Home » Archived » DSDP - Mobile Tools for Java (MTJ) » MTJ overwriting build.properties
MTJ overwriting build.properties [message #31493] Tue, 30 June 2009 12:37 Go to next message
I am finding that the latest version of MTJ is always trying to
overwrite my build.properties file. We store a lot of important build
information here so this is not good. Is there a reason for this behaviour?
cheers
Re: MTJ overwriting build.properties [message #31528 is a reply to message #31493] Tue, 30 June 2009 18:39 Go to previous messageGo to next message
Hi teknokrat,
MTJ stores build configurations for each runtime configuration (device)
you have on your project inside the build.properties file within the
project's root. This feature allow developers to select which files are
packaged on each device package. Did you create this file yourself ??
Please look at
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .mtj.doc.user/html/gettingstarted/gettingstarted.html
David Marques
> cheers
Re: MTJ overwriting build.properties [message #31563 is a reply to message #31528] Thu, 02 July 2009 06:09 Go to previous messageGo to next message
David Marques wrote:
> Hi teknokrat,
> Please look at
yes, and thats the problem. Why doesn't it use its own file instead of
co-opting build.properties which is usually used to setup properties for
Ant?
> Regards,
> David Marques
>> behaviour?
>> cheers
Re: MTJ overwriting build.properties [message #31593 is a reply to message #31563] Thu, 02 July 2009 07:13 Go to previous messageGo to next message
Hi teknokrat,
Well the solution was designed to work like that. My tip for you is
creating a build/ folder and putting your ant build.xml and
build.properties in there :)
It should solve your problem for now!
David Marques
Re: MTJ overwriting build.properties [message #31664 is a reply to message #31593] Thu, 02 July 2009 08:33 Go to previous message
> Hi teknokrat,
> Regards,
> David Marques
Actually we'll be uninstalling MTJ. We have dozens of projects, all set
up to work with our continuous integration system. We have unit tests,
metrics, reports, etc being run via ant, with many custom tasks. MTJ
doesn't add enough value for us to to go through such a restructuring
nightmare.
Re: MTJ overwriting build.properties [message #574225 is a reply to message #31493] Tue, 30 June 2009 18:39 Go to previous message
Hi teknokrat,
Please look at
David Marques
> cheers
Re: MTJ overwriting build.properties [message #574244 is a reply to message #31528] Thu, 02 July 2009 06:09 Go to previous message
> Hi teknokrat,
> Please look at
Ant?
> Regards,
> David Marques
>> behaviour?
>> cheers
Re: MTJ overwriting build.properties [message #574267 is a reply to message #31563] Thu, 02 July 2009 07:13 Go to previous message
Hi teknokrat,
David Marques
Re: MTJ overwriting build.properties [message #574349 is a reply to message #31593] Thu, 02 July 2009 08:33 Go to previous message
> Hi teknokrat,
> Regards,
> David Marques
nightmare.
Previous Topic:Cannot import device
Next Topic:Webinar Slides
Current Time: Sat Jul 19 11:40:07 EDT 2025
Powered by FUDForum. Page generated in 1.27616 seconds
