Comments under VE [message #33179] |
Tue, 27 April 2004 01:52  |
is use Eclipse M8 with the VE-SDK-M1RC1 plugin, all works fine but
the commenttext/doctext have a line break when he put a new method (bean).
* This method initializes jContentPane
* @return javax.swing.JPanel
Is there a config point to disable that (without a line break) ??
thanks ...
Re: Comments under VE [message #35473 is a reply to message #33511] |
Wed, 05 May 2004 06:35  |
Originally posted by: leo_zen.gmx.at
Gili Mendel wrote:
> M.Kroll wrote:
> > Gili Mendel wrote:
> >>M.Kroll wrote:
> >>Which platfrom are you running on?
> > It's running on a Windows-XP Prof. and Java 1.4.2_04
> Open a Bugzilla with this info, and please attach an actual file that re
> produces this symptom.
Was there a ticket opened for this issue? If so, what #? I wanna add also,
that the linebreak is also on automatic generated Events.
Re: Comments under VE [message #587262 is a reply to message #33179] |
Tue, 27 April 2004 08:14  |
M.Kroll wrote:
> Hello,
> thanks ...
Re: Comments under VE [message #587363 is a reply to message #33477] |
Wed, 28 April 2004 08:39  |
Our builds are performed on a Linux machine (with a different \n). Code
is being generated by JavaJet templates, which will be using the Linux
\n for line feed. We are working with the EMF guys (own the JavaJet
technology), at this time, to get dynamic multi platform "\n" support
for JavaJet templates ... but it is not here yet.
Re: Comments under VE [message #588045 is a reply to message #33511] |
FUDForum. Page generated in 0.25870 seconds
