Home » Eclipse Projects » Eclipse Platform » Ant Runner - Console Log
Ant Runner - Console Log [message #37159] Sun, 18 May 2003 21:26 Go to next message
Originally posted by: ghodsian.collaxa.com
I am developing a builder extension which needs to run an ant build file.
I have found the documentation on how to configure and run AntRunner.
try
// build logic
AntRunner runner = new AntRunner();
runner.setBuildFileLocation( buildFile );
// Assign logger so that output is redirected to the console.
runner.addBuildLogger( ANT_LOGGER_CLASS );
runner.setArguments( " -verbose");
runner.run( monitor );
catch( Throwable t )
t.printStackTrace();
But I am not able to determine how to redirect the output the build into
the console.
Has anyone already solved that problem? Any pointer would be much
apreciated.
Re: Ant Runner - Console Log [message #37910 is a reply to message #37159] Mon, 19 May 2003 10:32 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
Eclipse launches and using AntLaunchDelegate and AntLaunchShortcut.
- Jared
Mark Ghodsian wrote:
> try
> // build logic
> the console.
> apreciated.
Re: Ant Runner - Console Log [message #38763 is a reply to message #37910] Mon, 19 May 2003 19:39 Go to previous messageGo to next message
Thank you for the insight. Would you happen to know if there are examples
out there on how to leverage the AntLaunchDelegate or the
AntLaunchShortcut from within a builder?
Thanks!!!
Mark
> - Jared
> > Hi,
> > try
> > // build logic
> > the console.
> > apreciated.
Re: Ant Runner - Console Log [message #38860 is a reply to message #38763] Mon, 19 May 2003 21:15 Go to previous messageGo to next message
ExternalToolBuilder is a builder that runs launch configs, including Ant
configs. As you'll see in the build(...) method, it's passed the location
of a launch config as an argument and just executes that config.
- Jared
Re: Ant Runner - Console Log [message #39088 is a reply to message #38860] Tue, 20 May 2003 02:49 Go to previous messageGo to next message
Jared. Thank you so much! It worked like a charm. Here is the source code
in case anyone else needs to accomplish the same time:
* Created on May 14, 2003
* To change the template for this generated file go to
* Window>Preferences>Java>Code Generation>Code and Comments
package bpelz.builders;
import java.io.File;
import java.io.IOException;
import java.util.Map;
import java.util.StringTokenizer;
import bpelz.bpelzPlugin;
import org.eclipse.ant.core.AntRunner;
import org.eclipse.ant.internal.core.IAntCoreConstants;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IncrementalProjectBuilder;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.debug.core.DebugPlugin;
import org.eclipse.debug.core.ILaunchConfiguration;
import org.eclipse.debug.core.ILaunchConfigurationType;
import org.eclipse.debug.core.ILaunchConfigurationWorkingCopy;
import org.eclipse.debug.core.ILaunchManager;
import org.eclipse.debug.ui.CommonTab;
import org.eclipse.debug.ui.DebugUITools;
import
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchConfigurationMessages;
import
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchShortcut;
import org.eclipse.ui.externaltools.internal.model.IExternalToolCon stants;
import org.eclipse.ui.externaltools.internal.model.ToolUtil;
import org.eclipse.ui.externaltools.internal.model.VariableContextM anager;
* @author Edwin Khodabakchian
* To change the template for this generated type comment go to
public class BPELBuilder extends IncrementalProjectBuilder
private static final String BUILD_TYPE_SEPARATOR = ","; //$NON-NLS-1$
private static final int[] DEFAULT_BUILD_TYPES= new int[] {
IncrementalProjectBuilder.INCREMENTAL_BUILD,
IncrementalProjectBuilder.FULL_BUILD};
public IProject[] build(int kind, Map args, IProgressMonitor monitor)
throws CoreException
try
System.out.println( ">>>>>>>>>>BUILDING>>>>>>>>>>>>");
// find build find within this project
IFile selectedFile = findBuildFile();
// Create a temporary launch configuration.
ILaunchConfiguration config = createDefaultConfig(
selectedFile );
boolean runTool = false;
int[] buildKinds =
buildTypesToArray( (String)config.getAttribute(
IExternalToolConstants.ATTR_RUN_BUILD_KINDS, "")
); //$NON-NLS-1$
for (int i = 0; i < buildKinds.length; i++) {
if (kind == buildKinds[i]) {
runTool = true;
break;
if (!runTool)
return null;
// Mark the build as started
VariableContextManager.getDefault().buildStarted(getProject( ),
kind);
// Launch the external ant tool
config.launch(ILaunchManager.RUN_MODE, null);
// Mark the build as completed
VariableContextManager.getDefault().buildEnded();
forgetLastBuiltState();
System.out.println( "<<<<<<<<<<BUILDING<<<<<<<<<<<<<");
t.printStackTrace( );
return null;
* Creates and returns a default launch configuration for the given
file.
* @param file
* @return default launch configuration
public static ILaunchConfiguration createDefaultConfig( IFile file )
ILaunchManager manager =
DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType type =
manager.getLaunchConfigurationType(
IExternalToolConstants.ID_ANT_LAUNCH_CONFIGURATION_TYPE);
StringBuffer buffer = new
StringBuffer(file.getProject().getName());
buffer.append(" "); //$NON-NLS-1$
buffer.append( file.getName() );
String name = buffer.toString().trim();
name= manager.generateUniqueLaunchConfigurationNameFrom( name );
try
ILaunchConfigurationWorkingCopy workingCopy
= type.newInstance(null, name);
StringBuffer buf = new StringBuffer();
ToolUtil.buildVariableTag(
IExternalToolConstants.VAR_WORKSPACE_LOC,
file.getFullPath().toString(),
buf
workingCopy.setAttribute(
IExternalToolConstants.ATTR_LOCATION,
buf.toString()
// set default for common settings
CommonTab tab = new CommonTab();
tab.setDefaults( workingCopy );
tab.dispose();
return workingCopy;
catch (Throwable t)
System.out.println( "Error while creating the default
configuration" );
return null;
* Find the ant build file associated with this project.
protected IFile findBuildFile()
IProject p = getProject();
return (IFile) p.findMember(
IAntCoreConstants.DEFAULT_BUILD_FILENAME );
protected void startupOnInitialize()
System.out.println( ">>>>>>>>>>BUILD ON INITIALIZE>>>>>>>>>>>>");
// builder init logic
* Converts the build types string into an array of
* build kinds.
* @param buildTypes the string of built types to convert
* @return the array of build kinds.
public static int[] buildTypesToArray(String buildTypes) {
int count = 0;
boolean incremental = false;
boolean full = false;
boolean auto = false;
if (buildTypes == null || buildTypes.length() == 0) {
return DEFAULT_BUILD_TYPES;
StringTokenizer tokenizer = new StringTokenizer(buildTypes,
BUILD_TYPE_SEPARATOR);
while (tokenizer.hasMoreTokens()) {
String token = tokenizer.nextToken();
if
(IExternalToolConstants.BUILD_TYPE_INCREMENTAL.equals(token) ) {
if (!incremental) {
incremental = true;
count++;
else if (IExternalToolConstants.BUILD_TYPE_FULL.equals(token))
if (!full) {
full = true;
count++;
else if (IExternalToolConstants.BUILD_TYPE_AUTO.equals(token))
if (!auto) {
auto = true;
count++;
int[] results = new int[count];
count = 0;
if (incremental) {
results[count] = IncrementalProjectBuilder.INCREMENTAL_BUILD;
count++;
if (full) {
results[count] = IncrementalProjectBuilder.FULL_BUILD;
count++;
if (auto) {
results[count] = IncrementalProjectBuilder.AUTO_BUILD;
count++;
return results;
> - Jared
Re: Ant Runner - Console Log [message #286058 is a reply to message #39088] Wed, 01 June 2005 10:43 Go to previous messageGo to next message
Originally posted by: mazloumi.uni-mannheim.de
Sorry, but I didn't understand how I can redirect the ant log to
a console view.
Has someone experience with that?
This is what id do at the moment:
final AntRunner runner = new AntRunner();
runner.setBuildFileLocation(buildFile.toString());
runner.setMessageOutputLevel(verboseLevel);
runner.setArguments(args);
runner.run();
I know I can add my own logger with:
runner.addBuildLogger("foo.FooLogger");
But how do I write out what ant logs into a console window?
nima
> import
> import
> try
> selectedFile );
> int[] buildKinds =
> ); //$NON-NLS-1$
> runTool = true;
> break;
> if (!runTool)
> return null;
> kind);
> return null;
> file.
> * @param file
> try
> buf
> buf.toString()
> tab.dispose();
> return workingCopy;
> catch (Throwable t)
> configuration" );
> return null;
> * build kinds.
> int count = 0;
> if
> if (!incremental) {
> incremental = true;
> count++;
> if (!full) {
> full = true;
> count++;
> if (!auto) {
> auto = true;
> count++;
> count = 0;
> if (incremental) {
> count++;
> if (full) {
> count++;
> if (auto) {
> count++;
> return results;
>>- Jared
Re: Ant Runner - Console Log [message #286071 is a reply to message #286058] Wed, 01 June 2005 16:02 Go to previous messageGo to next message
I have pasted below a logger class that works for me (would be your
foo.FooLogger):
public class AntConsoleLogger extends DefaultLogger {
// the message console stream used to output to the console view
private MessageConsoleStream mConsoleStream = null;
public AntConsoleLogger() {
super();
MessageConsole myConsole = findConsole("Some console name");
mConsoleStream = myConsole.newMessageStream();
protected void log(String message) {
mConsoleStream.println(message);
Also in case u need it, have added method to findConsole:
public static MessageConsole findConsole(String name) {
ConsolePlugin plugin = ConsolePlugin.getDefault();
IConsoleManager conMan = plugin.getConsoleManager();
IConsole[] existing = conMan.getConsoles();
for (int i = 0; i < existing.length; i++)
if (name.equals(existing[i].getName()))
return (MessageConsole) existing[i];
//no console found, so create a new one
MessageConsole myConsole = new MessageConsole(name, null);
conMan.addConsoles(new IConsole[]{myConsole});
return myConsole;
Hope this is what u need.
-matt
> a console view.
> runner.run();
> nima
>> import
>> import
>> try
>> selectedFile );
>> int[] buildKinds =
>> ); //$NON-NLS-1$
>> runTool = true;
>> break;
>> if (!runTool)
>> return null;
>> kind);
>> return null;
>> file.
>> * @param file
>> try
>> buf
>> buf.toString()
>> tab.dispose();
>> return workingCopy;
>> catch (Throwable t)
>> configuration" );
>> return null;
>> * build kinds.
>> int count = 0;
>> if
>> if (!incremental) {
>> incremental = true;
>> count++;
>> if (!full) {
>> full = true;
>> count++;
>> if (!auto) {
>> auto = true;
>> count++;
>> count = 0;
>> if (incremental) {
>> count++;
>> if (full) {
>> count++;
>> if (auto) {
>> count++;
>> return results;
>>>- Jared
Re: Ant Runner - Console Log [message #286092 is a reply to message #286071] Thu, 02 June 2005 06:28 Go to previous messageGo to next message
Hi Matt,
thank you very much. I works now.
Greetings,
Nima
> foo.FooLogger):
> super(); MessageConsole myConsole =
> mConsoleStream = myConsole.newMessageStream(); }
> return myConsole;
> -matt
>> a console view.
>> runner.run();
>> Thanks,
>> nima
>>> code
>>> import
>>> import
>>> import
>>> import
>>> public class BPELBuilder extends IncrementalProjectBuilder {
>>> monitor)
>>> throws CoreException {
>>> try
>>> selectedFile );
>>> int[] buildKinds = buildTypesToArray(
>>> ); //$NON-NLS-1$
>>> runTool = true;
>>> break;
>>> if (!runTool)
>>> return null;
>>> kind);
>>> return null;
>>> file.
>>> * * @param file
>>> file ) {
>>> try {
>>> name);
>>> buf
>>> workingCopy.setAttribute( IExternalToolConstants.ATTR_LOCATION,
>>> buf.toString()
>>> tab.dispose();
>>> return workingCopy;
>>> } catch (Throwable t) {
>>> configuration" );
>>> return null;
>>> * Find the ant build file associated with this project. */
>>> protected void startupOnInitialize() {
>>> * build kinds.
>>> int count = 0;
>>> if
>>> if (!incremental) {
>>> incremental = true;
>>> count++;
>>> else if
>>> if (!full) {
>>> full = true;
>>> count++;
>>> else if
>>> if (!auto) {
>>> auto = true;
>>> count++;
>>> count = 0;
>>> if (incremental) {
>>> results[count] =
>>> count++;
>>> if (full) {
>>> count++;
>>> if (auto) {
>>> count++;
>>> return results;
>>>> Ant configs. As you'll see in the build(...) method, it's passed the
>>>> location of a launch config as an argument and just executes that
>>>> config.
>>>> - Jared
>>>>> examples
Re: Ant Runner - Console Log [message #286093 is a reply to message #286092] Thu, 02 June 2005 06:33 Go to previous message
Matt,
have you experience with setting ant home programmatically
instead of manually using the preferences?
Nima
> Hi Matt,
> Greetings,
> Nima
>> foo.FooLogger):
>> return myConsole;
>> -matt
>>> a console view.
>>> runner.run();
>>> Thanks,
>>> nima
>>>> code
>>>> import
>>>> import
>>>> import
>>>> import
>>>> monitor)
>>>> try
>>>> selectedFile );
>>>> int[] buildKinds =
>>>> ); //$NON-NLS-1$
>>>> runTool = true;
>>>> break;
>>>> if (!runTool)
>>>> return null;
>>>> kind);
>>>> return null;
>>>> file.
>>>> * * @param file
>>>> file ) {
>>>> name );
>>>> try {
>>>> name);
>>>> buf
>>>> buf.toString()
>>>> tab.dispose();
>>>> return workingCopy;
>>>> configuration" );
>>>> return null;
>>>> * build kinds.
>>>> int count = 0;
>>>> if
>>>> if (!incremental) {
>>>> incremental = true;
>>>> count++;
>>>> else if
>>>> if (!full) {
>>>> full = true;
>>>> count++;
>>>> else if
>>>> if (!auto) {
>>>> auto = true;
>>>> count++;
>>>> count = 0;
>>>> if (incremental) {
>>>> results[count] =
>>>> count++;
>>>> if (full) {
>>>> count++;
>>>> if (auto) {
>>>> count++;
>>>> return results;
>>>>> including Ant configs. As you'll see in the build(...) method, it's
>>>>> passed the location of a launch config as an argument and just
>>>>> - Jared
>>>>>> examples
Previous Topic:[RCP] Reuse running instance of eclipse
Next Topic:Startup issue occurred from M6 to RC1
Current Time: Sat Jul 19 06:17:57 EDT 2025
Powered by FUDForum. Page generated in 0.05180 seconds
