Home » Modeling » OCL » OCL queries on UML / M1 level
OCL queries on UML / M1 level [message #33838] |
Tue, 24 July 2007 08:47  |
Originally posted by: wah.zurich.ibm.com
I have written a little UML model and created one instance of it using
InstanceSpecifications. Using the OCL interpreter, I have performed some
M2 level queries. For instance, evaluating `self' on one of my instance
specification results in
Instance Specification c1
However, evaluating 'self' as M1 level expression on the same instance
specification does not return a result (the expected result would be
`Class1 c1', since Class1 is the classifier specified for c1).
Am I doing the right thing? How would I get the expected result?
Michael
Re: OCL queries on UML / M1 level [message #33869 is a reply to message #33838] |
Tue, 24 July 2007 10:35   |
Hi, Michael,
At the M1 level, you would expect the same result as M2, because the
evaluation of M1 expressions on instance models treats the instance
specification as "self" and its Slots as the values of its classifier's
properties. Evaluating "self" definitely should not return null.
There are, currently, some problems in working with ValueSpecifications and
InstanceSpecifications, where the UML environment gets confused between
M-levels. See, for example,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194390
Probably, in the next release, the UML environment API will have to make a
more definitive distinction between whether it is working on M2 or M1
level.
Christian
Michael Wahler wrote:
> Michael
Re: OCL queries on UML / M1 level [message #34256 is a reply to message #33869] |
Thu, 26 July 2007 11:57   |
Hi Christian,
thanks for your reply.
Just to make sure I have understood you correctly: once the bugs you
mentioned are fixed, will the result of my M1 level query be "Class c1"
instead of "Instance Specification c1"?
Michael
Christian W. Damus wrote:
> Hi, Michael,
> level.
> Cheers,
> Christian
>> Hi,
>> Thanks,
>> Michael
Re: OCL queries on UML / M1 level [message #34290 is a reply to message #34256] |
Thu, 26 July 2007 14:23  |
Hi, Michael,
The result of
self
should look like
which is what the UML2 label provider produces for the label of an
InstanceSpecification.
To get "Class1 c1", you would need to override this default label provider
implementation. That could be done in the console example, but it's just
an example.
I misunderstood your question, before, as asking whether the result should
be "Class Class1", which had me confused because that would be very odd
(being the *type* of "self"). Sorry about that.
Christian
> Hi Christian,
> Michael
<snip>
Current Time: Sat Jul 19 19:34:06 EDT 2025
Powered by FUDForum. Page generated in 0.52346 seconds
