Home » Eclipse Projects » Eclipse Platform » Update error: Digest could not be parsed
Update error: Digest could not be parsed [message #319004] Thu, 09 August 2007 15:02 Go to next message
I am getting consistent errors whenever I try to search for updates to my
Eclipse components. Unfortunately, the information does not include the
specific component that is causing the update to abort. Here is the error
info from the log file:
eclipse.buildId=I20070503-1400
java.version=1.5.0_07
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/erict/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch x86 -keyring
/Users/erict/.
eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.update.core 4 0 2007-08-07 23:34:48.441
!MESSAGE Digest could not be parsed:Element type "includes" must be
followed by
either attribute specifications, ">" or "/>".
I suspect that there is a bad config file on one of the update sites, but
I'm damned if I can figure out which one. This is quite tedious.
Re: Update error: Digest could not be parsed [message #319018 is a reply to message #319004] Thu, 09 August 2007 16:26 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Check out platform.xml in the .metadata site (think it's somewhere in update) as well as the various sites in feature.xml.
One way of tying these problems down is to install a network sniffer and/or proxy that you can point Eclipse to; that way, you can see the output as it happens. It's possible that you're getting an HTML 404 back. See e.g. The Grinder http://grinder.sourceforge.net
Alex.
Re: Update error: Digest could not be parsed [message #319021 is a reply to message #319004] Thu, 09 August 2007 17:02 Go to previous messageGo to next message
Originally posted by: zx.us.ibm.com
It's a bad digest produced by SiteOptimizer on one of the update
sites... from the looks of it... how about you select your own mirror
and download from another site?
~ Chris
Re: Update error: Digest could not be parsed [message #319023 is a reply to message #319021] Fri, 10 August 2007 00:06 Go to previous message
OK, how do I configure which mirror sites eclipse will use?
Previous Topic:CommonNavigator and Properties View
Next Topic:Converting tabs to spaces - multiline indent
Current Time: Sun Jul 20 19:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.03922 seconds
