Home » Archived » AM3 » UML22Measure build failure
UML22Measure build failure [message #374183] Sat, 15 November 2008 12:02 Go to next message
Hi all,
I'm using the old AM3 distribution (0.2.0.200706221611) on Eclipse 3.4.1
(modeling tools included), EMF2.4.0 and ATL 2.0.1.
When running the build.xml ant script of the project "UML22Measure" taken
from the zoo, I receive the following error message:
BUILD FAILED
............\build.xml:28: Problem: failed to create task or type
am3.loadModel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
In the build config the option "Run in the same JRE as the workspace" is
checked.
The AM3 plugin seems to be properly installed as I can open the AM3
perspective. Problem seems similar to Mark Melia's one.
Thank you for your help.
Re: UML22Measure build failure [message #374184 is a reply to message #374183] Mon, 17 November 2008 05:15 Go to previous messageGo to next message
Hi Jerome,
The problem I was having was with the latest, bleeding edge of AM3. I have
AM3 working with an older version - 0.2.0 I think.
One idea I have is to check the box in the refresh tab of the "External
Tools Configuration" check the box "refresh resources upon completion"
and the radio button "The Entire workspace".
HTH,
Mark
Jerome wrote:
> Hi all,
> BUILD FAILED
> ............build.xml:28: Problem: failed to create task or type
> am3.loadModel
> place.
> checked.
Re: UML22Measure build failure [message #374185 is a reply to message #374183] Mon, 17 November 2008 05:33 Go to previous messageGo to next message
Hi Jerome,
Jerome a écrit :
> Hi all,
> taken from the zoo, I receive the following error message:
> BUILD FAILED
> am3.loadModel
> place.
> checked.
Due to some recent major modifications of the ATL HEAD version, the old
AM3 plugins (available as explained from
http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN) are currently not
compatible with this ATL version.
You have to checkout the sources of compatible ATL plugins from the
development branch as explained from
http://wiki.eclipse.org/ATL/How_Install_ATL_(Dev)_From_CVS
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
École des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
EMail: hugo.bruneliere@inria.fr
Re: UML22Measure build failure [message #374294 is a reply to message #374185] Sun, 23 November 2008 13:08 Go to previous message
Ok thanks Hugo,
I finally got it to work.
J.
Re: UML22Measure build failure [message #563331 is a reply to message #374183] Mon, 17 November 2008 05:15 Go to previous message
Hi Jerome,
HTH,
Mark
Jerome wrote:
> Hi all,
> BUILD FAILED
> am3.loadModel
> place.
> checked.
Re: UML22Measure build failure [message #563352 is a reply to message #374183] Mon, 17 November 2008 05:33 Go to previous message
Hi Jerome,
Jerome a écrit :
> Hi all,
> BUILD FAILED
> am3.loadModel
> place.
> checked.
Hugo
Re: UML22Measure build failure [message #563496 is a reply to message #374185] Sun, 23 November 2008 13:08 Go to previous message
Ok thanks Hugo,
J.
Previous Topic:Error installing AM3 in Ganymede
Next Topic:Where are the zoos?
Current Time: Sat Jul 19 17:12:22 EDT 2025
Powered by FUDForum. Page generated in 0.86426 seconds
