Home » Eclipse Projects » SWTBot » New SWTBot release
New SWTBot release [message #36074] Thu, 21 May 2009 01:03 Go to next message
This is in continuation of my previous email[1] on some of the new
features in swtbot.
I've pushed in a new build of SWTBot in case you wish to try it out. If
you're going to be downloading this release, I'd highly recommend
reading these notes.
Some known issues:
1. Editor autocompletes and quickfixes is broken with eclipse 3.5M7 and RC1.
2. Menus inside eclipse are broken with eclipse 3.5M7 and RC1.
Some of the features:
1. Toggle button support
2. SWTBot can now be scoped to search within a particular widget:
microBot = bot.viewByLabel("Package Explorer").bot();
microBot.tree().select("MyProject");
This makes the earlier nuiances redundant:
widget = bot.viewByLabel("Package Explorer").getWidget();
SWTBotTree t = bot.widget(widget, widgetOfType(Tree.class));
3. Renamed SWTEclipseBot to SWTWorkbenchBot:
SWTEclipseBot is available but deprecated. Also the methods
view(viewLabel) and editor(fileName) are renamed to
viewByLabel(viewLabel) and editorByFileName(fileName);
4. Native mouse support (partial):
Clicking on certain widgets actually moves the mouse over them and
performs the click.
5. Native keyboard event(needs community inputs):
Performing type operations performs keyboard types using native events.
This requires that the community participates in sending in their
keyboard layouts[2] for inclusion in SWTBot.
6. Setting preferences is now easier.
Setting preferences is now a matter of setting a simple variable instead
of via System.setProperty().
[1] -
http://www.eclipse.org/newsportal/article.php?id=653&gro up=eclipse.swtbot#653
[2] - http://wiki.eclipse.org/SWTBot/Keyboard_Layouts
-- Ketan
Re: New SWTBot release [message #36109 is a reply to message #36074] Thu, 21 May 2009 06:03 Go to previous messageGo to next message
Hi Ketan,
I just upgraded to 2.0.0.292, running Eclipse 3.4.1 on MacOSX10.5,
following your comment on bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275127.
Unfortunately none of my now tests run properly. I've changed all bot
references to SWTWorkbenchBot, and the way I access views, but the
detection of dialogs seems not to work anymore.
ALl my tests start by creating a fresh project via the new project wizard
public static void getNewProjectWizardMainPage(SWTWorkbenchBot bot) throws
Exception{
// this still works and opens new project wizard
bot.menu("File").menu("New").menu("SBSI System").click();
// this was workng but now fails with timeout exception
bot.shell(NewSBSIProjectWizard.WINDOW_TITLE).activate();
The 'New Project' Dialog opens ok but the test fails with a 'widget not
found' exception as the open shell cannot be found - the test just hangs
and the dialog is not completed. I tried adding text by hand but his
rather loses the convenience of automated tests.
I read your two recent posts and can't see anything about this being
changed.
- Also, 'viewByLabel' is not present in API, but bot.viewByTitle is - are
they the same thing?
Richard
Re: New SWTBot release [message #36143 is a reply to message #36074] Thu, 21 May 2009 18:08 Go to previous messageGo to next message
Cool!
Glad to see new stuff happening :)
Re: New SWTBot release [message #36372 is a reply to message #36109] Sat, 23 May 2009 17:34 Go to previous messageGo to next message
Hi Richard,
Richard Adams wrote:
> Hi Ketan,
I got the same problem with 2.0.0.316.
I found out that there is a differnce between 2.0.0.316 and 2.0.0.204,
when starting a test as "SWTBot Test" from within Eclipse.
With 204 the command line contains
-application org.eclipse.swtbot.eclipse.core.swtbottestapplication
With 316 the command line contains
-application org.eclipse.pde.junit.runtime.uitestapplication
So it seems the "SWTBot Test" of 316 starts a PDE JUnit test.
As a workaround I just added the good argument to my runtime
configuration's arguments.
Kind Regards,
Stefan
Re: New SWTBot release [message #36399 is a reply to message #36372] Sun, 24 May 2009 01:10 Go to previous messageGo to next message
I just ran a few tests myself, and the command line as returned by "ps
aux | grep java" contains
org.eclipse.swtbot.eclipse.core.swtbottestapplication and not pde's
uitestapplication as you mention.
-- Ketan
Re: New SWTBot release [message #36462 is a reply to message #36399] Sun, 24 May 2009 02:30 Go to previous messageGo to next message
Stefan,
Could you try deleting the launch configuration and execute the test
again ? I have a suspicion that this was possibly introduced[1] as part
of bug 274083[2]. Although nothing points me in this direction.
[1] -
http://github.com/ketan/swtbot/commit/cd9a676ce93864864353da 0aa9be13c3521c9b02
[2] - https://bugs.eclipse.org/bugs/show_bug.cgi?id=274083
-- Ketan
> -- Ketan
Re: New SWTBot release [message #36479 is a reply to message #36462] Sun, 24 May 2009 04:28 Go to previous messageGo to next message
Hi Ketan,
Still the same.
I tried some more:
- Installed a fresh Eclipse Ganymede 3.4.2
- Started with a fresh workspace
- Installed SWTBot 2.0.0.316 from update site [1]
- Created a test plugin with the following class:
@RunWith(SWTBotJunit4ClassRunner.class)
public class MyFirstTest extends SWTBotEclipseTestCase {
@Test
public void OpenPerspective() throws Exception {
final SWTWorkbenchBot bot = new SWTWorkbenchBot();
bot.menu("Window").
menu("Open Perspective").
menu("Other...").click();
bot.shell("Open Perspective"); // <--hangs here
bot.table().select("Resource");
bot.button("OK").click();
- Right-click the class and select Run As->SWTBot Test
--> The "Open Perspective" dialog is opened but hangs then.
I found another workaround:
In the run configuration's main tab, the selection is "Run a product"
and "org.eclipse.platform.ide". If I change this to "Run an application"
and "org.eclipse.swtbot.eclipse.core.swtbottestapplication" everything
works well.
I'll try with Eclipse 3.5 later, because I need JUnit 4.5.
Kind Regards,
Stefan
[1]
http://download.eclipse.org/technology/swtbot/ganymede/dev-b uild/update-site
Re: New SWTBot release [message #36509 is a reply to message #36479] Sun, 24 May 2009 07:52 Go to previous messageGo to next message
I think that is enough info. The only difference between galileo and
ganymede is the junit4 dependency. The code is the same.
Thanks!
-- Ketan
On 24/5/09 13:58, Stefan Seelmann wrote:
> Hi Ketan,
> Still the same.
> I tried some more:
> @Test
> bot.menu("Window").
> bot.shell("Open Perspective"); //<--hangs here
> works well.
> Kind Regards,
> Stefan
> [1]
Re: New SWTBot release [message #36790 is a reply to message #36509] Mon, 25 May 2009 06:14 Go to previous messageGo to next message
Hi Stefan,
I've fixed this issue with the latest build on the update site.
Could you test if that works fine ?
-- Ketan
On 24/5/09 17:22, Ketan Padegaonkar wrote:
> Thanks!
> -- Ketan
>> Hi Ketan,
>> Still the same.
>> I tried some more:
>> @Test
>> bot.menu("Window").
>> works well.
>> Kind Regards,
>> Stefan
>> [1]
Re: New SWTBot release [message #36824 is a reply to message #36790] Mon, 25 May 2009 17:19 Go to previous messageGo to next message
Works fine now,
Many thanks Ketan!
> Hi Stefan,
Re: New SWTBot release [message #36927 is a reply to message #36824] Tue, 26 May 2009 09:42 Go to previous message
Problem solved for me too,
thanks very much,
Richard
Previous Topic:Running SWTBot -Tests with an complete new instance of eclipse
Next Topic:SWTBotPreferences
Current Time: Sat Jul 19 06:13:16 EDT 2025
Powered by FUDForum. Page generated in 0.05010 seconds
