Home » Eclipse Projects » Eclipse Platform » Accessing JRE extensions from Eclipse Plugin
Accessing JRE extensions from Eclipse Plugin [message #323857] Thu, 10 January 2008 09:35 Go to next message
Originally posted by: tas.frangoullides.barclaysglobal.com
I'm developing an application that needs COM port communication and I'm
trying to do this using the Sun Java Communications API.
I'm able to install the the Java Communications API files into a JRE and
set this as the target JRE and develop code against the API. Running the
code as a java application works as expected.
However, if I try run the same code within an Eclipse Application (or
JUnit Plugin Test) the code fails with a NoClassDefFoundError. Apparently
the launched eclipse environment can't see the additional libraries.
Is there something special I need to do to the launch configuration?
Thanks for your help,
Tas
java.lang.NoClassDefFoundError: javax/comm/NoSuchPortException
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2365)
at java.lang.Class.getMethod0(Class.java:2611)
at java.lang.Class.getMethod(Class.java:1579)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.getTest(JUnit3TestLoader.java:99)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestLoade r.loadTests(JUnit3TestLoader.java:59)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
at
org.eclipse.pde.internal.junit.runtime.CoreTestApplication.r un(CoreTestApplication.java:24)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Accessing JRE extensions from Eclipse Plugin [message #323858 is a reply to message #323857] Thu, 10 January 2008 09:49 Go to previous messageGo to next message
I'm not an OSGi-Expert but if those are not part of the standard JRE I
think you need to add import statements to your MANIFEST.MF.
Do they need to be installed in the JRE or why don't you ship them with
your plugin directly?
Tom
Tas Frangoullides schrieb:
> Apparently the launched eclipse environment can't see the additional
> libraries.
> Tas
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Accessing JRE extensions from Eclipse Plugin [message #323888 is a reply to message #323858] Fri, 11 January 2008 04:14 Go to previous messageGo to next message
Hi Tom,
Thanks for helping out.
I tried adding an import-package statement to the MANIFEST.MF but I get
the following buildtime error in the manifest editor "No Available Bundle
Exports 'javax.comm'. This kind of makes sense becuase the library is not
in a bundle - it's part of the JRE.
I would like to package the communication API into a plugin if possible
but I don't know how to do that for this type of library. There are a few
components to the install.
1) Win32com.dll - this goes in the bin folder
2) javax.com.properties - this goes in the lib floder
3) comm.jar - this goes in the lib/ext folder
The stangest things is that the libraries are visible to the compiler,
everything compiles and that running my tests as "JUnit Test" works fine.
It's only when I run as "JUnit Plug-in Test" that things don't work and I
get the NoClassDefFoundError.
Tas
Re: Accessing JRE extensions from Eclipse Plugin [message #323911 is a reply to message #323888] Sat, 12 January 2008 10:31 Go to previous message
Originally posted by: rkuzsma.gmail.com
I have a little experience trying to get native DLLs and third party .jar
files to work. Here's an example plug-in project that exports a .jar file
so other plug-ins can use it.
Example build.properties looks like this:
source.. = .
output.. = .
bin.includes = META-INF/,\
ThirdParty.jar
ThirdParty.jar MUST live in the root directory of the plug-in.
META-INF/MANIFEST.MF looks like this:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: My ThirdParty Jar Wrapper Plug-in
Bundle-SymbolicName: com.myCompany.lib3rdparty
Bundle-Version: 1.0.0.0
Bundle-Vendor: My Company, Inc.
Bundle-Localization: plugin
Eclipse-LazyStart: true
Bundle-ClassPath: ThirdParty.jar
Export-Package: com.thirdParty.package1,
com.thirdParty.package2,
com.thirdParty.package3
As far as I know, the .classpath file does NOT need to explicitly export
the ThirdParty.jar, too, i.e.:
<classpath>
<classpathentry kind="src" path=""/>
<classpathentry exported="true" kind="lib" path="ThirdParty.jar"/>
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins"/>
<classpathentry kind="output" path=""/>
</classpath>
But it doesn't hurt.
Plug-ins are built using the PDE build, Java projects are build using the
Java build. Both have different ways of specifying a classpath
(essentially, Java projects use .classpath, Plug-in projects use
Manifest.mf).
As for accessing the native DLL: There's a Manifest.mf header called
Bundle-NativeCode that you might have to use. Although, I've had more
success just putting the native .dll in my plug-in's root. Also, to
simplify your life, don't include any .java source files in this Third
Party plug-in project.
And, if you're installing the plug-in project on someone's machine, do not
install the whole plug-in as a .JAR. Instead, unpack the plug-in to a
folder in the eclipse/plugins directory. Or, if there's a corresponding
feature project, specify unpack="true" in it. At least for me in Eclipse
3.2, I can only get third party .jar files and native dlls to load if I
install their host plug-in into its own folder.
Previous Topic:existing versions of plugin causing build conflicts
Next Topic:PDE finding source for BND-wrapped jars
Current Time: Sat Jul 19 05:39:51 EDT 2025
Powered by FUDForum. Page generated in 0.03321 seconds
