Home » Archived » XML Schema Definition (XSD) » Redefinitions
Redefinitions [message #36799] Fri, 30 January 2004 04:55 Go to next message
Originally posted by: niemaz.xrce.xerox.com
I'd like to find out when a type is being redefined or not.
I guest I should just compare the typedefinitions but which one of next
methods should I use?
getBaseTypeDefinition, getBaseType, getRootTypeDefinition, getRootType(),
getItemTypeDefinition, ... ?
Then, how would I get access to the redefinition itself?
How to find out if it's a restriction or an extension?
so many questions .. ;-)
thanx,
--mike
Re: Redefinitions [message #36833 is a reply to message #36799] Fri, 30 January 2004 07:43 Go to previous messageGo to next message
Have found the getDerivationMethod for complex types.
Fine.
What about simple types?
--mike
mike wrote:
> thanx,
> --mike
Re: Redefinitions [message #36901 is a reply to message #36799] Fri, 30 January 2004 08:26 Go to previous message
Mike,
I'm not sure if you are really asking about <redefine>. Are you?
mike wrote:
> thanx,
> --mike
Re: Redefinitions [message #583263 is a reply to message #36799] Fri, 30 January 2004 07:43 Go to previous message
Fine.
--mike
mike wrote:
> thanx,
> --mike
Re: Redefinitions [message #583303 is a reply to message #36799] Fri, 30 January 2004 08:26 Go to previous message
Mike,
mike wrote:
> thanx,
> --mike
Previous Topic:nullException
Next Topic:nullException
Current Time: Sat Jul 19 17:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.03698 seconds
