globalmodelmanagement\transformationexecuti onengine\TransformationExecutionHelper.class
due to java.io.FileNotFoundException
(The system cannot find the path specified)
Failed to copy
to
Failed to copy
to
Failed to copy
to
What is the problem ?
FUDForum. Page generated in 0.04743 seconds
