Home » Eclipse Projects » Eclipse Platform » label update for command/handler/contribution
label update for command/handler/contribution [message #323701] Sun, 06 January 2008 18:06 Go to next message
for "old" retargetable actions, there were the option allowLabelUpdate and
an action could set another label for its menu item (as example).
Is there a similar function for the new menu contribution mechanism
(org.eclipse.ui.menus) and command handlers? So, that the active handler can
add additional info to its menu item label?
Teddy
Re: label update for command/handler/contribution [message #323784 is a reply to message #323701] Tue, 08 January 2008 10:58 Go to previous messageGo to next message
A handler can implement org.eclipse.ui.commands.IElementUpdater. That
will allow the handler access to an object with setText(*) and
setImageDescriptor(*) methods.
A call to ICommandService#refreshElements(*) will allow the active
handler to update the label.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: label update for command/handler/contribution [message #323930 is a reply to message #323784] Sun, 13 January 2008 13:57 Go to previous messageGo to next message
Paul,
thank you very much! That's what I was looking for.
I works fine, but on startup. It is not updated automatically, calling
refreshElements in constructor of the handler is too early. As workaround, I
call it on first request of isEnabled. Is it a bug?
Teddy
"Paul Webster" <pwebster@ca.ibm.com> schrieb im Newsbeitrag
news:fm06gf$b7s$3@build.eclipse.org...
>A handler can implement org.eclipse.ui.commands.IElementUpdater. That will
> A call to ICommandService#refreshElements(*) will allow the active handler
> PW
> Paul Webster
Re: label update for command/handler/contribution [message #323955 is a reply to message #323930] Mon, 14 January 2008 12:39 Go to previous messageGo to next message
Teddy Walker wrote:
> Paul,
> workaround, I call it on first request of isEnabled. Is it a bug?
On startup your handler would not normally be loaded, but it would be
proxied (probably by a HandlerProxy). If your handler was the default
handler it would be the active handler.
If you are worried that the menu item is not being updated right away,
that is normal (since your handler won't be loaded until a user action).
Or is it a slightly different scenario than I outline here?
PW
Paul Webster
Re: label update for command/handler/contribution [message #324345 is a reply to message #323955] Wed, 23 January 2008 05:53 Go to previous messageGo to next message
Hi Paul,
It is a toolbar button and the default handler. The handler object is
created and the method #isEnabled() is called via HandlerProxy#isEnabled() .
It seems, it is not updated, after the proxy loaded the real handler?
Ciao,
Teddy
news:fmg6ko$b0a$2@build.eclipse.org...
> Teddy Walker wrote:
>> Paul,
> PW
> Paul Webster
Re: label update for command/handler/contribution [message #324358 is a reply to message #324345] Wed, 23 January 2008 09:57 Go to previous messageGo to next message
Teddy Walker wrote:
> Hi Paul,
What is not updated after the proxy loads the real handler? The enabled
state (if you change it in your handler, you need to fire a property
change event)? Or the call to refreshElements(*)?
PW
Paul Webster
Re: label update for command/handler/contribution [message #324412 is a reply to message #324358] Thu, 24 January 2008 04:57 Go to previous messageGo to next message
refreshElements(*) is not updated after the proxy loads the real handler.
Should it be called (by the proxy)?
(The enablement state is correct, the real handler is requested.)
Re: label update for command/handler/contribution [message #324428 is a reply to message #324412] Thu, 24 January 2008 09:31 Go to previous message
> handler. Should it be called (by the proxy)?
Right, the handler proxy won't call refresh elements (that's been left
to the developer or the handler implementation itself). Maybe open a
bug at:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[Contributions]
It sounds like having the HandlerProxy ask for a refresh if it
instantiates a handler that implements IElementUpdater might be reasonable.
PW
Paul Webster
Previous Topic:Is there a eclipse plugin which can compile Java source to class files?
Next Topic:Plugins installed but classes not found
Current Time: Sat Jul 19 16:37:54 EDT 2025
Powered by FUDForum. Page generated in 0.07259 seconds
