Home » Eclipse Projects » Eclipse Platform » Storing objects as preferences
Storing objects as preferences [message #323502] Sun, 23 December 2007 05:15 Go to next message
Hi.
What is the best way to store data structures and custom object as plugin
preferences? The PreferenceStore provided by Eclipse can handle only
primitive types plus strings: even arrays are not supported.
Thanks.
Lorenzo Dalla Vecchia
Re: Storing objects as preferences [message #323503 is a reply to message #323502] Sun, 23 December 2007 08:24 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Use a serializer and store them as strings.
Derek
Lorenzo Dalla Vecchia wrote:
> Hi.
> plugin preferences? The PreferenceStore provided by Eclipse can handle
> only primitive types plus strings: even arrays are not supported.
> Thanks.
Re: Storing objects as preferences [message #323534 is a reply to message #323503] Wed, 26 December 2007 16:33 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:fklni8$qvj$1@build.eclipse.org...
That's one approach. If the strings would be of unwieldy length, another
approach is to serialize the preferences into separate files. You can get
the appropriate file locations for per-plugin (workspace) settings from
Platform.getStateLocation(), or for per-project settings from
ProjectScope.getLocation().
There is some discussion of this at
http://wiki.eclipse.org/FAQ_How_do_I_store_extra_properties_ on_a_resource%3F
Re: Storing objects as preferences [message #323535 is a reply to message #323534] Wed, 26 December 2007 16:36 Go to previous messageGo to next message
"Walter Harley" <wharley@bea.com> wrote in message
news:fkuhc2$esd$1@build.eclipse.org...
> http://wiki.eclipse.org/FAQ_How_do_I_store_extra_properties_ on_a_resource%3F .
I should also mention that another alternative is to use hierarchical
preferences. Preference nodes in Eclipse can contain nested nodes, so if
for instance you have a setting whose "value" is actually a map of strings,
you can make the setting be a node and nest the individual strings inside
it.
You can look at the code in org.eclipse.jdt.apt.core.AptConfig for an
example of how to do this.
Re: Storing objects as preferences [message #323551 is a reply to message #323503] Thu, 27 December 2007 19:45 Go to previous message
Originally posted by: games.insight.com
Another approach would be to use Base64. I've used this approach to store
encrypted passwords, which are byte arrays.
> Derek
>> Hi.
>> Thanks.
Previous Topic:Java Debug Problem
Next Topic:Error has occured while closing workbench....
Current Time: Sun Jul 20 13:27:18 EDT 2025
Powered by FUDForum. Page generated in 1.09712 seconds
