A cycle was detected when generating the classpath [message #311497] |
Sun, 14 January 2007 13:20  |
Originally posted by: arno.nymix.gmail.com
Hello
My Plugin runs in the eclipse environment, but when I try to export the
following error occurs:
Problems during export
com.test.myplugin_1.0.0,
org.eclipse.core.runtime_3.2.0v20060603,
org.eclipse.equinox.registry_3.2.0v20060601,
com.ibm.openactivities.client.common.service_3.0.0.20061101- 1847,
What does that mean and how can I avoid this error?
Thx
Arno
Re: A cycle was detected when generating the classpath [message #1806810 is a reply to message #1782701] |
Wed, 15 May 2019 09:52  |
Hello.
I'm trying to implement a Kura Driver and I get this error too.
Whenever I try to generate the jar file with the option "Export -> Plug-in Development | Deployable plug-ins and fragments" I get this error message:
A cycle was detected when generating the classpath <my plugin>, org.eclipse.kura.core.configuration_2.0.300.201905151446, org.eclipse.kura.core_1.0.600.201905151446, org.eclipse.kura.core.configuration_2.0.300.201905151446.
I get the same error message if I try to generate the jar files for org.eclipse.kura.driver.s7plc.provider, org.eclipse.kura.driver.opcua.provider and org.eclipse.kura.driver.ibeacon.provider.
It seems that the cycle is between org.eclipse.kura.core.configuration->org.eclipse.kura.core->org.eclipse.kura.core.configuration or at least is what I understand from the message I'm getting. Am I right?
I have the export option "Allow for binary cycles in target platform checked" although I don't know if that should fix the problem or not.
Could anyone tell me how to fix this?
Thanks in advance.
FUDForum. Page generated in 0.04276 seconds
