Home » Eclipse Projects » SWTBot » Eclipse 3.4.2 Ganymede supported by SWTBot?
Eclipse 3.4.2 Ganymede supported by SWTBot? [message #34704] Thu, 07 May 2009 04:30 Go to next message
A co-worker uses Ubuntu and tries to use SWTBot with Eclipse 3.4.2
Ganymede.
Although we installed SWTBot plugins in the IDE, Eclipse does not show the
"SWTBot Test" launcher (Run>Run Configurations...) configuration on that
system.
Is there a problem with Ubuntu and Eclipse 3.4.2 Ganymede concerning
"SWTBot Test" launcher being available in the IDE?
Or do you have any idea why "SWTBot Test" is not available on that system?
Re: Eclipse 3.4.2 Ganymede supported by SWTBot? [message #34872 is a reply to message #34704] Thu, 07 May 2009 15:08 Go to previous messageGo to next message
Using Ubuntu and Eclipse 3.4.2 as well: everything runs fine.
Make sure you installed the ui plugin of SWTBot.
> Ganymede.
> the "SWTBot Test" launcher (Run>Run Configurations...) configuration on
> that system.
Re: Eclipse 3.4.2 Ganymede supported by SWTBot? [message #34962 is a reply to message #34704] Thu, 07 May 2009 22:57 Go to previous message
Add a the option -consoleLog -debug to your eclipse.ini and start eclipse
from the command line to see why this is happening. My guess is some
missing dependency or a misconfigured eclipse.
-- Ketan
Previous Topic:macosx experiences
Next Topic:[3.5 M7] Test launch problem
Current Time: Sat Jul 19 17:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.06033 seconds
