Home » Eclipse Projects » Eclipse Platform » Not related java.lang.reflect.InvocationTargetException
Not related java.lang.reflect.InvocationTargetException [message #323726] |
Mon, 07 January 2008 07:15  |
I encounter the below exception when opening an editor.
In my RCP application a current navigation is
opening an editor E1
From this editor : close E1; open E2
From E2 ; close E2; open E3;
From E3 : close E3; open E1.
... and so on.
The exception doesn't come immediatly, but after N (10, 15 ?) such close
/ open executions.
Because the exception doesn't come the first time, but after N right
execution of the process, I suspect a resource / memory problem.
However, I have no elements with the stack trace to track the native
problem.
Any idea ?
Any idea about more log information than the sole console (-logConsole
option set)
Thanks in advance.
Richard
My code to open and close Editors
avec
iEditorInput extends org.eclipse.ui.IEditorInput
twActionOpenEditor extends org.eclipse.jface.action.Action
public static void OpenEditor ( String sName,
iEditorInput TheEditorInput)
Event wMyEventData = new Event ();
wMyEventData.data = TheEditorInput;
twActionOpenEditor wActionOpenEditor
= (twActionOpenEditor) mActionCatalog.get (sName);
if (wActionOpenEditor != null)
wActionOpenEditor.runWithEvent (wMyEventData);
else
InfoEditorInexistant (sName);
public static void CloseActiveEditor ()
IWorkbenchPage WorkbenchPage
= PlatformUI.getWorkbench ()
.getActiveWorkbenchWindow ()
.getActivePage();
if (WorkbenchPage == null)
return;
WorkbenchPage.closeEditor (WorkbenchPage.getActiveEditor(), false);
The Exception
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
strip.runtime.cStripRuntimeFactory.GenericMethodCall(cStripR untimeFactory.java:32)
at
strip.runtime.jface.cTwingTableDoubleClicListener.mouseDoubl eClick(cTwingTableDoubleClicListener.java:43)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:182)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at wwprogres01.intro.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
Caused by: java.lang.IllegalAccessError: class
sun.reflect.GeneratedConstructorAccessor73 cannot access its superclass
sun.reflect.ConstructorAccessorImpl
at sun.misc.Unsafe.defineClass(Native Method)
at sun.reflect.ClassDefiner.defineClass(ClassDefiner.java:45)
at
sun.reflect.MethodAccessorGenerator$1.run(MethodAccessorGene rator.java:381)
at
sun.reflect.MethodAccessorGenerator.generate(MethodAccessorG enerator.java:377)
at
sun.reflect.MethodAccessorGenerator.generateConstructor(Meth odAccessorGenerator.java:76)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:30)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at org.xml.sax.helpers.NewInstance.newInstance(NewInstance.java :51)
at
org.xml.sax.helpers.XMLReaderFactory.loadClass(XMLReaderFact ory.java:187)
at
org.xml.sax.helpers.XMLReaderFactory.createXMLReader(XMLRead erFactory.java:180)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:311)
at org.jdom.input.SAXBuilder.build(SAXBuilder.java:464)
at
strip.dombuilder.cDOMTreeBuilder.BuildDOMTreeUsingSAX(cDOMTr eeBuilder.java:143)
at
strip.GUI.ECLIPSE.editors.cEclipseEditor.PrologueEclipseEdit or(cEclipseEditor.java:139)
at
strip.GUI.ECLIPSE.editors.cEclipseEditor.init(cEclipseEditor .java:240)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
at
strip.GUI.ECLIPSE.twActionOpenEditor.runWithEvent(twActionOp enEditor.java:99)
at
strip.GUI.ECLIPSE.twActionFactory.OpenEditor(twActionFactory .java:56)
at
wwprogres01.BRAIN.SearchPersonBrain.TblDataOnDoubleClic(Sear chPersonBrain.java:111)
... 32 more
Re: Not related java.lang.reflect.InvocationTargetException [message #323729 is a reply to message #323726] |
Mon, 07 January 2008 07:36   |
--------------060600070703000602020608
Richard,
I know in the past that I've seen things like this affected by the
Thread.getContextClassLoader so the behavior you see might be a
consequence of which thread is doing the work and what other
applications have done to the context class loader. We used to have to
write code like this to make sure the "right" class loader was available
to the parser factory...
public XSDParser()
* ClassLoader previousClassLoader =
Thread.currentThread().getContextClassLoader();
try
Thread.currentThread().setContextClassLoader(getClass().getC lassLoader());*
SAXParserFactory saxParserFactory =
SAXParserFactory.newInstance();
saxParserFactory.setNamespaceAware(true);
saxParserFactory.setValidating(false);
saxParserFactory.setFeature("http://xml.org/sax/features/validation",
false);
saxParserFactory.setFeature("http://xml.org/sax/features/namespaces",
true);
saxParserFactory.setFeature("http://xml.org/sax/features/namespace-prefixes",
true);
saxParser = saxParserFactory.newSAXParser();
saxParser.setProperty("http://xml.org/sax/properties/lexical-handler",
this);
catch (SAXException exception)
fatalError(exception);
catch (ParserConfigurationException exception)
* finally
Thread.currentThread().setContextClassLoader(previousClassLo ader);
Richard Desbiolles wrote:
> ... and so on.
> close / open executions.
> problem.
> Any idea ?
> option set)
> Thanks in advance.
> Richard
> avec
> else
> .getActivePage();
> return;
> The Exception
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> superclass sun.reflect.ConstructorAccessorImpl
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Richard,<br>
<br>
available to the parser factory...<small><br>
</small>
<blockquote><small> public XSDParser()</small><br>
<small> {</small><br>
<b><small> ClassLoader previousClassLoader =
Thread.currentThread().getContextClassLoader();</small><br >
<small> try </small><br>
<small>
Thread.currentThread().setContextClassLoader(getClass().getC lassLoader()); </small></b><br>
<br>
<small> SAXParserFactory saxParserFactory =
SAXParserFactory.newInstance();</small><br>
<small> saxParserFactory.setNamespaceAware(true);</small><br>
<small> saxParserFactory.setValidating(false);</small><br>
<br>
<small>
saxParserFactory.setFeature(<a class="moz-txt-link-rfc2396E" href="http://xml.org/sax/features/validation">"http://xml.org/sax/features/validation"</a>,
false);</small><br>
<small>
saxParserFactory.setFeature(<a class="moz-txt-link-rfc2396E" href="http://xml.org/sax/features/namespaces">"http://xml.org/sax/features/namespaces"</a>,
true);</small><br>
<small>
saxParserFactory.setFeature(<a class="moz-txt-link-rfc2396E" href="http://xml.org/sax/features/namespace-prefixes">"http://xml.org/sax/features/namespace-prefixes"</a>,
true);</small><br>
<br>
<small> saxParser = saxParserFactory.newSAXParser();</small><br>
<br>
<small>
saxParser.setProperty(<a class="moz-txt-link-rfc2396E" href="http://xml.org/sax/properties/lexical-handler">"http://xml.org/sax/properties/lexical-handler"</a>,
this);</small><br>
<small> } </small><br>
<small> catch (SAXException exception)</small><br>
<small> fatalError(exception);</small><br>
<small> }</small><br>
<small> catch (ParserConfigurationException exception) </small><br>
<b><small> finally </small><br>
<small>
Thread.currentThread().setContextClassLoader(previousClassLo ader); </small><br>
<small> }</small></b><br>
</blockquote>
<br>
<blockquote cite="mid:flt559$cdk$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
... and so on.
<br>
<br>
<br>
<br>
<br>
<br>
problem.
<br>
<br>
Any idea ?
<br>
<br>
option set)
<br>
<br>
Thanks in advance.
<br>
<br>
Richard
<br>
<br>
<br>
<br>
avec
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
else
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
.getActivePage();
<br>
<br>
return;
<br>
<br>
<br>
<br>
The Exception
<br>
<br>
<br>
<br>
<br>
at
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
at
<br>
at
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
at
<br>
... 32 more
<br>
</blockquote>
<br>
</body>
</html>
--------------060600070703000602020608--
Re: Not related java.lang.reflect.InvocationTargetException [message #323736 is a reply to message #323729] |
Mon, 07 January 2008 09:57   |
Thanks Ed for your response.
I do what you propose, but now gets an other exception related to thread
hierarchy and hibernate.
regards,
Richard
what I did
try
// MAKE THE INITIAL JOB
wPart = WorkbenchPage.openEditor ((iEditorInput) event.data, mEditorID);
catch (Exception ee)
// TODO Auto-generated catch block ee.printStackTrace();
finally
// The exception
!ENTRY org.eclipse.ui.workbench 4 2 2008-01-07 14:48:32.675
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.ExceptionInInitializerError
at
org.hibernate.engine.query.QueryPlanCache.getNativeSQLQueryP lan(QueryPlanCache.java:114)
at
org.hibernate.impl.AbstractSessionImpl.getNativeSQLQueryPlan (AbstractSessionImpl.java:137)
at
org.hibernate.impl.AbstractSessionImpl.list(AbstractSessionI mpl.java:142)
at org.hibernate.impl.SQLQueryImpl.list(SQLQueryImpl.java:150)
at strip.database.hibernate.cCurseur.ExecuteQuery(cCurseur.java :343)
at
strip.DICO.Components.twing.cRubCmbSTRING.RemplirCmb(cRubCmb STRING.java:231)
at
strip.DICO.Components.twing.cRubCmbSTRING.Rafraichit(cRubCmb STRING.java:108)
at
strip.DICO.Components.twing.cRubComponent.Rafraichit(cRubCom ponent.java:349)
at strip.forms.cRootBaseForm.RafraichitForm(cRootBaseForm.java: 1166)
at
strip.forms.cRootBaseForm.SetObjectsStateFromDico(cRootBaseF orm.java:727)
at
strip.forms.cRootBaseForm.SetObjectsStateFromDico(cRootBaseF orm.java:542)
at
strip.GUI.ECLIPSE.editors.cEclipseEditor.EpilogueEclipseEdit or(cEclipseEditor.java:226)
at
strip.GUI.ECLIPSE.editors.cEclipseEditor.setFocus(cEclipseEd itor.java:254)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:318)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 127)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:614)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:609)
at
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3380)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:602)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2730)
at
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
at
at
at
strip.GUI.ECLIPSE.twActionOpenEditor.runWithEvent(twActionOp enEditor.java:112)
at strip.GUI.ECLIPSE.twActionFactory.OpenEditor(twActionFactory .java:57)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: Invalid class
loader hierarchy. You have more than one version of
'org.apache.commons.logging.Log' visible, which is not allowed. (Caused
by org.apache.commons.logging.LogConfigurationException: Invalid class
'org.apache.commons.logging.Log' visible, which is not allowed.) (Caused
'org.apache.commons.logging.Log' visible, which is not allowed.))
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:543)
at
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:235)
at
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:209)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :351)
at
org.hibernate.engine.query.NativeSQLQueryPlan.<clinit>(NativeSQLQueryPlan.java:36)
... 64 more
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:397)
at
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:529)
... 68 more
Caused by: org.apache.commons.logging.LogConfigurationException: Invalid
class loader hierarchy. You have more than one version of
at
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:385)
... 69 more
Ed Merks a écrit :
> Richard,
> public XSDParser()
> try
> false);
> true);
> true);
> this);
> * finally
>> Hi,
>> ... and so on.
>> problem.
>> Any idea ?
>> option set)
>> Thanks in advance.
>> Richard
>> avec
>> else
>> .getActivePage();
>> return;
>> The Exception
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 32 more
Re: Not related java.lang.reflect.InvocationTargetException [message #323739 is a reply to message #323736] |
Mon, 07 January 2008 10:20   |
--------------040206030101060906000604
Richard,
Where did you try this? It's best to try it with the narrowest scope
possible which looks to be in
> thread hierarchy and hibernate.
> regards,
> Richard
> what I did
> try
> finally
> // The exception
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> (Caused by org.apache.commons.logging.LogConfigurationException:
> Invalid class loader hierarchy. You have more than one version of
> at
> at
> at
> at
> ... 64 more
> at
> at
> ... 68 more
> at
> ... 69 more
> Ed Merks a
Re: Not related java.lang.reflect.InvocationTargetException [message #323745 is a reply to message #323739] |
Mon, 07 January 2008 11:12   |
Hi Ed,
OK, I did the changes in cDOMTreeBuilder class and it now seems to be
all right.
However, I'm not sure to really understand in which situations it's
necessary to do this operation.
Anyway, thanks a lot for your very efficient help.
best regards,
Richard
Ed Merks a écrit :
> Richard,
>> regards,
>> Richard
>> what I did
>> try
>> finally
>> // The exception
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 64 more
>> at
>> at
>> ... 68 more
>> at
>> ... 69 more
>> Ed Merks a écrit :
>>> Richard,
>>> to write code like this to make sure the "right" class loader was
>>> public XSDParser()
>>> try
>>> false);
>>> true);
>>> true);
>>> this);
>>> * finally
>>>> Hi,
>>>> ... and so on.
>>>> problem.
>>>> Any idea ?
>>>> (-logConsole option set)
>>>> Thanks in advance.
>>>> Richard
>>>> avec
>>>> else
>>>> .getActivePage();
>>>> return;
>>>> The Exception
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 32 more
Re: Not related java.lang.reflect.InvocationTargetException [message #323753 is a reply to message #323745] |
Mon, 07 January 2008 11:51  |
--------------020206060808020608010807
Richard,
Imagine how much time I saved you trying to figure out that magical
incantation. Did you know Eclipse accepts donations? :-P
<http://www.eclipse.org/donate/donorlist.php>
> Hi Ed,
> all right.
> best regards,
> Richard
> Ed Merks a
Current Time: Sun Jul 20 12:28:02 EDT 2025
Powered by FUDForum. Page generated in 0.32021 seconds
