Home » Eclipse Projects » Plugin Development Environment (PDE) » UI methods in normal Job
UI methods in normal Job [message #35060] Mon, 01 December 2008 08:02 Go to next message
Hey,
i have a simple Eclipse Job which will start a search. Before i can do
this, i need some information about the opened resource in a editor. So i
would call PlatformUI.get... to get this information. To use this method i
have to run it from a UI Job. I could now simply start a UIJob out of my
normal Job to retrieve the information but there has to be a better way or
not?
Can i use the method somehow in my normal Eclipse job?
regards
Matthias
Re: UI methods in normal Job [message #35338 is a reply to message #35060] Tue, 02 December 2008 17:49 Go to previous messageGo to next message
Hi Matthias,
You do not need to create a UIJob just to run code in the UI thread if that
is what you mean, e.g. get information about an editor.
You should be able to do something like this:
org.eclipse.swt.widgets.Display.getCurrent().syncExec(new Runnable() {
public void run() {
System.out.println("I'm running from the GUI thread, wee!");
I hope this helps and that I didn't misunderstand your question.
Best of luck!
David Virdefors
Purple Scout / www.purplescout.com
"Matthias Kohles" <m.kohles@gmx.de> wrote in message
news:3fc08b78e0e93f71706e51fa4cc83d16$1@www.eclipse.org...
> Hey,
> not?
> regards
> Matthias
Re: UI methods in normal Job [message #35615 is a reply to message #35338] Thu, 04 December 2008 01:40 Go to previous messageGo to next message
Hey,
thank you for your answer.
I tried your code but it did not work for me.
i have a normal NonUI eclipe Job. In this job i need the information of
what file from which project is opened in the active editor. So i tried
your code within this job but i receive a NullPointerException in
public void run()
editorPart =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActiveEditor();
JavaDoc says that when i call Display.getCurrent() in a non-UI thread it
will return always null.
is there another way to use this syncExec within my job?
best regards,
Matthias
Re: UI methods in normal Job [message #35683 is a reply to message #35615] Thu, 04 December 2008 06:40 Go to previous messageGo to next message
Originally posted by: Marcus.Ilgner.gerig.de
Matthias Kohles wrote:
> Hey,
> public void run()
> editorPart =
> best regards,
> Matthias
have you tried
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShel l().getDisplay()
instead of
Afaik that would be the way to go...
HTH
Marcus
Re: UI methods in normal Job [message #35717 is a reply to message #35683] Thu, 04 December 2008 08:22 Go to previous messageGo to next message
thanks for your message,
this didn't work either.
Same NullPointerException in getDisplay :(
regards Matthias
Re: UI methods in normal Job [message #35751 is a reply to message #35717] Thu, 04 December 2008 08:50 Go to previous messageGo to next message
> regards Matthias
Duh... that shouldn't happen. Where does the NPE occur exactly? In
getDisplay() or before that (activeWorkbenchWindow could be null)? Do you
have a stacktrace?
Re: UI methods in normal Job [message #35817 is a reply to message #35751] Thu, 04 December 2008 10:02 Go to previous messageGo to next message
Hey,
here is the stacktrace:
at com.myPlugin.jobs.FileScanJob.run(FileScanner.java:414)
ad the code
try
IWorkbench workbench = PlatformUI.getWorkbench();
IWorkbenchWindow wWindow = workbench.getActiveWorkbenchWindow();
Shell shell = wWindow.getShell();
Display display = shell.getDisplay();
display.syncExec(new Runnable()
public void run()
editorPart =
catch (Exception e)
e.printStackTrace();
the NPE is occuring on Shell shell = wWindow.getShell();
i have no idea why this is happening
regards Matthias
Re: UI methods in normal Job [message #36327 is a reply to message #35817] Mon, 08 December 2008 08:26 Go to previous message
getActiveWorkbenchWindow() works only if called from UI thread. This is
not consistent and expected it is a legacy from Eclipse 2.x.
> Hey,
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> ad the code
> try
> public void run()
> editorPart =
> catch (Exception e)
> regards Matthias
Re: UI methods in normal Job [message #586223 is a reply to message #35060] Tue, 02 December 2008 17:49 Go to previous message
Hi Matthias,
public void run() {
Best of luck!
David Virdefors
> Hey,
> not?
> regards
> Matthias
Re: UI methods in normal Job [message #586358 is a reply to message #35338] Thu, 04 December 2008 01:40 Go to previous message
Hey,
public void run()
editorPart =
best regards,
Matthias
Re: UI methods in normal Job [message #586382 is a reply to message #35615] Thu, 04 December 2008 06:40 Go to previous message
> Hey,
> public void run()
> editorPart =
> best regards,
> Matthias
have you tried
instead of
HTH
Marcus
Re: UI methods in normal Job [message #586388 is a reply to message #35683] Thu, 04 December 2008 08:22 Go to previous message
regards Matthias
Re: UI methods in normal Job [message #586399 is a reply to message #35717] Thu, 04 December 2008 08:50 Go to previous message
> regards Matthias
have a stacktrace?
Re: UI methods in normal Job [message #586427 is a reply to message #35751] Thu, 04 December 2008 10:02 Go to previous message
Hey,
ad the code
try
public void run()
editorPart =
catch (Exception e)
regards Matthias
Re: UI methods in normal Job [message #586610 is a reply to message #35817] Mon, 08 December 2008 08:26 Go to previous message
> Hey,
> ad the code
> try
> public void run()
> editorPart =
> catch (Exception e)
> regards Matthias
Previous Topic:Plug-in compiles and exports, but throws NPE when accessed
Next Topic:How to run executable jar via eclipse update manager
Current Time: Sat Jul 19 09:36:55 EDT 2025
Powered by FUDForum. Page generated in 0.04894 seconds
