Home » Eclipse Projects » Eclipse Platform » Eclipse UI fails to repaint after processing a click on my view
Eclipse UI fails to repaint after processing a click on my view [message #323931] Sun, 13 January 2008 19:21 Go to next message
Hi!
I have a view which contains an org.eclipse.draw2d.FigureCanvas with
several figures in it. Those figures listen to mouse clicks. Inside
the mousePressed() method I sometimes open windows like
MessageDialogs etc. If a dialog was opened it may happen that the
complete Eclipse UI gets white or just the toolbars and my view get
white. I think Eclipse wants to redraw everything but fails to do
so. Is there a method which redraws the whole Eclipse UI? Or is
there something fundamentally wrong with my code (opening Dialogs
inside the mousePressed method)?
Any suggestions?
Nicolai
I'm using an evaluation license of nemo since 133 days.
You should really try it!
http://www.malcom-mac.com/nemo
Re: Eclipse UI fails to repaint after processing a click on my view [message #323944 is a reply to message #323931] Mon, 14 January 2008 06:54 Go to previous messageGo to next message
Nicolai,
If you open a blocking dialog, that likely means your mouse event
doesn't finish processing until the dialog is completed and that's
perhaps not a good thing. Consider using Display.asyncExec to open your
dialog a little bit later and so that the mouse event processing can
return to the caller...
Nicolai Kamenzky wrote:
> Hi!
> Any suggestions?
> Nicolai
Re: Eclipse UI fails to repaint after processing a click on my view [message #323952 is a reply to message #323944] Mon, 14 January 2008 12:26 Go to previous message
Thanks a lot, Ed!
That did it.
For those searching the archives here is a very interesting
article related to the problem I had:
< http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform
doc.isv/guide/swt_threading.htm>
Nicolai
Previous Topic:Windows Linux swt_awt bridge flickering removed with Java 1.6.0.04 but....
Next Topic:Any example for a Form Editor to edit Objects
Current Time: Sat Jul 19 12:24:09 EDT 2025
Powered by FUDForum. Page generated in 0.48324 seconds
