Home » Eclipse Projects » Eclipse Platform » Correct way to get at values in plugin.properties?
Correct way to get at values in plugin.properties? [message #325514] Wed, 20 February 2008 13:03
What is the correct way to get at the values held in plugin.properties?
I can get the values by doing the following; however getDescriptor() and
getResourceBundle() are deprecated?
* @param key
* @return the value associated with the key located in plugin.properties
file.
public static String getString (String key)
GooberPlugin gooberPlugin = GooberPlugin.getDefault ();
IPluginDescriptor pluginDescriptor = gooberPlugin.getDescriptor ();
ResourceBundle plugin_properties = pluginDescriptor.getResourceBundle
return plugin_properties.getString (key);
Previous Topic:How to create Eclipse Watchpoint breakpoints
Next Topic:Eclipse 3.3.1 does not generate java1.5 class files
Current Time: Sun Jul 20 09:34:00 EDT 2025
Powered by FUDForum. Page generated in 0.03514 seconds
