Getting connection profile content [message #36374] |
Mon, 17 September 2007 10:28  |
I am now able to successfully get a handle on a particular
IConnectionProfile via the ProfileManager object.
How can I get the meta data content from that connection profile and use it
in another plugin (rather than just viewing it as a user)?
Obviously, I must connect first.
Chuck
Re: Getting connection profile content [message #36438 is a reply to message #36421] |
Tue, 18 September 2007 11:53  |
I believe this method or a similar one should be part of the public API -
don't you?
If you want people to leverage the work that you've done, then you should be
able to programmatically access the contents of the connection profile (not
just as a user).
I'm just trying to figure out the best way to do that.
Thank you very much for your help.
Chuck
"Hui Cao" <hui.cao@sybase.ocm> wrote in message
news:fcnrl2$knd$1@build.eclipse.org...
> In SQL Dev Tools, we have a utility method ProfileUtil.getDatabase, which
> does exactly what you want, although this is not API and we can not
> guarantee its stability. In fact, you can see that the parameter
> DatabaseIdentifier asks more than what this method needs: a profile name
> is sufficient. So we'll overload this method with a profileName as the
> parameter later.
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
> "Chuck Doucette" <cdoucette@vaultus.com> wrote in message
> news:fcmdsc$3sv$1@build.eclipse.org...
>> Let me be more specific:
>> How can I get a handle on a
>> (org.eclipse.datatools.modelbase.sql.schema.)Database object
>> given a connection profile?
>> Thanks,
>> Chuck
>> news:fcm30k$8al$1@build.eclipse.org...
>>> it in another plugin (rather than just viewing it as a user)?
>>> Thanks,
>>> Chuck
Re: Getting connection profile content [message #587912 is a reply to message #36374] |
Mon, 17 September 2007 13:34  |
Chuck
> Chuck
Re: Getting connection profile content [message #587923 is a reply to message #36401] |
Tue, 18 September 2007 02:36  |
DatabaseIdentifier asks more than what this method needs: a profile name is
parameter later.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
> Chuck
>> Thanks,
>> Chuck
Re: Getting connection profile content [message #587931 is a reply to message #36421] |
don't you?
just as a user).
Chuck
> parameter later.
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> Thanks,
>> Chuck
>>> Thanks,
>>> Chuck
FUDForum. Page generated in 0.04263 seconds
