Home » Archived » BIRT » javascript debug failing
javascript debug failing [message #365309] Wed, 24 September 2008 14:23 Go to next message
I am trying to debug a report in BIRT 2.3. I have set my breakpoint in
the report's beforeFactory script. When I try running Run->Debug Report
nothing happen. I have tried it from both the report and debug
perspective. Any ideas? Thanks.
Re: javascript debug failing [message #365312 is a reply to message #365309] Wed, 24 September 2008 15:10 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Mike,
In the debug perspective did you add a new report debug configuration?
Jason
Re: javascript debug failing [message #365314 is a reply to message #365312] Wed, 24 September 2008 15:30 Go to previous messageGo to next message
yes
Re: javascript debug failing [message #365315 is a reply to message #365314] Wed, 24 September 2008 16:50 Go to previous messageGo to next message
Mike,
What options did you select for the debug configuration?
Jason
Mike wrote:
> yes
Re: javascript debug failing [message #365316 is a reply to message #365315] Wed, 24 September 2008 17:16 Go to previous messageGo to next message
Main Tab:
Report file: pointed at my report
Use default engine home: checked
Temp folder: my windows profile temp directory (default)
Task Type: Run and Render
Debug type: Java Script
Output: html
Open generated file: checked
All other tabs: default
Re: javascript debug failing [message #365321 is a reply to message #365316] Thu, 25 September 2008 10:49 Go to previous messageGo to next message
Mike,
Are you using windows vista?
If so can you try setting the temp folder to something like c:/temp?
I had permission problems with the profile temp directory.
Jason
Mike wrote:
> Main Tab:
> Output: html
Re: javascript debug failing [message #365323 is a reply to message #365321] Thu, 25 September 2008 15:01 Go to previous messageGo to next message
I am not using Vista. I switched my temp folder to c:/temp and there is
no change.
Re: javascript debug failing [message #365345 is a reply to message #365323] Mon, 29 September 2008 09:57 Go to previous messageGo to next message
Mike,
Are you getting any errors in the workspace log file?
Jason
> no change.
Re: javascript debug failing [message #368131 is a reply to message #365345] Tue, 05 May 2009 11:26 Go to previous messageGo to next message
My 2.3.2.1 debugging was working fine last week. This week I'm experiencing
the same issue reported here, namely nothing *at all* happens when I attempt
to debug. Perhaps related, I emptied out my TEMP folder yesterday. I do
use Vista, and have tried changing my temp folder to c:\temp. None of this
helps.
My workspace log shows:
!ENTRY org.eclipse.ui 4 0 2009-05-05 10:51:05.250
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at
org.eclipse.birt.report.designer.ui.parameters.ParameterFact ory.createScalarParameter(ParameterFactory.java:183)
at
org.eclipse.birt.report.designer.ui.parameters.ParameterFact ory.getRootChildren(ParameterFactory.java:87)
at
org.eclipse.birt.report.debug.internal.ui.script.launcher.Re portLaunchHelper.getInputParameters(ReportLaunchHelper.java: 308)
at
org.eclipse.birt.report.debug.internal.ui.script.launcher.Re portLaunchHelper.access$0(ReportLaunchHelper.java:292)
at
org.eclipse.birt.report.debug.internal.ui.script.launcher.Re portLaunchHelper$1.run(ReportLaunchHelper.java:358)
at
org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:155)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer. java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 22 more
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:gbqmun$6l0$1@build.eclipse.org...
> Mike,
> Jason
>> no change.
Re: javascript debug failing [message #368133 is a reply to message #368131] Tue, 05 May 2009 11:42 Go to previous messageGo to next message
I think I figured it out. Filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275008
"James Koch" <jkoch@insightdirect.com> wrote in message
news:gtplrj$dv7$1@build.eclipse.org...
> experiencing the same issue reported here, namely nothing *at all* happens
> when I attempt to debug. Perhaps related, I emptied out my TEMP folder
> yesterday. I do use Vista, and have tried changing my temp folder to
> c:\temp. None of this helps.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
>> Mike,
>> Jason
>>> no change.
Re: javascript debug failing [message #368134 is a reply to message #368133] Tue, 05 May 2009 12:03 Go to previous message
James,
It looks like this is a bug, but what event do you have the breakpoint on?
Jason
>> happens when I attempt to debug. Perhaps related, I emptied out my
>> TEMP folder yesterday. I do use Vista, and have tried changing my
>> temp folder to c:\temp. None of this helps.
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 22 more
>>> Mike,
>>> Jason
>>>> there is no change.
Previous Topic:Creating Mailing Labels and Form Type of Repots
Next Topic:Sorting on Strings?
Current Time: Sat Jul 19 10:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.05032 seconds
