Home » Eclipse Projects » Eclipse Platform » Get active workbench part in Command IHandler
Get active workbench part in Command IHandler [message #318875] Wed, 08 August 2007 08:54 Go to next message
I wanna get access to the currently active workbench part when my
command handler is called. I can see that somewhere in
ExecutionEvent.applicationContext it is hidden in a HashMap. But how do
I access this value in a API conform way? Is there any documentation
about the Workbench's applicationContext available?
Thanks in advance,
Phil
Re: Get active workbench part in Command IHandler [message #318950 is a reply to message #318875] Thu, 09 August 2007 09:08 Go to previous message
Philipp Kursawe wrote:
> Hello,
In 3.3 you can use HandlerUtil to extract information from the execution
event, the methods are named and typed, and there is usually a form that
throws an exception and a form that just returns null.
In 3.2 most of the same information is there, but you need to extract it
manually. With some checks:
IWorkbenchPart activePart = null;
if (event.getApplicationContext() instanceof IEvaluationContext) {
IEvaluationContext app = (IEvaluationContext) event
.getApplicationContext();
Object obj = app.getVariable(ISources.ACTIVE_PART_NAME);
if (obj instanceof IWorkbenchPart) {
activePart = (IWorkbenchPart) obj;
http://wiki.eclipse.org/Command_Core_Expressions has an explanation of
the variables available through ISources.
Later,
PW
Paul Webster
Previous Topic:Problems view: How to group items programmatically?
Next Topic:What kind of schedulingrule to use?
Current Time: Sun Jul 20 08:52:14 EDT 2025
Powered by FUDForum. Page generated in 0.03902 seconds
