Home » Archived » XML Schema Definition (XSD) » The 'no duplicates' constraint is violated
The 'no duplicates' constraint is violated [message #34246] Wed, 17 December 2003 09:33 Go to next message
Originally posted by: niemaz.xrce.xerox.com
I get this error when trying to load an xsd file.
My question is : is there a workaround?
A quick and dirty load?
thanx,
--mike
Re: The 'no duplicates' constraint is violated [message #34312 is a reply to message #34246] Wed, 17 December 2003 09:45 Go to previous messageGo to next message
Mike,
You need to provide more detail, like a stack trace. I'm not a mind
reader...
> thanx,
> --mike
Re: The 'no duplicates' constraint is violated [message #34380 is a reply to message #34312] Wed, 17 December 2003 10:09 Go to previous messageGo to next message
Yep sorry, I wasn't quiet sure my message would be read.
Below is the stacktrace.
Seems to be the BasicEList#add method which catches the xsd incorrectness
and
sends the error.
--mike
java.lang.IllegalArgumentException: The 'no duplicates' constraint is
violated
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 12)
at
org.eclipse.emf.common.util.BasicEList$EListIterator.add(Bas icEList.java:1399)
at
org.eclipse.xsd.impl.XSDNamedComponentImpl.mergeToSortedList (XSDNamedComponentImpl.java:178)
at
org.eclipse.xsd.impl.XSDSchemaImpl.propogateComponents(XSDSc hemaImpl.java:2862)
at
org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl .java:3027)
at
org.eclipse.xsd.impl.XSDSchemaImpl.included(XSDSchemaImpl.ja va:2946)
at
org.eclipse.xsd.impl.XSDIncludeImpl.handleResolvedSchema(XSD IncludeImpl.java:337)
at
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:405)
at
org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.jav a:324)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:513)
at
org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1494)
at
org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl .java:3025)
at
at
at
at
at
at
at
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
at
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
at
org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:410)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:233)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
at
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:374)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
at
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:380)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
Ed Merks wrote:
> Mike,
> reader...
> > thanx,
> > --mike
Re: The 'no duplicates' constraint is violated [message #34450 is a reply to message #34380] Wed, 17 December 2003 10:48 Go to previous messageGo to next message
Mike,
Hmmm. There's some interesting include stuff going on here. Could you share the schemas that
produce this problem? If I have a working (i.e., failing) test case, I can get to the bottom of it
quickly...
> and
> sends the error.
> --mike
> violated
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Mike,
> > reader...
> > > thanx,
> > > --mike
Re: The 'no duplicates' constraint is violated [message #34484 is a reply to message #34450] Wed, 17 December 2003 11:03 Go to previous messageGo to next message
I'm afraid I can't share this one, but I'll try to isolate the problem and
create a test file from it.
--mike
Ed Merks wrote:
> Mike,
> quickly...
> > and
> > sends the error.
> > --mike
> > violated
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Mike,
> > > reader...
> > > > thanx,
> > > > --mike
Re: The 'no duplicates' constraint is violated [message #34517 is a reply to message #34484] Wed, 17 December 2003 11:11 Go to previous messageGo to next message
Mike,
That would be much appreciated. I may be able to fix this for the 2.0 drop later this week if you
act quickly. ;-)
> --mike
> Ed Merks wrote:
> > Mike,
> > quickly...
> > > and
> > > sends the error.
> > > --mike
> > > violated
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Mike,
> > > > reader...
> > > > > thanx,
> > > > > --mike
Re: The 'no duplicates' constraint is violated [message #581675 is a reply to message #34246] Wed, 17 December 2003 09:45 Go to previous messageGo to next message
Mike,
reader...
> thanx,
> --mike
Re: The 'no duplicates' constraint is violated [message #581765 is a reply to message #34312] Wed, 17 December 2003 10:09 Go to previous messageGo to next message
and
sends the error.
--mike
violated
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Ed Merks wrote:
> Mike,
> reader...
> > thanx,
> > --mike
Re: The 'no duplicates' constraint is violated [message #581831 is a reply to message #34380] Wed, 17 December 2003 10:48 Go to previous messageGo to next message
Mike,
quickly...
> and
> sends the error.
> --mike
> violated
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Mike,
> > reader...
> > > thanx,
> > > --mike
Re: The 'no duplicates' constraint is violated [message #581871 is a reply to message #34450] Wed, 17 December 2003 11:03 Go to previous messageGo to next message
--mike
Ed Merks wrote:
> Mike,
> quickly...
> > and
> > sends the error.
> > --mike
> > violated
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Ed Merks wrote:
> > > Mike,
> > > reader...
> > > > thanx,
> > > > --mike
Re: The 'no duplicates' constraint is violated [message #581885 is a reply to message #34484] Wed, 17 December 2003 11:11 Go to previous messageGo to next message
Mike,
act quickly. ;-)
> --mike
> Ed Merks wrote:
> > Mike,
> > quickly...
> > > and
> > > sends the error.
> > > --mike
> > > violated
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > Ed Merks wrote:
> > > > Mike,
> > > > reader...
> > > > > thanx,
> > > > > --mike
Re: The 'no duplicates' constraint is violated [message #996360 is a reply to message #34246] Tue, 01 January 2013 17:21 Go to previous messageGo to next message
I just found this old post. I have a problem with the same symptoms, and created a post (including an XSD file causing the problem) in a different forum:
http://www.eclipse.org/forums/index.php/t/445467/
BTW: What is the difference between the forum "Modeling » XSD" and "Eclipse Projects » XML Schema Definition (XSD)"?
I hope this helps resolving the issue.
Best Regards,
Max
Re: The 'no duplicates' constraint is violated [message #996655 is a reply to message #996360] Wed, 02 January 2013 11:06 Go to previous messageGo to next message
Max,
The problem stems from duplicate union members:
<xs:union memberTypes="m:length m:length"/>
But we should diagnose that as an error not throw an exception. Please
open a bugzilla and attach the sample zip file.
I didn't know that at some point duplicate newsgroups were created. :-(
This is the original one and I didn't know about the other one so I have
only monitored this one. I've asked that the other one be terminated.
On 01/01/2013 11:21 PM, Max Bureck wrote:
> different forum:
> Best Regards,
> Max
Re: The 'no duplicates' constraint is violated [message #996702 is a reply to message #996655] Wed, 02 January 2013 13:02 Go to previous messageGo to next message
Max,
I was looking at how to fix it, which isn't hard, so I have a patch ready...
I also looked at the specification and I don't see any constraint that
says it's an error for them memberTypes attribute to specify the same
type more than once. If there were such a constraint, I would have had
a test case for it. So I think the semantic model is just supposed to
ignore duplicates, i.e., filter them out. I suppose it is bad style to
have duplicate, but not wrong, so that's how I'll handle the fix...
On 02/01/2013 5:06 PM, Ed Merks wrote:
> Max,
> have only monitored this one. I've asked that the other one be
> terminated.
>> Hi,
>> different forum:
>> Best Regards,
>> Max
Re: The 'no duplicates' constraint is violated [message #996939 is a reply to message #34246] Thu, 03 January 2013 03:51 Go to previous messageGo to next message
Hi Ed,
Thanks for the quick help! I created a bugzilla entry for this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=397348
The MathML web page states that the XSD schema was derived from a RelaxNG schema, so maybe this duplicate was generated automatically.
Thanks again,
Max
Re: The 'no duplicates' constraint is violated [message #996976 is a reply to message #996939] Thu, 03 January 2013 05:20 Go to previous messageGo to next message
Max,
Comments below.
On 03/01/2013 9:51 AM, Max Bureck wrote:
> Hi Ed,
You're welcome. It helps immensely to have a test case. It's amazing
how often people forget that...
I committed the fix for master. Not sure if you were looking for a fix
in the maintenance stream (2.7.x) as well? You indicated 2.6 in the
bugzilla, but we (I) don't have the capacity for maintaining more than
one released stream.
Yes, and if there is no constraint to indicate that it's wrong, it's
something that's easily overlooked...
> Thanks again,
> Max
Re: The 'no duplicates' constraint is violated [message #996983 is a reply to message #34246] Thu, 03 January 2013 05:40 Go to previous message
Hello Ed,
I just selected 2.6, because it is the version the error occurred. I am fine with it being fixed in 2.7.x .
Previous Topic:Digram Editor loses focus on closing of MessageDialog in Graphiti
Next Topic:choice child under all
Current Time: Sun Jul 20 05:59:06 EDT 2025
Powered by FUDForum. Page generated in 0.08142 seconds
