Home » Eclipse Projects » Eclipse Platform » [DataBinding] Using JFace DB for Mapping Object Models
[DataBinding] Using JFace DB for Mapping Object Models [message #325372] Fri, 15 February 2008 13:58 Go to next message
Originally posted by: housh_housh.yahoo.com
JFace DB is usually used for mapping between UI and Model. Is it
possible to used this automatic mapping for this situation:
I have a client-domain-model on an rcp-client. This client-domain-model
is very similar to the domain-model on the ejb-serverside (implemented
with jpa-entities). It is similar, but not exactly the same.
Now everytime I want to sync with the serverside I need some kind of
mapping-mechanism between some two objects "Customer" on the client and
"CustomerEntity" on the server.
Am I thinking in the right direction, that I can somehow use JFace DB
for this problem? If J DB is suited, what do I have to do - implement
any interfaces of Jface DB for the model objects or so?
Could you please give me some specific hints on that?
Thank you very much.
Best,
ex
Re: [DataBinding] Using JFace DB for Mapping Object Models [message #325383 is a reply to message #325372] Fri, 15 February 2008 17:12 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
exquisitus wrote:
> Hello,
Didn't you ask the same question on the eclipse.newcomer group
yesterday? Please see my response there.
Eric
Re: [DataBinding] Using JFace DB for Mapping Object Models [message #325385 is a reply to message #325383] Fri, 15 February 2008 18:26 Go to previous messageGo to next message
Eric Rizzo wrote:
> exquisitus wrote:
>> Hello,
> Eric
Hi Eric,
yes I did.
I was hoping to get a little more help here since I didn't exactly
understand your answer.
Could you please be a litte more precise.
Thanx,
ex
Re: [DataBinding] Using JFace DB for Mapping Object Models [message #325388 is a reply to message #325385] Fri, 15 February 2008 19:33 Go to previous message
exquisitus wrote:
> Eric Rizzo wrote:
>> exquisitus wrote:
>>> Hello,
>> Eric
> Hi Eric,
> yes I did.
> Thanx,
> ex
The answer is yes, you can bind model-to-model in DataBinding just as
well as binding model-to-UI.
What I suggest is that you go through your model classes and make sure
the following patterns are followed:
* Use get/set method names for property accessor and mutator methods.
* They should implement the following methods:
addPropertyChangeListener(PropertyChangeListener)
removePropertyChangeListener(PropertyChangeListener)
String propertyName, PropertyChangeListener)
With these methods in place, BeansObservables will be able to monitor
your model objects for changes, so that when one side of the model
changes, the other side can be updated accordingly.
Hope this helps,
Matthew
Previous Topic:Using scp task in ant build file
Next Topic:MessageDialog raises a NullPointerException
Current Time: Sat Jul 19 21:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.24721 seconds
