Home » Eclipse Projects » Eclipse Platform » Setting document text without losing cursor position?
Setting document text without losing cursor position? [message #323921] Sun, 13 January 2008 05:48 Go to next message
Originally posted by: sascha.pasalacqua.de
we are currently working on a simple text editor. We provide our own
simple document provider and document (which is just an extended Document
(class)).
There are times when we have to replace the whole text of the document by
calling IDocument.set(...).
The problem: After calling .set(...) the text editor scrolls to the top
and sets the cursor to line 1.
We would like to avoid this and keep the current cursor position since
often the new text is quite similar to the replaced text.
But how to ? Why does the editor scroll up to the top at all ?
Thanks in advance!
Sascha
Re: Setting document text without losing cursor position? [message #323984 is a reply to message #323921] Tue, 15 January 2008 08:39 Go to previous message
Sascha wrote:
> Document (class)).
> by calling IDocument.set(...).
> top and sets the cursor to line 1.
If it is quite similar, why don't you change it using text edits instead
of replacing the whole document? If the position is really the same you can
1. get the selection from the editor's selection provider
2. replace the doc
3. set the selection from step 1 to the selection provider
Dani
> Thanks in advance!
> Sascha
Previous Topic:Interface Selection Wizard Component
Next Topic:Autocomplete takes ages to load javadocs
Current Time: Sat Jul 19 19:59:37 EDT 2025
Powered by FUDForum. Page generated in 0.03438 seconds
