Home » Eclipse Projects » Eclipse Platform » How To Share A POJO Across Plugins?
How To Share A POJO Across Plugins? [message #323616] Thu, 03 January 2008 22:04 Go to next message
Originally posted by: anupgokhale.rediffmail.com
I have two plugins Plugin1 & Plugin2 in a RCP app. I want Plugin2 to have
read/write access to a POJO created in Plugin1. Any pointers on how to do
this?
Anup Gokhale
Re: How To Share A POJO Across Plugins? [message #323617 is a reply to message #323616] Thu, 03 January 2008 22:47 Go to previous messageGo to next message
Plugin2 needs to have a dependency on Plugin1.
Open the project manifest (select the project, right-click PDE Tools ->
Open Manifest).
Select the dependencies tab and add Plugin1 as a dependency.
Then it just works.
> have read/write access to a POJO created in Plugin1. Any pointers on how
> to do this?
> Regards,
> Anup Gokhale
Re: How To Share A POJO Across Plugins? [message #323619 is a reply to message #323617] Fri, 04 January 2008 00:10 Go to previous messageGo to next message
Thanks Francis. But my problem is a bit more complicated. In some
installations of my RCP app, both the plugins will be present, but in some
installations only Plugin2 will be present. So essentially what i need to
do is to access a POJO from Plugin1 ONLY if it has been installed. I guess
I can used the extension points mechanism to do this, but have absolutely
no idea on how to proceed.
Anup Gokhale
> Open Manifest).
> Then it just works.
>> to do this?
Re: How To Share A POJO Across Plugins? [message #323620 is a reply to message #323619] Fri, 04 January 2008 01:14 Go to previous messageGo to next message
> Regards,
> Anup Gokhale
Hello Anup,
This sounds like it could use OSGi services. You could register your POJO
as a service from Plugin1 (see
http://www.eclipsezone.com/eclipse/forums/t90688.html).
Plugin2 can then "consume" this service (see
http://www.eclipsezone.com/eclipse/forums/t90796.html and
http://www.eclipsezone.com/eclipse/forums/t91059.html).
Hth!
Ron
Re: How To Share A POJO Across Plugins? [message #323621 is a reply to message #323620] Fri, 04 January 2008 01:30 Go to previous messageGo to next message
Ron Bermejo wrote:
> Hello Anup,
> Hth!
> Ron
Ahhhhhh... seems like quite a bundle (no pun intended!) for me to read and
digest. There goes my lunch break! Thanks to you Ron.
Anup Gokhale
Re: How To Share A POJO Across Plugins? [message #323644 is a reply to message #323619] Fri, 04 January 2008 12:46 Go to previous message
You can set Plugin1 as optional (right click on Plugin1 in the
Dependencies Tab of the Manifest editor and select Properties).
You can check if Plugin1 exists using
Platform.getBundle("Plugin1") != null
Snjeza
> some installations only Plugin2 will be present. So essentially what i
> need to do is to access a POJO from Plugin1 ONLY if it has been
> installed. I guess I can used the extension points mechanism to do this,
> but have absolutely no idea on how to proceed.
> Regards,
> Anup Gokhale
>> -> Open Manifest).
>> Then it just works.
>>> how to do this?
Previous Topic:SWT-Swing Problem!
Next Topic:Debugger very very slow.
Current Time: Sat Jul 19 16:53:02 EDT 2025
Powered by FUDForum. Page generated in 0.04125 seconds
