Home » Eclipse Projects » Eclipse Platform » Contribute to Resource Navigator New Submenu
Contribute to Resource Navigator New Submenu [message #330888] |
Fri, 15 August 2008 19:16  |
Originally posted by: dave.dave.net
I am having a hard time trying to add my own newWizard dialogs to the
"new" menu in the resource navigator view.
I am using the popupMenu extension, but I do not know the "objectClass"
to point to or the menubar path. I've tried
"org.eclipse.ui.views.navigator.ResourceNavigator" with the template
popup menu, but that doesn't show the example menu for all the tree
nodes. (The IFile only works for file nodes). Can anyone give me some
pointers on how to do this ?
Thanks, Dave
Re: Contribute to Resource Navigator New Submenu [message #330896 is a reply to message #330890] |
Sat, 16 August 2008 05:20   |
Originally posted by: blah.blah.net
I've already implemented the newWizard dialogs, it shows up under the
appropriate default menus (Select a wizard dialog etc).
What I want to do is in the package explorer context popup menu . I want
to contribute to the entry under new-> myWizard (I.e. when you select a
folder in the resource navigator, the popupmen comes up, you select the
"new" menu, a submenu popups up, where you can select and create
package, java, interface, enum part). I want to attach an action that
calls my own newWizard dialog there.
I know i should be using the org.eclipse.ui.popupMenu extension and
create an action for it that launches my wizard, but i am unsure of the
menuBarPath setting. The most I can find on the net is that is under
"group.new" group but how do I put it under the submenu of "new" ?
Dave
Ed Merks wrote:
> David,
> Shouldn't use be using the newWizards extension point for that?
> <extension point="org.eclipse.ui.newWizards">
> <category
> id="org.eclipse.emf.codegen.ecore.ui.wizardCategory"
> name="%_UI_Wizard_category"/>
> <wizard
> id="org.eclipse.emf.ecore.presentation.EcoreModelWizardID"
> name="%_UI_EcoreModelWizard_label"
> class="org.eclipse.emf.ecore.presentation.EcoreModelWizard"
> category="org.eclipse.emf.codegen.ecore.ui.wizardCategory"
> icon="icons/full/ctool16/NewEcore.gif">
> <description>%_UI_EcoreModelWizard_description</description >
> <selection class="org.eclipse.core.resources.IResource"/>
> </wizard>
> </extension>
> David wrote:
>> Hi
>> "objectClass" to point to or the menubar path. I've tried
>> Thanks, Dave
Re: Contribute to Resource Navigator New Submenu [message #330897 is a reply to message #330896] |
Fri, 15 August 2008 12:32   |
Hi Dave,
You need to call IPageLayout.addNewWizardShortcut(String). This is
usually done when defining a new perspective e.g. see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/eps ilon/plugins/org.eclipse.epsilon.perspective/src/org/eclipse /epsilon/perspective/EpsilonPerspectiveFactory.java?revision =1.1&root=Technology_Project&view=markup
Dimitrios
David wrote:
> Hi
> Dave
> Ed Merks wrote:
>> David,
>> <category
>> <wizard
>> </wizard>
>> </extension>
>> David wrote:
>>> Hi
>>> Thanks, Dave
Re: Contribute to Resource Navigator New Submenu [message #331686 is a reply to message #330897] |
Tue, 16 September 2008 09:36  |
Thanks for the suggestion, but that only does half what I wanted. That
method only adds to the File -> New on the toolbar, but not he popup
menus in the project explorer. (Over the folder icon popup menu etc).
Any ideas ??
Thanks, Dave
Dimitrios Kolovos wrote:
> Hi Dave,
> Cheers,
> Dimitrios
> David wrote:
>> Hi
>> want to contribute to the entry under new-> myWizard (I.e. when you
>> select a folder in the resource navigator, the popupmen comes up, you
>> select the "new" menu, a submenu popups up, where you can select and
>> create package, java, interface, enum part). I want to attach an
>> action that calls my own newWizard dialog there.
>> the menuBarPath setting. The most I can find on the net is that is
>> under "group.new" group but how do I put it under the submenu of "new" ?
>> Dave
>> Ed Merks wrote:
>>> David,
>>> <category
>>> <wizard
>>> </wizard>
>>> </extension>
>>> David wrote:
>>>> Hi
>>>> the "new" menu in the resource navigator view.
>>>> some pointers on how to do this ?
>>>> Thanks, Dave
Current Time: Sun Jul 20 08:41:49 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
