Home » General (non-technical) » Eclipse Foundation » java.lang.IllegalArgumentException
java.lang.IllegalArgumentException [message #35570] Mon, 12 June 2006 04:46 Go to next message
Originally posted by: faireni.walla.com
i got this error:
ERROR [org.hibernate.proxy.BasicLazyInitializer] CGLIB Enhancement failed:
my.com.shinyang.ilms.model.MCurrency
java.lang.IllegalArgumentException: Superclass has no null constructors
but nopackage my.com.shinyang.ilms.model;
import java.util.Date;
import my.com.shinyang.ilms.ui.table.TableData;
public class MCurrency implements java.io.Serializable, TableData {
// Fields
private String code;
private int rate;
private String description;
private int unit;
private Date fromDate;
private Date toDate;
// Constructors
public MCurrency(String code, String description, Date fromDate, Date
toDate, int rate, int unit) {
this.code = code;
this.description = description;
this.rate = rate;
this.unit = unit;
this.fromDate = fromDate;
this.toDate = toDate;
/** minimal constructor */
public MCurrency(String code) {
this.code = code;
public String getCode() {
return code;
public void setCode(String code) {
this.code = code;
public String getDescription() {
return description;
public void setDescription(String description) {
public Date getFromDate() {
return fromDate;
public void setFromDate(Date fromDate) {
public int getRate() {
return rate;
public void setRate(int rate) {
this.rate = rate;
public Date getToDate() {
return toDate;
public void setToDate(Date toDate) {
public int getUnit() {
return unit;
public void setUnit(int unit) {
this.unit = unit;
can anyone help??? thanks!!!!
Re: java.lang.IllegalArgumentException [message #35604 is a reply to message #35570] Mon, 12 June 2006 07:41 Go to previous messageGo to next message
I'm not sure how this relates to Eclipse. The foundation newsgroup is
not really the place to ask questions about code anyway. The platform
newsgroup is better for general questions about Eclipse programming, but
this doesn't seem to ask a question that's in any way related to Eclipse
as far as I can tell.
faireni wrote:
> i got this error:
> failed: my.com.shinyang.ilms.model.MCurrency
> constructors but nopackage my.com.shinyang.ilms.model;
> // Fields
> private int rate;
> private int unit;
> // Constructors
> Date toDate, int rate, int unit) {
> this.code = code;
> this.rate = rate;
> this.unit = unit;
> this.code = code;
> return code;
> this.code = code;
> return description;
> return fromDate;
> return rate;
> this.rate = rate;
> return toDate;
> return unit;
> this.unit = unit;
Re: java.lang.IllegalArgumentException [message #35670 is a reply to message #35604] Mon, 12 June 2006 15:26 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
There's hardly any on-topic discussion in this group.
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=146669 for this.
D.
> faireni wrote:
>> i got this error:
>> // Fields private String code;
>> private int rate;
>> private int unit;
>> // Constructors
>> this.code = code;
>> this.rate = rate;
>> this.unit = unit;
>> this.code = code;
>> return code;
>> this.code = code;
>> return description;
>> return fromDate;
>> return rate;
>> this.rate = rate;
>> return toDate;
>> return unit;
>> this.unit = unit;
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Previous Topic:Bundles are really there but!!!!
Next Topic:Reference Material on Libraries, Deployment, Jars
Current Time: Sat Jul 19 06:35:29 EDT 2025
Powered by FUDForum. Page generated in 0.02814 seconds
